Energy becomes inf after read_dump
Input file:
units real
atom_style atomic
read_data reference.lmp nocoeff
read_dump dump.xyz 0 x y z box no format xyz
mass * 1.0
pair_style lj/cut 5.0
pair_coeff * * 1 1
neighbor 1 bin
run 0
reference.lmp:
2 atoms
1 atom types
0.0 20 xlo xhi
0.0 20 ylo yhi
0.0 20 zlo zhi
Atoms  # atomic
1 1 1.0 2.0 3.0
2 1 1.5 2.5 3.5
dump.xyz:
2
1 1.0 2.0 3.0
1 1.5 2.5 3.5
thermo output:
   Step          Temp          E_pair         E_mol          TotEng         Press
         0   0              inf            0              inf           -nan
If the read_dump line is removed then the output is fine.
Environment (configured with cmake ../cmake, 11 Feb 2026):
OS: Linux "Ubuntu 25.10" 6.17.0-8-generic x86_64
Compiler: GNU C++ 15.2.0 with OpenMP 4.5
C++ standard: C++17
Embedded fmt library version: 10.2.0
Embedded JSON class version: 3.12.0
MPI v3.1: Open MPI v5.0.8, package: Debian OpenMPI, ident: 5.0.8, repo rev: v5.0.8, May 30, 2025
Hi @initialize,
I can’t reproduce your issue here. LAMMPS version?
11 Feb 2026
I can reproduce the issue with the latest pulled branch and the following compiling options:
OS: Linux "Ubuntu 22.04.5 LTS" 6.8.0-101-generic x86_64
Compiler: GNU C++ 11.4.0 with OpenMP 4.5
C++ standard: C++17
MPI v3.1: Open MPI v5.0.10, package: Open MPI germain@N302P-A04316 Distribution, ident: 5.0.10, repo rev: v5.0.10, Feb 23, 2026
Note that using 2 MPI threads seems to correct it, but not other values from 1 to 8. Weird. Will investigate.
Bugfix should be this: Collected small fixes by akohlmey · Pull Request #4910 · lammps/lammps · GitHub
Can confirm, I traced down the same odd pattern. This solved the issue.
