Error in minimization
Hi All,
I am trying to simulate polymer in water. I am using buckingham potential to define the polymer while LJ and buckingham for the polymer and water interaction for different pairs. I used the packmol to generate the initial configuration and tranferred those coordinates to generate the topological file for my simulation. The mail issue here is , when I try to run the simulation, the energy decreases very quickly and reaches to the range around negative 10^56 or even greater in 5-10 steps. Then, I thought there must be a bad contact between the polymer atoms, since there is no way I can see the bad contact among water molecules. I created new configuration of the polymer chain so that my polymer itself is in good shape. But still the problem persists. I am a new user in LAMMPS and I shifted from GROMACS, just to incorporate both LJ and Buckingham potential in the system. I am not sure why such wierd behavior is happening. I checked my potential parameters just to match the paper i used( one by one) and it seems perfectly fine with number and units. I have attached the system.data file and the run file over here. I would really appreciate your help, because I am stuck in this problem for a longer time just to figure out myself.
#Model for PPO
1539 atoms
1058 bonds
645 angles
37 dihedrals
0 impropers
5 atom types
4 bond types
10 angle types
5 dihedral types
-1.0000 25.5000 xlo xhi
-1.0000 40.5000 ylo yhi
-1.0000 25.5000 zlo zhi
Masses
1 1.0078 #HP#HP1#HP2#HP3
2 12.0110 #CP#CH#CH3#CH2
3 15.9994 #OP #OP1
4 15.9994 #OW
5 1.0078 #HW
Atoms
1 1 1 0.0389 25.075 3.582 3.359
2 1 1 0.0389 24.757 3.742 1.62
3 1 1 0.0389 24.341 2.23 2.429
4 1 2 0.0858 24.382 3.317 2.554
5 1 3 -0.3760 23.084 3.844 2.794
6 1 2 0.1636 22.564 3.585 4.11
7 1 1 0.0266 23.273 3.961 4.861
8 1 2 -0.1519 22.346 2.089 4.331
9 1 1 0.0423 21.747 1.659 3.52
10 1 1 0.0423 21.85 1.888 5.285
11 1 1 0.0423 23.299 1.549 4.337
12 1 2 0.2124 21.241 4.372 4.239
13 1 1 -0.0008 20.546 4.005 3.475
14 1 1 -0.0008 21.435 5.429 4.019
15 1 3 -0.3760 20.654 4.261 5.545
16 1 2 0.1636 19.415 4.996 5.685
17 1 1 0.0266 19.535 5.997 5.247
18 1 2 -0.1519 18.286 4.26 4.964
19 1 1 0.0423 18.437 4.263 3.88
20 1 1 0.0423 17.313 4.718 5.161
21 1 1 0.0423 18.254 3.207 5.271
22 1 2 0.2124 19.079 5.159 7.192
23 1 1 -0.0008 19.976 5.54 7.693
24 1 1 -0.0008 18.839 4.181 7.628
25 1 3 -0.3760 17.986 6.077 7.408
26 1 2 0.1636 17.498 6.148 8.776
27 1 1 0.0266 17.1 5.162 9.042
28 1 2 -0.1519 18.609 6.503 9.763
29 1 1 0.0423 19.355 5.703 9.815
30 1 1 0.0423 18.221 6.638 10.777
31 1 1 0.0423 19.134 7.413 9.453
32 1 2 0.2124 16.319 7.173 8.845
33 1 1 -0.0008 16.618 8.107 8.357
