Dear All,
I was using “compute temp/profile”
as a temperature compute for the “fix temp/rescale” in order
to ensure the rescaling of the unbiased velocities and additionally in order to calculate the temperature profile.
My simulation is split in two runs (first of 2000001 and second of 6000000 steps). During the 1st run everything was fine and temperature of the system was around the desired 235K.
As the second run starts the temperature of the system get completely wrong values and after several hundreds of steps LAMMPS outputs an error.
I would appreciate a lot any hint regarding what might went wrong.
Here is the input script
atom_style atomic
neighbor 2.0 bin
read_data data.dd
pair_style dd 4
pair_coeff 1 1 1 1
fix 1 all nve
velocity all create 235.0 4928459 rot yes dist gaussian
compute tz all temp/profile 0 0 1 z 200 out bin
fix 2 all temp/rescale 100 235.0 235.0 10.0 1.0
fix_modify 2 temp tz
timestep 0.001
thermo_style custom step pe ke etotal c_tz
Thermolize
thermo 10
run 2000001
fix 5 all ave/time 10 600000 8000000 c_tz mode vector file temp_prof
Run a simulation
run 6000000
Thanks a lot!
Anton
Dear All,
I was using "compute temp/profile"
as a temperature compute for the "fix temp/rescale" in order
there are two things wrong independently from the problem you are
seeing. a) you don't -provide a complete input. b) you use
temp/rescale in a production calculation.
Why using temperature rescaling for the production run is wrong? I understand that temperature rescaling ruins the dynamics but the average distribution should not be affected. At this point I wanted just to have some thermostating without bias. Do mean that temp/rescale cannot be used together with compute temp/profile?
Please find the full input in the attachment.
data.Hg.dp.N1000.lxlz.d13.69.relaxed (49.3 KB)
in.nodd (1.35 KB)
Not just that.
But why use a bad thermostat when there are better options?
