I am trying to run VASP through ASE calculator to using a FLARE workflow. On submitting the job, it stops with an error because ASE cannot find the pseudopotential files. The error is as follows:
RuntimeError: Looking for PP for potpaw_PBE/Al/POTCAR
The pseudopotentials are expected to be in:
LDA: $VASP_PP_PATH/potpaw/
PBE: $VASP_PP_PATH/potpaw_PBE/
PW91: $VASP_PP_PATH/potpaw_GGA/
No pseudopotential for Al!
I have exported the environment variable by adding different variations of the following line in my .bashrc:
export VASP_PP_PATH=$HOME/jonemec
export VASP_PP_PATH=$HOME/jonemec/potpaw_PBE
export VASP_PP_PATH=“/home3/jonemec”
export VASP_PP_PATH=“$VASP_PP_PATH:/home3/jonemec/potpaw_PBE”
export VASP_PP_PATH=~/potpaw_PBE
export VASP_PP_PATH=/home/jonemec/potpaw_PBE
The error seems to be that the PP files cannot be found no matter what path I export! Any help will be greatly appreciated.
Thank you!