34 1 1 -0.0008 15.479 6.767 8.267
35 1 3 -0.3760 15.906 7.494 10.193
36 1 2 0.1636 14.519 7.917 10.323
37 1 1 0.0266 14.201 8.356 9.369
38 1 2 -0.1519 13.681 6.679 10.611
39 1 1 0.0423 13.824 5.924 9.83
40 1 1 0.0423 12.616 6.918 10.66
41 1 1 0.0423 13.987 6.212 11.553
42 1 2 0.2124 14.367 9.037 11.415
43 1 1 -0.0008 15.311 9.136 11.964
44 1 1 -0.0008 14.209 9.993 10.901
45 1 3 -0.3760 13.338 8.823 12.409
46 1 2 0.1636 12.355 9.882 12.555
47 1 1 0.0266 12.796 10.851 12.292
48 1 2 -0.1519 11.196 9.579 11.611
49 1 1 0.0423 11.55 9.49 10.579
50 1 1 0.0423 10.43 10.359 11.646
51 1 1 0.0423 10.731 8.62 11.867
52 1 2 0.2124 11.861 9.971 14.041
53 1 1 -0.0008 11.591 8.963 14.373
54 1 1 -0.0008 12.695 10.316 14.665
55 1 3 -0.3760 10.725 10.849 14.232
56 1 2 0.1636 10.392 11.163 15.617
57 1 1 0.0266 11.198 11.787 16.023
58 1 2 -0.1519 10.26 9.911 16.489
59 1 1 0.0423 9.539 9.21 16.056
60 1 1 0.0423 9.945 10.158 17.507
61 1 1 0.0423 11.216 9.385 16.571
62 1 2 0.2124 9.062 11.994 15.677
63 1 1 -0.0008 8.284 11.429 15.152
64 1 1 -0.0008 9.202 12.941 15.144
65 1 3 -0.3760 8.625 12.266 17.031
66 1 2 0.1636 7.444 13.103 17.156
67 1 1 0.0266 7.63 14.055 16.643
68 1 2 -0.1519 6.211 12.434 16.543
69 1 1 0.0423 6.308 12.338 15.458
70 1 1 0.0423 5.301 13.011 16.738
71 1 1 0.0423 6.078 11.424 16.946
72 1 2 0.2124 7.164 13.402 18.664
73 1 1 -0.0008 8.073 13.814 19.114
74 1 1 -0.0008 6.926 12.467 19.185
75 1 3 -0.3760 6.09 14.35 18.841
76 1 2 0.1636 5.525 14.401 20.177
77 1 1 0.0266 5.112 13.413 20.415
78 1 2 -0.1519 6.562 14.766 21.238
79 1 1 0.0423 7.345 14.004 21.299
80 1 1 0.0423 6.11 14.843 22.232
81 1 1 0.0423 7.049 15.716 20.998
82 1 2 0.2124 4.35 15.418 20.188
83 1 1 -0.0008 4.695 16.389 19.814
84 1 1 -0.0008 3.572 15.065 19.501
85 1 3 -0.3760 3.801 15.614 21.506
86 1 2 0.1636 2.502 16.248 21.49
87 1 1 0.0266 2.414 16.834 20.569
88 1 2 -0.1519 1.436 15.156 21.514
89 1 1 0.0423 1.524 14.505 20.639
90 1 1 0.0423 0.427 15.582 21.526
91 1 1 0.0423 1.557 14.511 22.391
92 1 2 0.2124 2.353 17.247 22.67
93 1 1 -0.0008 1.941 18.183 22.269
94 1 1 -0.0008 3.325 17.477 23.12
95 1 3 -0.4050 1.492 16.755 23.704
96 1 2 0.0858 0.651 17.766 24.249
97 1 1 0.0389 0.062 17.33 25.06
98 1 1 0.0389 -0.042 18.133 23.485
99 1 1 0.0389 1.244 18.594 24.649
100 2 4 -1.0400 15.483 11.567 0.372
101 2 5 0.5200 15.798 10.682 0.571
102 2 5 0.5200 15.463 12.088 1.178
103 3 4 -1.0400 4.228 16.692 17.009
104 3 5 0.5200 3.568 16.037 17.247
105 3 5 0.5200 3.822 17.374 16.469
106 4 4 -1.0400 1.702 2.857 20.775
107 4 5 0.5200 0.948 2.311 21.008
108 4 5 0.5200 1.682 3.667 21.29
109 5 4 -1.0400 23.198 40.727 23.211
110 5 5 0.5200 22.636 40.655 23.986
111 5 5 0.5200 23.432 41.647 23.069
