I started using LAMMPS for my research at the start of this year, and doing energy minimization at 0k has worked well. I am currently moving to doing some heating simulations and I want to look at the Energy vs. Temperature to see phase changes. My understanding of looking through the calculations, the temperature will be calculated via the total kinetic energy per degree of freedom. If I am looking at the calculated etotal vs. temperature, one is inferred from the other so the straight line E vs. T graphs make sense as they are being calculated from each other. This would not allow me to see a phase change in an E vs T graph. My question is, is there a way to get temperature or KE values that are not inferred from one another?
A little background into what I am running;
20 carbon atom “isolated-cluster”
heating using nvt from 1 - 3500 K
LCBOP potential used
