Hello all,
I am using the Jan 2013 lammps version. When I try to run this meam simulation I get "ERROR: Did not find all elements in MEAM library file". Attached are the input file, the data file, and the library.meam file. I changed the pair_coeff command and created a Ga.meam file with parameters like rc, lattce, etc. but I still get the same error. Attached are the files if you want to look and have any other thoughts.
data.gallium3 (2.95 KB)
in.gallium (495 Bytes)
library.meam (9.38 KB)
Ga.meam (214 Bytes)
Hello all,
there is no entry for "Ga" in your library.meam file. no wonder lammps
is complaining it cannot find it.