112 6 4 -1.0400 17.65 13.14 7.731
113 6 5 0.5200 17.477 13.916 7.192
114 6 5 0.5200 16.958 12.49 7.587
115 7 4 -1.0400 10.633 23.214 6.464
116 7 5 0.5200 10.666 24.129 6.177
117 7 5 0.5200 9.719 22.918 6.485
118 8 4 -1.0400 21.578 0.717 1.765
119 8 5 0.5200 21.646 1.581 1.351
120 8 5 0.5200 20.707 0.616 2.156
121 9 4 -1.0400 9.406 8.851 23.95
122 9 5 0.5200 9.533 7.909 23.816
123 9 5 0.5200 8.487 9.077 23.792
124 10 4 -1.0400 20.638 5.795 2.075
125 10 5 0.5200 21.207 6.537 2.291
126 10 5 0.5200 21.175 5.05 1.795
127 11 4 -1.0400 21.437 41.767 3.285
128 11 5 0.5200 22.084 41.097 3.051
129 11 5 0.5200 21.275 41.739 4.23
130 12 4 -1.0400 5.177 4.629 13.095
131 12 5 0.5200 5.815 4.556 12.382
132 12 5 0.5200 4.309 4.818 12.73
133 13 4 -1.0400 24.945 15.514 6.798
134 13 5 0.5200 24.902 15.865 5.906
135 13 5 0.5200 24.056 15.408 7.144
136 14 4 -1.0400 23.992 16.802 9.982
137 14 5 0.5200 23.717 15.908 9.766
138 14 5 0.5200 23.593 17.068 10.813
139 15 4 -1.0400 16.084 16.506 10.965
140 15 5 0.5200 16.706 15.792 11.123
141 15 5 0.5200 16.495 17.174 10.412
142 16 4 -1.0400 13.362 24.526 13.201
143 16 5 0.5200 13.557 25.253 13.796
144 16 5 0.5200 14.183 24.155 12.869
145 17 4 -1.0400 24.143 3.13 8.786
146 17 5 0.5200 24.723 2.486 9.199
147 17 5 0.5200 23.872 3.781 9.437
148 18 4 -1.0400 20.559 41.3 12.516
149 18 5 0.5200 21.312 41.794 12.848
150 18 5 0.5200 20.797 40.374 12.428
151 19 4 -1.0400 7.859 25.437 7.252
152 19 5 0.5200 7.85 24.978 8.095
153 19 5 0.5200 8.57 25.092 6.707
154 20 4 -1.0400 2.085 15.054 5.568
155 20 5 0.5200 1.267 14.629 5.837
156 20 5 0.5200 1.907 15.964 5.321
157 21 4 -1.0400 13.993 23.989 8.966
158 21 5 0.5200 13.167 24.052 9.452
159 21 5 0.5200 14.269 23.071 8.92
160 22 4 -1.0400 14.416 35.891 3.554
161 22 5 0.5200 14.178 34.975 3.395
162 22 5 0.5200 15.011 35.942 4.305
163 23 4 -1.0400 15.122 11.586 9.431
164 23 5 0.5200 16.072 11.704 9.515
165 23 5 0.5200 14.677 12.064 10.135
166 24 4 -1.0400 21.616 14.979 15.409
167 24 5 0.5200 21.452 14.56 16.257
168 24 5 0.5200 20.783 15.268 15.029
169 25 4 -1.0400 5.821 36.267 7.717
170 25 5 0.5200 5.309 37.057 7.526
171 25 5 0.5200 6.098 35.858 6.894
172 26 4 -1.0400 24.138 28.217 16.729
173 26 5 0.5200 24.44 27.374 16.382
174 26 5 0.5200 24.781 28.553 17.358
175 27 4 -1.0400 19.738 41.374 19.282
176 27 5 0.5200 20.298 40.61 19.122
177 27 5 0.5200 20.053 41.843 20.058
178 28 4 -1.0400 12.965 44.256 9.678
179 28 5 0.5200 12.649 43.558 10.256
180 28 5 0.5200 13.481 43.872 8.965
181 29 4 -1.0400 9.012 21.451 9.12
182 29 5 0.5200 9.452 21.717 8.309
183 29 5 0.5200 8.601 22.217 9.527
184 30 4 -1.0400 9.776 17.531 11.294
185 30 5 0.5200 9.933 16.616 11.05
