Hi everyone,
I want to stimulate SAFT-g Mie for supercritical hydrogen gas form “Thermophysical properties of supercritical H2 from Molecular Dynamics simulations” in lammps… but it is showing this error…can anyone help…I’m new to lammps
variable dt index 1
units real
atom_style atomic
lattice sc 1.0
region box block 0 8 0 8 0 8
create_box 1 box
create_atoms 1 box
mass 1 1.0
min_style cg
velocity all create 100 87287 loop geom dist gaussian
velocity all zero linear
velocity all zero angular
pair_style mie/cut 4.0000
pair_coeff 1 1 18.355 3.1586 7.813 6.00 4.00
neighbor 0.5 bin
neigh_modify one 10000
minimize 1e-10 1e-10 10000 10000
restart 50000000 restartmpa10.*.equil
#Define Simulation Parameters
fix 1 all npt temp 100 100 100 iso 98.69 98.69 1000.0 tchain 3
#Final setup
thermo_style custom step temp etotal pe ke press vol density
thermo 10000
run_style verlet #verlet velocity
log log-pres-10mpas
timestep ${dt}
run 500
#Advanced inputs
fix 3 all momentum 1000 linear 1 1 1 angular
dump 1 all custom 1000 dump_10mpa.dat id type x y z
comm_modify cutoff 4.5
compute myRDF all rdf 500 cutoff 4.5
fix myRDF all ave/time 100 10000 10000000 c_myRDF[*] file tmp_0-06.dat mode vector
timestep ${dt}
run 100
