Error in Data Retrieval
When running the following code to retrieve the chgcar data for a material:
with MPRester(api_key="*******") as mpr:
    material_id="mp-2137"
    chgcar = mpr.get_charge_density_from_material_id(material_id)
    # In addition, you can specify the level of theory by using "thermo_type", the default is "GGA_GGA+U_R2SCAN":
    #thermo_docs = mpr.thermo.search(
        #material_ids=["mp-12807"], thermo_types=["GGA_GGA+U", "GGA_GGA+U_R2SCAN", "R2SCAN"])
I get an error that looks like this:
NoSuchKey                                 Traceback (most recent call last)
File ~/.local/lib/python3.10/site-packages/smart_open/s3.py:434, in _get(client, bucket, key, version, range_string)
    432         params["Range"] = range_string
--> 434     return client.get_object(**params)
    435 except botocore.client.ClientError as error:
File ~/.local/lib/python3.10/site-packages/botocore/client.py:565, in ClientCreator._create_api_method.<locals>._api_call(self, *args, **kwargs)
    564 # The "self" in this scope is referring to the BaseClient.
--> 565 return self._make_api_call(operation_name, kwargs)
File ~/.local/lib/python3.10/site-packages/botocore/client.py:1021, in BaseClient._make_api_call(self, operation_name, api_params)
   1020     error_class = self.exceptions.from_code(error_code)
-> 1021     raise error_class(parsed_response, operation_name)
   1022 else:
NoSuchKey: An error occurred (NoSuchKey) when calling the GetObject operation: The specified key does not exist.
The above exception was the direct cause of the following exception:
OSError                                   Traceback (most recent call last)
Cell In[23], line 5
      3 with MPRester(api_key="MY-API-KEY") as mpr:
      4     material_id="mp-2137"
----> 5     chgcar = mpr.get_charge_density_from_material_id(material_id)
      7     # In addition, you can specify the level of theory by using "thermo_type", the default is "GGA_GGA+U_R2SCAN":
      8     #thermo_docs = mpr.thermo.search(
      9         #material_ids=["mp-12807"], thermo_types=["GGA_GGA+U", "GGA_GGA+U_R2SCAN", "R2SCAN"])
File ~/.local/lib/python3.10/site-packages/mp_api/client/mprester.py:1348, in MPRester.get_charge_density_from_material_id(self, material_id, inc_task_doc)
   1339 latest_doc = max(  # type: ignore
   1340     results,
   1341     key=lambda x: x.last_updated  # type: ignore
   1342     if self.use_document_model
   1343     else x["last_updated"],  # type: ignore
   1344 )
   1346 decoder = MontyDecoder().decode if self.monty_decode else json.loads
   1347 chgcar = (
-> 1348     self.tasks._query_open_data(
   1349         bucket="materialsproject-parsed",
   1350         key=f"chgcars/{str(latest_doc.task_id)}.json.gz",
   1351         decoder=decoder,
   1352         fields=["data"],
   1353     )[0]
   1354     or {}
   1355 )
   1357 if not chgcar:
   1358     raise MPRestError(f"No charge density fetched for {material_id}.")
File ~/.local/lib/python3.10/site-packages/mp_api/client/core/client.py:390, in BaseRester._query_open_data(self, bucket, key, decoder, fields)
    376 def _query_open_data(
    377     self, bucket: str, key: str, decoder: Callable, fields: list[str]
    378 ) -> tuple[list[dict] | list[bytes], int]:
    379     """Query and deserialize Materials Project AWS open data s3 buckets.
