Eror "domain too large for neighbor bins"
Hello everyone.
I want to relax my nano wire with fix npt but it keeps giving me this error:
“ERROR: Domain too large for neighbor bins (src/nbin_standard.cpp:133)
Last command: run 500”
I’ve put my code below
thanks
Pouya
atom_style atomic
variable dt equal 0.002
variable inputTemp equal 0.01
variable inputPress equal 1.0
variable w equal 0.018
variable periodOfRotation equal 360/${w}
variable tdamp equal 20*${dt}
variable pdamp equal 50*${dt}
----- create lattice -----
region boxRegion block -110 110 -30 30 -30 30 units box
region aluminaRegion block -110 110 -15 15 -15 15 units box
region region_a block -110 -100 -15 15 -15 15 units box
region region_b block -5 5 -15 15 -15 15 units box
region region_c block 100 110 -15 15 -15 15 units box
region surfaceStress block -100 100 -15 15 -15 15 units box
create_box 2 boxRegion
lattice custom 1 a1 4.76570 0.00000 0.00000 a2 -2.38285 4.12722 0.00000 a3 0.00000 0.00000 13.01000 &
basis 0.00000 0.00000 0.35200 &
basis 0.30600 0.00000 0.25000 &
basis 0.00000 0.00000 0.14800 &
basis 0.00000 0.00000 0.64800 &
basis 0.00000 0.00000 0.85200 &
basis 0.66667 0.33333 0.68533 &
basis 0.66667 0.33333 0.48133 &
basis 0.66667 0.33333 0.98133 &
basis 0.66667 0.33333 0.18533 &
basis 0.33333 0.66667 0.01867 &
basis 0.33333 0.66667 0.81467 &
basis 0.33333 0.66667 0.31467 &
basis 0.33333 0.66667 0.51867 &
basis 0.00000 0.30600 0.25000 &
basis 0.69400 0.69400 0.25000 &
basis 0.69400 0.00000 0.75000 &
basis 0.00000 0.69400 0.75000 &
basis 0.30600 0.30600 0.75000 &
basis 0.97267 0.33333 0.58333 &
basis 0.66667 0.63933 0.58333 &
basis 0.36067 0.02733 0.58333 &
basis 0.36067 0.33333 0.08333 &
basis 0.66667 0.02733 0.08333 &
basis 0.97267 0.63933 0.08333 &
basis 0.63933 0.66667 0.91667 &
basis 0.33333 0.97267 0.91667 &
basis 0.02733 0.36067 0.91667 &
basis 0.02733 0.66667 0.41667 &
basis 0.33333 0.36067 0.41667 &
basis 0.63933 0.97267 0.41667
create_atoms 2 region aluminaRegion &
basis 1 1 &
basis 2 2 &
basis 3 1 &
basis 4 1 &
basis 5 1 &
basis 6 1 &
basis 7 1 &
basis 8 1 &
basis 9 1 &
basis 10 1 &
basis 11 1 &
basis 12 1 &
basis 13 1 &
basis 14 2 &
basis 15 2 &
basis 16 2 &
basis 17 2 &
basis 18 2 &
basis 19 2 &
basis 20 2 &
basis 21 2 &
basis 22 2 &
basis 23 2 &
basis 24 2 &
basis 25 2 &
basis 26 2 &
basis 27 2 &
basis 28 2 &
basis 29 2 &
basis 30 2 &
units lattice
mass 1 26.98
mass 2 15.999
neigh_modify binsize 10
neighbor 3 bin
----- potentials -----
pair_style eam/alloy
pair_coeff * * AlO.eam.alloy Al O
----- define groups -----
group aluminaGroup region aluminaRegion
group group_a region region_a
group group_b region region_b
group group_c region region_c
----- initial velocities -----
velocity aluminaGroup create ${inputTemp} 123456 mom yes rot yes dist gaussian
----- computation -----
compute keneticenergy aluminaGroup ke
----- thermo dump -----
thermo 100
thermo_style custom step cpu temp pe c_keneticenergy press pxx pyy pzz
timestep ${dt}
----- run -----
minimize 1e-6 1e-8 10000 10000
reset_timestep 0
dump myDumpHeavy all xyz 50 dumpH.xyz
dump_modify myDumpHeavy element Al O
dump myDumpLight all xyz 1000 dumpL.xyz
dump_modify myDumpLight element Al O
fix relax all npt temp $inputTemp $inputTemp $tdamp aniso $inputPress $inputPress $pdamp
run 500
unfix relax
write_data data.relax pair ij
thermo 100
fix aluminaTempFix aluminaGroup nvt temp $inputTemp $inputTemp $tdamp
fix fix_b group_b move linear 0 0 0
fix aluminaRotationFixA group_a move rotate 0 0 0 0 -1 0 $periodOfRotation units box
fix aluminaRotationFixC group_c move rotate 0 0 0 0 1 0 $periodOfRotation units box
run 1000
Why do you have these two settings?
This is incorrect. As it says in the metadata comment of the potential file, this potential is not a regular EAM potential, but is for Streitz-Mintmire models. Thus likely your system is just exploding due to the incorrect force field and eventually crashing because of the error. Please see the corresponding examples (and read the manual and the corresponding publications!!) for properly setting up and simulating such a system with this force field. lammps/examples/streitz at release · lammps/lammps · GitHub
Those two settings are nothing I just forgot to delete it…my bad.
Thanks a lot for your help.