186 30 5 0.5200 10.61 17.952 11.514
187 31 4 -1.0400 21.133 39.303 6.445
188 31 5 0.5200 21.55 38.46 6.641
189 31 5 0.5200 21.412 39.605 5.578
190 32 4 -1.0400 16.993 36.385 9.039
191 32 5 0.5200 16.658 35.493 8.917
192 32 5 0.5200 17.911 36.347 9.316
193 33 4 -1.0400 23.042 33.003 2.242
194 33 5 0.5200 22.097 32.836 2.244
195 33 5 0.5200 23.2 33.95 2.266
196 34 4 -1.0400 22.625 30.836 7.522
197 34 5 0.5200 22.457 31.678 7.953
198 34 5 0.5200 21.816 30.517 7.116
199 35 4 -1.0400 9.402 31.972 4.267
200 35 5 0.5200 8.883 32.289 3.524
201 35 5 0.5200 10.041 32.642 4.521
202 36 4 -1.0400 4.442 30.676 21.121
203 36 5 0.5200 4.651 31.57 21.399
204 36 5 0.5200 4.825 30.05 21.741
205 37 4 -1.0400 21.539 12.577 6.042
206 37 5 0.5200 20.88 12.909 6.657
207 37 5 0.5200 21.1 12.181 5.285
208 38 4 -1.0400 6.169 28.244 7.704
209 38 5 0.5200 6.976 28.082 8.199
210 38 5 0.5200 6.102 27.611 6.985
211 39 4 -1.0400 9.131 1.09 14.061
212 39 5 0.5200 9.05 0.752 14.956
213 39 5 0.5200 9.485 0.403 13.49
214 40 4 -1.0400 4.52 39.195 8.046
215 40 5 0.5200 4.409 38.71 8.867
216 40 5 0.5200 5.454 39.256 7.834
217 41 4 -1.0400 11.435 9.977 6.124
218 41 5 0.5200 10.511 10.202 5.991
219 41 5 0.5200 11.522 9.027 6.228
220 42 4 -1.0400 11.509 40.832 2.129
221 42 5 0.5200 12.465 40.751 2.105
222 42 5 0.5200 11.112 40.054 1.729
223 43 4 -1.0400 18.751 24.788 15.438
224 43 5 0.5200 18.426 24.181 14.768
225 43 5 0.5200 18.449 24.501 16.303
226 44 4 -1.0400 23.495 2.308 19.866
227 44 5 0.5200 24.451 2.34 19.948
228 44 5 0.5200 23.093 2.665 20.661
229 45 4 -1.0400 14.693 23.438 15.982
230 45 5 0.5200 15.116 22.748 16.498
231 45 5 0.5200 14.413 23.08 15.137
232 46 4 -1.0400 17.265 7.342 16.264
233 46 5 0.5200 17.931 7.14 15.603
234 46 5 0.5200 17.571 7.052 17.126
235 47 4 -1.0400 7.486 6.091 8.961
236 47 5 0.5200 6.576 6.214 9.241
237 47 5 0.5200 7.647 5.159 8.796
238 48 4 -1.0400 12.678 4.961 1.196
239 48 5 0.5200 12.45 5.845 0.9
240 48 5 0.5200 12.24 4.313 0.64
241 49 4 -1.0400 12.293 10.981 8.985
242 49 5 0.5200 12.919 10.347 9.344
243 49 5 0.5200 11.432 10.567 8.898
244 50 4 -1.0400 3.882 35.572 18.212
245 50 5 0.5200 3.447 34.725 18.336
246 50 5 0.5200 4.777 35.526 18.557
247 51 4 -1.0400 17.414 27.242 0.83
248 51 5 0.5200 18.315 26.909 0.824
249 51 5 0.5200 17.428 28.201 0.873
250 52 4 -1.0400 13.808 36.132 20.065
251 52 5 0.5200 13.314 35.845 19.293
252 52 5 0.5200 13.723 35.477 20.761
253 53 4 -1.0400 14.874 38.239 5.834
254 53 5 0.5200 13.978 38.491 5.6
255 53 5 0.5200 14.898 37.304 6.052
256 54 4 -1.0400 17.479 29.852 24.484
257 54 5 0.5200 17.973 29.03 24.453
258 54 5 0.5200 18.018 30.563 24.13
259 55 4 -1.0400 18.758 33.282 7.502
