I’m using 27Oct2021 version of lammps.
I use fix gcmc module, with GPU libraries on. I’ve had no problems using the module, with lj/cut/coul/long pair style, with GPU enabled.
However, the error :
ERROR: Fix adapt interface to this pair style not supported (src/pair.cpp:290)
is produced when I try the pair style lj/class2/coul/long. I understand fix gcmc is utilizing fix adapt, but the fix adapt manual states the pair style is supported. Is this due to the GPU version of pair style not being supported?
Regards, and thanks in advance
