Hi everyone, I’m trying to install the latest “exciting fluorine” on my campus supercomputer server. I followed the instructions on Download and Compile exciting - exciting, but got stuck at the last step
$ make smp
I first tried to compile with Intel ifort,
$ cp build/platforms/make.inc.ifort build/make.inc
$ make smp
which ends up with the following error msg:
make[3]: Entering directory `/nfs-share/home/1600011754/exciting/external/Lbfgsb.3.0'
ar -rc liblbfgs.a lbfgsb.o linpack.o timer.o
make[3]: Leaving directory `/nfs-share/home/1600011754/exciting/external/Lbfgsb.3.0'
cp ../../external/Lbfgsb.3.0/liblbfgs.a ./
perl ../../build/utilities/versionstamp.pl
readline() on closed filehandle $HEADREF at ../../build/utilities/versionstamp.pl line 14.
readline() on closed filehandle $REFS at ../../build/utilities/versionstamp.pl line 41.
../../build/utilities/mkmf -t ./template -f -m Makefile.mkmf\
-p exciting ../../src/math ../../src/testframework ../../src/ ../../src/simplified_input ../../src/lapack_wrappers ../../src/lapack_wrappers/f95_interfaces ../../src/lapack_wrappers/multiplication ../../src/lapack_wrappers/decomposition ../../src/lapack_wrappers/diagonalization ../../src/lapack_wrappers/utils ../../src/lapack_wrappers/tensor_contraction ../../src/char_utils ../../src/writers ../../src/structure ../../src/src_advanced/ ../../src/constants ../../src/src_eigensystem/ ../../src/errors_warnings ../../src/char_utils ../../src/src_fermisurfdx/ ../../src/src_gw/ ../../src/src_gw/src_vxc ../../src/src_gw/src_tests ../../src/src_hybrids/ ../../src/input ../../src/src_inputparser/ ../../src/src_LDAU/ ../../src/src_lib/ ../../src/src_lib/bessel ../../src/math ../../src/src_mixing/ ../../src/src_mpi/ ../../src/src_mpi/routines/ ../../src/src_mpi/serial/ ../../src/src_optics/ ../../src/src_phonon/ ../../src/src_raman/ ../../src/src_rdmft/ ../../src/src_stm/ ../../src/src_sym/ ../../src/testframework ../../src/src_vdW/ ../../src/src_wannier ../../src/src_xc/ ../../src/src_xml/ ../../src/src_xs/ ../../src/src_xs/modtetra ../../src/src_xs/src_rttddft ../../src/wavefunctions ../../src/sirius ../../src/read ../../src/potential ../../src/file_io ../../src/matrix_elements ../../src/dfpt ../../external/libXC/src/libxc.f90 ../../external/libXC/src/libxc_funcs.f90 ../../src/mainxml/\
&& make -f Makefile.mkmf exciting
.......................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................... Makefile.mkmf is ready.
make[3]: Entering directory `/nfs-share/home/1600011754/exciting/build/smp'
ifort -O3 -ip -unroll -scalar_rep -cpp -DXS -DISO -DLIBXC -DIFORT -DFFTW -DMKL -qopenmp -DUSEOMP -Ifinclude -I"/nfs-share/software/intel/2017.1/compilers_and_libraries_2017.1.132/linux/mkl/include" -I"/nfs-share/software/intel/2017.1/compilers_and_libraries_2017.1.132/linux/mkl/include/intel64/lp64" -c ../../src/file_io/block_data_file.f90
../../src/file_io/block_data_file.f90(79): error #8304: In an intrinsic assignment statement, variable shall not be polymorphic. [TYPE_DUMMY]
this%type_dummy = type_dummy
compilation aborted for ../../src/file_io/block_data_file.f90 (code 1)
make[3]: *** [block_data_file.o] Error 1
make[3]: Leaving directory `/nfs-share/home/1600011754/exciting/build/smp'
make[2]: *** [bin] Error 2
make[2]: Leaving directory `/nfs-share/home/1600011754/exciting/build/smp'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/nfs-share/home/1600011754/exciting/build/smp'
make: *** [smp] Error 2
while I also tried using gfortran:
$ cp build/platforms/make.inc.gfortran build/make.inc
$ make smp
which also fails, giving the following message:
gfortran -O3 -march=native -ffree-line-length-0 -cpp -DXS -DISO -DLIBXC -fopenmp -DUSEOMP -Ifinclude -c ../../src/file_io/block_data_file.f90
../../src/file_io/block_data_file.f90:3.6:
use precision, only: dp
1
Fatal Error: File 'precision.mod' opened at (1) is not a GNU Fortran module file
the ifort and gfortran versions are:
$ ifort --version
ifort (IFORT) 17.0.1 20161005
Copyright (C) 1985-2016 Intel Corporation. All rights reserved.
$ gfortran --version
GNU Fortran (GCC) 4.8.5 20150623 (Red Hat 4.8.5-39)
Copyright (C) 2015 Free Software Foundation, Inc.
GNU Fortran comes with NO WARRANTY, to the extent permitted by law.
You may redistribute copies of GNU Fortran
under the terms of the GNU General Public License.
For more information about these matters, see the file named COPYING
I know little about Fortran and I’m not sure how I can solve these problems. Can anyone kindly help me? Thanks in advance!