260 55 5 0.5200 18.962 33.009 8.399
261 55 5 0.5200 17.821 33.159 7.335
262 56 4 -1.0400 9.973 2.405 16.852
263 56 5 0.5200 10.748 2.831 17.226
264 56 5 0.5200 10.091 1.452 16.871
265 57 4 -1.0400 24.112 19.462 24.534
266 57 5 0.5200 23.287 19.788 24.902
267 57 5 0.5200 23.925 18.787 23.878
268 58 4 -1.0400 8.655 35.96 14.953
269 58 5 0.5200 9.47 35.778 14.479
270 58 5 0.5200 8.758 36.761 15.472
271 59 4 -1.0400 20.463 19.381 5.115
272 59 5 0.5200 21.018 19.105 5.848
273 59 5 0.5200 19.884 18.658 4.862
274 60 4 -1.0400 23.327 21.741 7.195
275 60 5 0.5200 23.572 22.635 7.445
276 60 5 0.5200 24.118 21.241 6.98
277 61 4 -1.0400 15.955 43.251 2.486
278 61 5 0.5200 16.349 43.081 1.627
279 61 5 0.5200 15.035 42.976 2.476
280 62 4 -1.0400 5.686 18.559 11.641
281 62 5 0.5200 6.519 18.47 11.172
282 62 5 0.5200 5.404 17.697 11.957
283 63 4 -1.0400 20.655 44.864 14.478
284 63 5 0.5200 21.596 44.998 14.617
285 63 5 0.5200 20.479 43.927 14.367
286 64 4 -1.0400 22.449 34.561 24.58
287 64 5 0.5200 22.707 35.482 24.671
288 64 5 0.5200 21.602 34.509 24.132
289 65 4 -1.0400 12.918 43.199 6.57
290 65 5 0.5200 12.419 42.451 6.906
291 65 5 0.5200 13.668 42.881 6.061
292 66 4 -1.0400 7.759 29.341 10.662
293 66 5 0.5200 6.917 29.602 10.283
294 66 5 0.5200 7.814 28.383 10.691
295 67 4 -1.0400 0.686 5.09 19.182
296 67 5 0.5200 0.307 5.972 19.184
297 67 5 0.5200 0 4.447 19.378
298 68 4 -1.0400 23.354 17.483 7.351
299 68 5 0.5200 22.742 16.998 7.91
300 68 5 0.5200 23.041 18.384 7.24
301 69 4 -1.0400 21.652 39.262 22.026
302 69 5 0.5200 21.666 38.954 22.936
303 69 5 0.5200 21.93 38.551 21.444
304 70 4 -1.0400 4.649 22.798 0.573
305 70 5 0.5200 5.512 22.48 0.297
306 70 5 0.5200 4.712 23.724 0.818
307 71 4 -1.0400 23.548 38.459 8.92
308 71 5 0.5200 23.99 39.307 8.833
309 71 5 0.5200 23.206 38.187 8.065
310 72 4 -1.0400 21.838 39.546 1.278
311 72 5 0.5200 22.342 40.143 0.72
312 72 5 0.5200 22.437 39.057 1.847
313 73 4 -1.0400 19.409 36.489 14.827
314 73 5 0.5200 19.894 37.002 14.176
315 73 5 0.5200 19.917 35.71 15.064
316 74 4 -1.0400 1.129 38.533 2.117
317 74 5 0.5200 1.073 38.432 1.164
318 74 5 0.5200 0.811 39.404 2.366
319 75 4 -1.0400 1.851 36.514 2.629
320 75 5 0.5200 0.955 36.177 2.552
321 75 5 0.5200 1.945 36.986 3.459
322 76 4 -1.0400 12.093 42.002 14.327
323 76 5 0.5200 12.984 42.226 14.049
324 76 5 0.5200 11.618 42.804 14.558
325 77 4 -1.0400 5.801 15.408 3.953
326 77 5 0.5200 6.222 16.027 4.554
327 77 5 0.5200 6.17 14.532 4.084
328 78 4 -1.0400 13.271 29.459 17.013
329 78 5 0.5200 14.183 29.507 17.309
330 78 5 0.5200 12.887 30.338 17.016
331 79 4 -1.0400 3.598 1.991 2.362
332 79 5 0.5200 3.146 1.373 2.941
333 79 5 0.5200 4.519 1.734 2.276