    380
    381     Args:
    388         dict: MontyDecoded data
    389     """
--> 390     file = open(
    391         f"s3://{bucket}/{key}",
    392         encoding="utf-8",
    393         transport_params={"client": self.s3_client},
    394     )
    396     if "jsonl" in key:
    397         decoded_data = [decoder(jline) for jline in file.read().splitlines()]
File ~/.local/lib/python3.10/site-packages/smart_open/smart_open_lib.py:224, in open(uri, mode, buffering, encoding, errors, newline, closefd, opener, compression, transport_params)
    221 except ValueError as ve:
    222     raise NotImplementedError(ve.args[0])
--> 224 binary = _open_binary_stream(uri, binary_mode, transport_params)
    225 decompressed = so_compression.compression_wrapper(binary, binary_mode, compression)
    227 if 'b' not in mode or explicit_encoding is not None:
File ~/.local/lib/python3.10/site-packages/smart_open/smart_open_lib.py:400, in _open_binary_stream(uri, mode, transport_params)
    398 scheme = _sniff_scheme(uri)
    399 submodule = transport.get_transport(scheme)
--> 400 fobj = submodule.open_uri(uri, mode, transport_params)
    401 if not hasattr(fobj, 'name'):
    402     fobj.name = uri
File ~/.local/lib/python3.10/site-packages/smart_open/s3.py:308, in open_uri(uri, mode, transport_params)
    306 parsed_uri, transport_params = _consolidate_params(parsed_uri, transport_params)
    307 kwargs = smart_open.utils.check_kwargs(open, transport_params)
--> 308 return open(parsed_uri['bucket_id'], parsed_uri['key_id'], mode, **kwargs)
File ~/.local/lib/python3.10/site-packages/smart_open/s3.py:392, in open(bucket_id, key_id, mode, version_id, buffer_size, min_part_size, multipart_upload, defer_seek, client, client_kwargs, writebuffer)
    389     raise ValueError("version_id must be None when writing")
    391 if mode == constants.READ_BINARY:
--> 392     fileobj = Reader(
    393         bucket_id,
    394         key_id,
    395         version_id=version_id,
    396         buffer_size=buffer_size,
    397         defer_seek=defer_seek,
    398         client=client,
    399         client_kwargs=client_kwargs,
    400     )
    401 elif mode == constants.WRITE_BINARY:
    402     if multipart_upload:
File ~/.local/lib/python3.10/site-packages/smart_open/s3.py:698, in Reader.__init__(self, bucket, key, version_id, buffer_size, line_terminator, defer_seek, client, client_kwargs)
    695 self.raw = None
    697 if not defer_seek:
--> 698     self.seek(0)
File ~/.local/lib/python3.10/site-packages/smart_open/s3.py:793, in Reader.seek(self, offset, whence)
    788     offset += self._current_pos
    790 if not self._seek_initialized or not (
    791     whence == constants.WHENCE_START and offset == self._current_pos
    792 ):
--> 793     self._current_pos = self._raw_reader.seek(offset, whence)
    795     self._buffer.empty()
    797 self._eof = self._current_pos == self._raw_reader._content_length
File ~/.local/lib/python3.10/site-packages/smart_open/s3.py:521, in _SeekableRawReader.seek(self, offset, whence)
    519     self._position = self._content_length
    520 else:
--> 521     self._open_body(start, stop)
    523 return self._position
File ~/.local/lib/python3.10/site-packages/smart_open/s3.py:542, in _SeekableRawReader._open_body(self, start, stop)
    538 range_string = smart_open.utils.make_range_string(start, stop)
    540 try:
    541     # Optimistically try to fetch the requested content range.
--> 542     response = _get(
    543         self._client,
    544         self._bucket,
    545         self._key,
    546         self._version_id,
    547         range_string,
    548     )
    549 except IOError as ioe:
    550     # Handle requested content range exceeding content size.
    551     error_response = _unwrap_ioerror(ioe)
File ~/.local/lib/python3.10/site-packages/smart_open/s3.py:442, in _get(client, bucket, key, version, range_string)
    436 wrapped_error = IOError(
    437     'unable to access bucket: %r key: %r version: %r error: %s' % (
    438         bucket, key, version, error
    439     )
    440 )
    441 wrapped_error.backend_error = error
--> 442 raise wrapped_error from error
OSError: unable to access bucket: 'materialsproject-parsed' key: 'chgcars/mp-1436207.json.gz' version: None error: An error occurred (NoSuchKey) when calling the GetObject operation: The specified key does not exist.
