Dear LAMMPS users,
I am simulating the granular system by LAMMPS. I have no problem with the LAMMPS (8 Aug 2014), everything is working well; but after I upgrade LAMMPS to the Stable version (10 Feb 2015) , I meet the problem :
ERROR: Attempting to rescale a 0.0 temperature (../velocity.cpp:715)
using the absolute same input script. The command "velocity chain create $T 4928459 mom yes rot yes dist gaussian" kills the program, if I change it to "velocity chain set 0 0 0 units box", it works, but it is not what I want.
I also use LAMMPS to simulate alkane, the atom_style is full, the similar command "velocity all create $T 4928459 mom yes rot yes dist gaussian" initiates the velocities, both versions work.
Following is part of my input script for granular system:
newton off
processors * * 1
variable T equal 1.0 # Temperature
variable A equal 2.0 # Amplitude
variable W equal 0.7 # Period
variable K equal 5.0
variable l equal 3.1
variable DT equal 0.01
timestep ${DT}
thermo 1000
units lj
atom_style sphere
atom_modify map array sort 10000 2.0
boundary p s s
pair_style gran/hooke/history 20.0 NULL 50.0 NULL 0.5 1
read_data system.data
pair_coeff * *
#read_restart restart_before_steady_state.1000000.friction
group chain type 1 2 3
atom_modify first chain
group bot type 4
group bead1 id 1
group bead2 id 2
group bead3 id 3
group bead4 id 4
group bead5 id 5
neighbor 0.3 bin
#neighbor 2.0 nsq
neigh_modify every 5 delay 0 check yes exclude group bot bot
comm_style tiled
comm_modify vel yes
Thank you very much!
Best wishes,
Wei