334 80 4 -1.0400 15.966 34.216 20.472
335 80 5 0.5200 16.683 33.99 19.875
336 80 5 0.5200 16.006 35.152 20.68
337 81 4 -1.0400 4.284 25.605 21.093
338 81 5 0.5200 3.671 26.012 21.71
339 81 5 0.5200 4.137 24.657 21.075
340 82 4 -1.0400 6.876 28.123 16.239
341 82 5 0.5200 7.19 27.216 16.206
342 82 5 0.5200 5.938 28.144 16.038
343 83 4 -1.0400 1.008 18.76 16.107
344 83 5 0.5200 1.864 18.326 16.133
345 83 5 0.5200 0.549 18.515 15.301
346 84 4 -1.0400 16.951 17.677 13.104
347 84 5 0.5200 17.683 18.229 13.386
348 84 5 0.5200 16.129 18.166 13.19
349 85 4 -1.0400 13.76 25.927 6.423
350 85 5 0.5200 14.405 25.752 7.113
351 85 5 0.5200 13.003 26.38 6.8
352 86 4 -1.0400 11.961 41.557 8.934
353 86 5 0.5200 12.304 40.695 9.182
354 86 5 0.5200 11.016 41.494 8.782
355 87 4 -1.0400 13.588 18.009 14.917
356 87 5 0.5200 13.347 18.494 15.71
357 87 5 0.5200 14.501 18.198 14.692
358 88 4 -1.0400 2.481 0.872 0.315
359 88 5 0.5200 2.093 0.002 0.202
360 88 5 0.5200 3.388 0.862 0
361 89 4 -1.0400 4.58 35.462 22.779
362 89 5 0.5200 3.649 35.649 22.92
363 89 5 0.5200 4.799 34.612 23.168
364 90 4 -1.0400 10.663 17.642 14.802
365 90 5 0.5200 10.424 18.175 14.041
366 90 5 0.5200 10.008 16.952 14.929
367 91 4 -1.0400 17.524 5.858 13.836
368 91 5 0.5200 16.991 5.136 13.495
369 91 5 0.5200 18.397 5.532 14.064
370 92 4 -1.0400 0.043 21.764 3.769
371 92 5 0.5200 0.796 21.698 3.177
372 92 5 0.5200 0.086 22.594 4.25
373 93 4 -1.0400 11.728 17.289 4.9
374 93 5 0.5200 11.661 18.033 4.297
375 93 5 0.5200 11.322 17.519 5.739
376 94 4 -1.0400 22.061 36.174 16.892
377 94 5 0.5200 22.678 36.474 17.564
378 94 5 0.5200 22.267 35.269 16.649
379 95 4 -1.0400 18.382 12.145 16.047
380 95 5 0.5200 18.152 11.226 16.202
381 95 5 0.5200 19.311 12.208 15.817
382 96 4 -1.0400 6.635 10.909 13.112
383 96 5 0.5200 6.178 11.729 13.31
384 96 5 0.5200 7.541 11.101 12.856
385 97 4 -1.0400 8.16 22.247 4.959
386 97 5 0.5200 7.74 22.876 4.367
387 97 5 0.5200 7.915 21.354 4.703
388 98 4 -1.0400 22.527 17.383 15.58
389 98 5 0.5200 22.375 18.001 16.3
390 98 5 0.5200 23.464 17.184 15.522
391 99 4 -1.0400 5.681 4.43 2.249
392 99 5 0.5200 5.975 4.847 1.435
393 99 5 0.5200 5.141 5.046 2.748
394 100 4 -1.0400 2.24 10.489 12.898
395 100 5 0.5200 2.161 9.539 13.012
396 100 5 0.5200 1.385 10.901 13.042
397 101 4 -1.0400 9.771 15.184 9.302
398 101 5 0.5200 9.414 14.351 8.984
399 101 5 0.5200 10.727 15.121 9.36
400 102 4 -1.0400 5.568 1.023 19.072
401 102 5 0.5200 5.161 1.423 19.843
402 102 5 0.5200 5.043 1.221 18.293
403 103 4 -1.0400 0.011 34.729 13.914
404 103 5 0.5200 0.469 34.645 14.754
405 103 5 0.5200 0.64 34.967 13.229
406 104 4 -1.0400 9.63 12.973 13.151
407 104 5 0.5200 10.434 13.43 12.894
