LAMMPS ver Jun 2023 and Nov 2022
In the code below I get a segmentation fault error in this code if I add ‘pre no’ to run command,
‘pre no’ cause another error in a another script which is
Dump 1 every variable logsteps returned a bad timestep: 0 (src/output.cpp:509)
in the other code where I am using logfreq3, I get the error. Although, when I print the current timestep it gives 0 and printing the variable it gives 1. So, the variable is greater than the timestep, but still gives an error.
dimension 2
units lj
atom_style atomic
region box block 0 10 0 10 -0.2 0.2
create_box 1 box
create_atoms 1 random 1 123456 box
mass * 1.0
run 0
dump 1 all custom 1 data.restart_small.xyz id x y vx vy
run 1000 post no pre no
