Dear axel,
I am working with N2 + H2O mixtures. A slab of ice phase contacts with a slab of liquid H2O-N2 mixture (N2 molecules dissolved in liquid water). The mass of point charge/massless atom (at the center of N2) is set to 0.000000001. The angles and bonds of water molecules are constrained by SHAKE algorithm. When I use fix rigid/nvt for N2 group and fix nvt for water molecules group, the simulation runs very well. When I use fix rigid/npt for N2 group and fix npt for water molecules group. I got the error: Out of range atoms - cannot compute PPPM. That is to say, fix rigid/nvt can work yet fix rigid/npt can’t work with the same data file. However, when I leave out the ice phase, just run a simulation for liquid H2O-N2 mixture. I also use fix rigid/npt for N2 group and fix npt for water molecules group. The simulation runs well again. What could be the reason of this, what could I do? Thanks in advance for any support.
Dear axel,
yet fix rigid/npt can't work with the same data file. However, when I leave
you cannot have two integrators modify box size, i.e. not two npt
style integrators
at the same time. the simplest options is to use fix rigid/npt/small
for the entire system.
