Hi All,
I have an issue that seems to belong to accuracy of CG method. I am trying to determine energy of a system having ~ 30000 atoms with a dislocation dipole, relaxing using box-relax with zero applied pressure and CG with the following set up:
minimize 1.0e-20 0.0 10000 20000
It shows a difference in energy and enthalpy of the system. The difference is ~ 0.03 for the system. Then I do similar relaxation with applied uniaxial pressure e.g. 500 MPa, 1 GPa, 2 GPa etc. and I expect the difference between energy and enthalpy to be in the order of applied external pressure. However, I see no trend in the evolution of enthalpy vs. pressure.
On the other hand if do a MD simulation with press/berendsen and NVE at 0 K, it shows the expected trend and at zero external pressure, the energy is identical to enthalpy.
I would like to know if anyone has experienced a similar issue and what could be done to make CG useful for such simulations.
Regards,
Alankar
Hi All,
following set up:
just set your velocities to zero.
atomic velocities are completely disregarded
during minimization, but since the same routines
are called as during MD, e.g. to compute pressure,
their contributions are still included.
so using the following should give the expected behavior:
velocity all set 0.0 0.0 0.0
cheers,
Thanks.
Still not working.
I tried the following:
velocity all zero linear
and also
velocity all zero angular
Still shows descrepency in energy vs. enthalpy at 0 applied pressure.
Alankar
Thanks.
Still not working.
and also
sorry, but if you don't want to follow
given advice, why do ask for it?
Sorry for the confusion.
When I tried
I got the following error:
ERROR: Use of velocity with undefined lattice
I figured out that that I was reading a data filed in my script and therefore had turned off the lattice command.
I turned the lattice command on; it ran well.
However, it could not help me in energy vs. enthalpy discrepancy.
Alankar
When I tried
i don’t believe that. how should this be possible?
if you have no kinetic energy and have a properly
relaxed system (pressure ~0), there is no other
contributing factor that would explain any difference.
have a look at the source code and you’ll see.
i can only assume that you must be doing
something wrong in your comparisons or
calculations that you are not really comparing
apples with apples somehow.
This is simply b/c the velocity command has a units box/lattice
option and the default is lattice. Use units box if you prefer.
But Axel is correct, velocities are ignored for minimization.
