Hi Lammps Users,
I am trying to simulate a system with two layer on a substrate using hybrid function
pair_style hybrid/overlay lj/cut 20.0 tersoff airebo 3.0
pair_coeff * * tersoff SiC.tersoff Si NULL NULL
pair_coeff * * airebo CH.airebo NULL C NULL
giving error
ERROR: All pair coeffs are not set
means 3 or more types of atoms then SiC.tersoff and CH.airebo are not working but for 2 types of atoms they are working fine.
any help is greatly appreciated
regards
Sandeep Kumar Singh
PhD Student
Hi Lammps Users,
function
giving error
well, where are the coefficient setting for the remaining
the first line uses tersoff for all type 1 atoms with type 1 atoms
the second line uses airebo for all type 2 atoms with type 2 atoms
but where are the coefficients for the combinations type 1 with type 2
type 1 with type 3, type 2 with type 3 and type 3 with type 3.
so - as LAMMPS tells you - not all pair coefficients have been set.
why does this surprise you?
Thanks Axel for your kind suggesion. Now problem is solved.
#pair_style tersoff
pair_coeff 1 3 lj/cut 0.01 3.4
pair_coeff 2 3 lj/cut 0.01 3.4
pair_coeff 1 2 lj/cut 0.01 3.4
pair_coeff 3 3 none
