Hi everyone,
I’m currently working on simulating a cellulose uniaxial test and I’m reaching out to seek some advice from the community.
- I’ve built a cellulose data file using the CHARMM36 force field. The procedure followed the general steps outlined in this paper: (Molecular dynamics simulation of mechanical properties of carbon nanotube reinforced cellulose | Research Square).
- To achieve this, I used the cellulose-builder toolkit for constructing the cellulose crystal geometry.
- Subsequently, I employed charmm2lammps to apply the CHARMM36 force field with the
top-all36-carb.rtpandtop-all36-carb.prmfiles. - I then attempted an equilibration process involving minimization, followed by an NVT ensemble run for 40,000 timesteps and an NPT ensemble run for 100,000 timesteps.
Unfortunately, the resulting cellulose density after equilibration is around 1.32g/cm³, which falls significantly short of the expected value of 1.6 g/cm³ for cellulose.
I would greatly appreciate any insights or suggestions the community might have to help me achieve the desired density in my cellulose simulation.
Below are my input and data files.
crystal.data (1.4 MB)
run.equil.npt (1.8 KB)
Thank you in advance for your time and expertise!