From what I can gather it seems that mp-api is referencing a different material_id(mp-1426207) than my input(mp-2137). This error is not unique to this particular material, but occurs in a few. Here is a list of the ones that have given me the same type of error:
mp-19410
mp-19399
mp-1211715
mp-18750
mp-20758
mp-608016
mp-637188
mp-19202
mp-20167
mp-648893
mp-755882
mp-510598
mp-1103973
mp-36447
mp-540763
mp-2137
mp-18937
Note: this is not a comprehensive list, just ones that I’ve encountered personally.
Is this an error on my end or in mp-api?
Thanks!
Thanks for reaching out. I edited your traceback to remove your API key. Please consider using the MP_API_KEY environment variable to avoid accidentally exposing your API key.
Make sure to use the latest material_id for a material and not a task_id. Run your list of task_id/material_ids through a search to get a mapping:
mpr.materials.search(task_ids=[<list of ids>], fields=["material_id"])
Also, see this thread for how to deal with the remaining NoSuchKey errors: NoSuchKey error - #2 by tschaume
Hi sorry I meant to follow up on this post but something came up.
So I tried your code snippet to retrieve the material_id, assuming that the error was occurring due to trying to fetch for material properties via the task_id instead of the material_id.
The output says that my task_ids and my material_ids are the same?
list = ['mp-19410', 'mp-19399', 'mp-1211715',
        'mp-18750', 'mp-20758', 'mp-608016',
        'mp-637188', 'mp-19202', 'mp-20167',
        'mp-648893', 'mp-755882', 'mp-510598',
        'mp-1103973', 'mp-36447', 'mp-540763',
        'mp-2137', 'mp-18937']
idlist = []
for x in list:
    with MPRester(api_key="------------") as mpr:
        mpid=mpr.materials.search(task_ids=[x], fields=["material_id"])
        idlist.append(mpid)
print(idlist)
[[MPDataDoc<MaterialsDoc>(
material_id=MPID(mp-19410),
fields_not_requested=['builder_meta', 'nsites', 'elements', 'nelements', 'composition', 'composition_reduced', 'formula_pretty', 'formula_anonymous', 'chemsys', 'volume', 'density', 'density_atomic', 'symmetry', 'structure', 'deprecated', 'deprecation_reasons', 'initial_structures', 'task_ids', 'deprecated_tasks', 'calc_types', 'last_updated', 'created_at', 'origins', 'warnings', 'task_types', 'run_types', 'entries']
)], [MPDataDoc<MaterialsDoc>(
material_id=MPID(mp-19399),
material_id=MPID(mp-1211715),
material_id=MPID(mp-18750),
material_id=MPID(mp-20758),
material_id=MPID(mp-608016),
material_id=MPID(mp-637188),
material_id=MPID(mp-19202),
material_id=MPID(mp-20167),
material_id=MPID(mp-648893),
material_id=MPID(mp-755882),
material_id=MPID(mp-510598),
material_id=MPID(mp-1103973),
material_id=MPID(mp-36447),
material_id=MPID(mp-540763),
material_id=MPID(mp-2137),
material_id=MPID(mp-18937),
Am I interpreting this output incorrectly?
Yes, that’s correct.
In which case my error from my original post persists.
Using these material_ids will still trigger the initial error in which the API searches for a different id than the one that is prompted.
Unless I’m just confused?
The NoSuchKey error can unfortunately happen for some chgcars when they’re not available in our AWS OpenData repository. See the thread that I linked in my earlier response on how to deal with them: NoSuchKey error - #2 by tschaume. We’re working on making sure that this error occurs less in the future.
