I have been optimizing my metal-organic framework system with the presence and absence of guests for adsorption calculation. I am getting the following error with the application of the keywords minimum_image
- "NoConditionsForMin: ‘Conditions for a minimum have not been satisfied. However, no lower point can be found - treat results with caution unless gradient norm is small (less than 0.1)’
and if i use the keyword rfo i am getting the errors - ’ Maximum number of function calls has been reached ’
- ’ Too many failed attempts to optimize '.
I would like to know the reason behind these errors. Any suggestions to rectify them would be helpful.
Thanks.
