Dear LAMMPS experts,
I am trying to insert Li atoms inside my simulation box which contains oxygen molecule and zeolite templated carbon structure. However, I am getting below error,
“ERROR: Fix gcmc cannot exchange individual atoms belonging to a molecule (src/MC/fix_gcmc.cpp:507)”
Could you please guide me how to fix this error? I have attached input script below;
-------------------- Init Section -----------------------
units real
atom_style full
#bond_style harmonic
#angle_style harmonic
#dihedral_style harmonic
pair_style lj/cut/coul/long 12.8
kspace_style ewald 1e-05
kspace_modify gewald 1e5
-------------------- Atom Definition Section ------------
region cathode block 0.545001 35.961001 -4.785577 25.885579 -7.220522 21.696521
read_data FAU_o21.data
#replicate 2 2 2
group ztc molecule 1
group carbon type 1
group O2 molecule 2 3
group o1 type 2
group o2 type 3
molecule lithium Li.xyz #offset 1 0 0 0 0
group Li type 4
set group carbon charge 0
#set group O2 charge -1
pair_coeff * * 0.0000 0.0000 # no LJ interaction between structure and adsorbed atoms
#pair_coeff 1 1 0.1871 3.000 # C-C(C) LJ
pair_coeff 1 2 0.087148348 3.3755 # C1(MOF)-O(O2) LJ ; ARITHMETIC AVERAGE FOR SIGMA AND GEOMETRIC AVERAGE FOR EPSILON, ACCORDING TO THE LORENTZ-BERTHELOT MIXING RULES (SIGMA_MIX=(SIGMA1+SIGMA2)/2) (EPSILON_MIX=SQRT(EPS1*EPS2))
pair_coeff 1 3 0.087148348 3.3755 # C1(MOF)-X(O2) LJ
pair_coeff 2 3 0.072331662 3.3200 # O(O2)-O(O2) LJ
pair_coeff 1 4 0.871 2.000 # C-Li(Li) LJ
pair_coeff 4 4 0.871 1.900 # Li-Li(Li) LJ
pair_coeff 2 4 0.871 1.900 # Li-o2(o2) LJ
pair_coeff 3 4 0.871 1.900 # Li-o2(o2) LJ
-------------------- Settings Section -------------------
compute_modify thermo_temp dynamic yes
neighbor 2 bin
neigh_modify every 1 delay 0 check no one 100000 page 5000000
neigh_modify exclude group carbon carbon
variable Liad equal (atoms-1526)
#variable o2ad equal (atoms-1488-v_Liad)
-------------------- Run Section ------------------------
fix 1 all rigid single force 1 off off off torque 1 off off off
#fix 2 o2 rigid single force 1 off off off torque 1 off off off
#fix 3 o2 rigid single force 1 off off off torque 1 off off off
#fix 1 Li rigid single force 1 off off off torque 1 off off off
#fix 2 Li deposit 38 1 10 12456 mol lithium region cathode
fix fxgc Li gcmc 1 1 1 1 124356789 100.0 -0.5 0.5 group Li pressure 100 full_energy
#fix fxgc o2 gcmc 10 100 100 2 124356789 77.0 -0.5 0.5 pressure 100000 full_energy
thermo 10
thermo_style custom step epair etotal temp press atoms v_Liad #v_o2ad evdwl ecoul emol density
dump 2 all custom 5 FAU_186C_Li*.lammpstrj id type x y z
run 500
write_data FAU_LiO21.end
