Hello All,
My purpose is not to annoy people. Please ignore my email if you feel
annoyed.
it would be less annoying, if you would
pay better attention to what you got told.
I am working on a problem in which I need to determine exact value of
enthalpy that is of the order of 10- 60 meV aka 0.01 - 0.06 eV with applied
pressure. In case of no external pressure, the energy should be equal to
i already explained, that with *any* numerical method,
exact identity is an impossibility. the *exact* value of
your total energy *will* depend on the order of how it
is being summed up, since addition and and multiplication
in floating point math do *not* commute. so to expect
identity is ignoring fundamental properties of the
method you are using, to say the least.
enthalpy. MD method is giving the desired results and now I am looking for
options within CG / SD if possible.
so if you get what you want with simulated annealing,
why bother with minimization? as i wrote before, you
are trying to converge a property beyond a meaningful
threshold. have you considered trying to understand
why rather than insisting on something that you got
told to be pointless?
I am working on suggestions given by the group and update the group about
output. I understand the limitations of different operating system etc.
no, you don't understand. this has *nothing* to do
with the operating system, but is *general* issue
of the propagation of truncation errors when doing
floating point math.
Also, I am relatively new to atomistic simulations.
so, why ignore good advice?
Seems like the discrepancy of energy and enthalpy comes from residual
forces. Using CG or SD, the energy is minimized even though the residual
forces are not zero locally somewhere in the simulations cell.
I tried the following options with CG and SD
min_style cg
min_modify line quadratic
This gives the same discrepancy : Energy is not equal to enthalpy
but by how much?? identity is impossible.
you have only at the most 17 digits accuracy
in double precision floating point math. since
you are summing up derived properties of
different magnitude, probably significantly less.
min_style cg
min_modify line forcezero
This option gives : "ERROR Illegal min_modify command" Why ?
i *already* told you: because you have an outdated
or miscompiled LAMMPS executable.
min_style sd
result = Energy is not equal to enthalpy
again, by how much?
min_style sd
This option gives : "ERROR Illegal min_modify command" . Why ?
I would love to hear about what needs to be modified for using "min_modify
line forcezero". Also, whether CG or SD are capable of solving my problem or
I need to stick to MD method ?.
primarily, you need to rethink what is the meaning of error
and accuracy when doing floating point math. insisting on
getting bitwise identical results with these two scenarios
is ignoring the realities of computer simulations. perhaps
you should port LAMMPS to "bc", which can do arbitrary
precision math (at a cost, of course).
