Dear Everyone:
I write a new fix class for lammps.
in my fix class, what i am dong is simple: Firstly, I need the potential energy of the whole system , so i add a method of post_force() in the fix class
and getting the potential energy like this double potential=pe->compute_scalar()
(of course ,something is done in the setup part of this class)
int icompute=modify->find_compute(“thermo_pe”);
if(icompute <0)
error->all(FLERR,“pe ID for fix its does not exist”);
pe=modify->compute[icompute];
secondly, I changed the force of the system by the number of potential
and I compiled the lammps without any error,
but when I am doing some calculations,
I find that when I use the “thermo 1” in the input file , everything is ok , as I expected
but when I use another number other than 1 ,like “thermo 2”, " thermo 20", lammps exit with error : Energy was not tallied on needed timestep …/compute_pe.cpp:75
I read some information from the Web and this problem seems having some relationship with function modify->clearstep_compute() and addstep_compute() which I didn’t use in my fix class.
but I am still very confused and I don’t know how to fix this problem.
Thank you for any suggestions!
Dear Everyone:
if(icompute <0)
The pe->compute_scalar() call can only compute the total potential energy, if that information has been collected during the force computation
, i.e. before your fix is called. thus you need to add pe->addstep(update->ntimestep+1) at the end of your post_force() and setup() methods, so that the collection of potential energy is triggered at the next force computation. there is no need of using pe->clearstep(), this is only required, if you want to force the recomputation of the compute, but that would only work, if the compute style is completely self-contained.
With thermo 1
the energy collection is always enabled and thus
youdon’t
get the error.
Thank you Axel, my fix class works now.
But I have an additional question: if I have two fix classes in my simulation, both of which require the potential energy(or temperature)
of the system at the same state. How to avoid use the pe-> compute_scalar() twice?
or what is in the lammps already takes care of this problem?
thank you again for your reply.
Geng Sun
why would you need to do that?
the explanation is in my previous answer.
