Dear LAMMPS Users and Developers,
I am writing to ask a question regarding spin-lattice dynamics (SLD) simulations of bcc Fe.
During the NVE stage, I observed a continuous decrease in the total energy, which appears to originate from the magnetic energy contribution. Is this behavior expected? I have included my input file below for reference.
I came across a paper discussing energy drift associated with the Suzuki–Trotter decomposition (https://www.sciencedirect.com/science/article/pii/S0010465521003155), but I am not sure whether this fully explains what I am observing.
Zeyu
bcc iron in a 3d periodic box
clear
atom_style spin
# necessary for the serial algorithm (sametag)
atom_modify map array
read_data data.spin
mass 1 55.845
velocity all create 300 4928459 rot yes dist gaussian
pair_style hybrid/overlay eam/alloy spin/exchange 3.5
pair_coeff * * eam/alloy Fe_Mishin2006.eam.alloy Fe
pair_coeff * * spin/exchange exchange 3.4 0.042726 0.2171 1.841 offset yes
variable T equal 300
neighbor 0.1 bin
neigh_modify every 10 check yes delay 20
fix 1 all precession/spin zeeman 0.0 0.0 0.0 1.0
fix_modify 1 energy yes
fix 2 all langevin/spin 300.0 0.001 21
fix 3 all nve/spin lattice moving
#fix 4 all press/langevin x 0 0 10 y 0 0 10 z 0 0 10 temp 𝑇{T} 5351
fix 4 all press/berendsen iso 0.0 0.0 1000.0
fix 5 all langevin 𝑇{T} 10 124141
timestep 0.001
compute out_mag all spin
compute out_pe all pe
compute out_ke all ke
compute out_temp all temp
variable magx equal c_out_mag[1]
variable magy equal c_out_mag[2]
variable magz equal c_out_mag[3]
variable magnorm equal c_out_mag[4]
variable emag equal c_out_mag[5]
variable tmag equal c_out_mag[6]
thermo_style custom step time v_magnorm v_magx v_magy v_magz v_tmag temp v_emag ke pe press etotal
thermo 50
run 50000
unfix 4
run 50000
unfix 2
#unfix 4
unfix 5
#fix 6 all momentum 100 linear 1 1 1
run 50000
compute myKE all ke/atom
compute myPE all pe/atom
compute myStress all stress/atom NULL virial
compute flux all heat/flux myKE myPE myStress
compute outsp all property/atom spx spy spz sp fmx fmy fmz
dump 1 all custom 25 dump_Fe.lammpstrj id type xu yu zu vx vy vz c_outsp[1] c_outsp[2] c_outsp[3]
dump_modify 1 sort id
fix HF_out all ave/time 1 1 25 c_flux[1] c_flux[2] c_flux[3] file heat_flux_profile.dat
run 1000000
