Hi while trying to run the lammps I get the following error, I also tried to add path to libtbbmalloc.so.2 but still the error appears. Thank you in advance.
OSError: libtbbmalloc.so.2: cannot open shared object file: No such file or directory
lmp= lammps.lammps()
File “/globalhome/bwa467/HPC/.local/lib/python3.10/site-packages/lammps/core.py”, line 150, in init
self.lib = CDLL(libpath,RTLD_GLOBAL)
File “/cvmfs/soft.computecanada.ca/easybuild/software/2020/avx/Core/python/3.10.2/lib/python3.10/ctypes/init.py”, line 374, in init
File “/globalhome/bwa467/HPC/dataraw/MLP_lmp/lmp-64/Min/min.py”, line 6, in
self._handle = _dlopen(self._name, mode)
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