408 104 5 0.5200 8.925 13.612 13.28
409 105 4 -1.0400 22.38 13.238 3.602
410 105 5 0.5200 22.11 12.666 2.88
411 105 5 0.5200 23.329 13.377 3.564
412 106 4 -1.0400 12.841 13.986 6.009
413 106 5 0.5200 12.38 14.824 6.094
414 106 5 0.5200 13.782 14.146 5.91
415 107 4 -1.0400 6.08 31.265 16.644
416 107 5 0.5200 6.867 31.66 17.025
417 107 5 0.5200 6.29 30.39 16.31
418 108 4 -1.0400 11.956 16.663 8.385
419 108 5 0.5200 11.445 16.328 7.644
420 108 5 0.5200 11.407 17.243 8.916
421 109 4 -1.0400 15.116 43.1 10.496
422 109 5 0.5200 15.939 43.588 10.418
423 109 5 0.5200 15.262 42.184 10.249
424 110 4 -1.0400 14.023 17.356 6.766
425 110 5 0.5200 14.948 17.561 6.917
426 110 5 0.5200 13.847 16.452 7.038
427 111 4 -1.0400 15.267 5.239 6.996
428 111 5 0.5200 14.335 5.439 7.115
429 111 5 0.5200 15.62 5.771 6.279
430 112 4 -1.0400 2.073 43.602 19.419
431 112 5 0.5200 2.024 44.421 18.92
432 112 5 0.5200 1.417 43.615 20.119
433 113 4 -1.0400 22.095 36.755 4.849
434 113 5 0.5200 21.847 35.829 4.801
435 113 5 0.5200 22.976 36.831 5.221
436 114 4 -1.0400 1.888 24.068 18.873
437 114 5 0.5200 2.638 23.8 18.337
438 114 5 0.5200 2.04 24.951 19.217
439 115 4 -1.0400 9.79 15.818 19.663
440 115 5 0.5200 9.492 14.96 19.974
441 115 5 0.5200 9.314 16.509 20.13
442 116 4 -1.0400 22.65 29.371 9.809
443 116 5 0.5200 22.005 30.074 9.695
444 116 5 0.5200 23.535 29.732 9.722
445 117 4 -1.0400 7.071 17.645 21.524
446 117 5 0.5200 6.304 17.571 20.952
447 117 5 0.5200 7.405 18.545 21.497
448 118 4 -1.0400 17.104 35.088 6.398
449 118 5 0.5200 17.807 35.344 7
450 118 5 0.5200 16.362 35.689 6.498
451 119 4 -1.0400 21.607 21.731 19.064
452 119 5 0.5200 20.721 21.661 18.7
453 119 5 0.5200 21.599 21.453 19.982
454 120 4 -1.0400 20.444 3.403 11.339
455 120 5 0.5200 20.735 2.498 11.476
456 120 5 0.5200 21.204 3.959 11.154
457 121 4 -1.0400 12.488 33.62 13.445
458 121 5 0.5200 11.555 33.545 13.229
459 121 5 0.5200 12.847 32.746 13.617
460 122 4 -1.0400 2.381 8.641 20.119
461 122 5 0.5200 1.668 8.271 20.646
462 122 5 0.5200 2.158 9.54 19.867
463 123 4 -1.0400 10.717 41.361 17.853
464 123 5 0.5200 11.364 40.824 18.317
465 123 5 0.5200 11.17 42.01 17.311
466 124 4 -1.0400 0.758 8.958 16.488
467 124 5 0.5200 1.458 8.309 16.383
468 124 5 0.5200 1.143 9.815 16.684
469 125 4 -1.0400 10.22 5.315 15.725
470 125 5 0.5200 9.709 5.954 15.223
471 125 5 0.5200 11.14 5.586 15.748
472 126 4 -1.0400 4.511 40.564 4.903
473 126 5 0.5200 5.128 40.386 4.189
474 126 5 0.5200 4.266 41.492 4.89
475 127 4 -1.0400 13.242 32.273 15.974
476 127 5 0.5200 12.376 32.399 16.37
477 127 5 0.5200 13.616 33.127 15.746
478 128 4 -1.0400 15.825 1.356 11.959
479 128 5 0.5200 16.647 1.158 12.415
480 128 5 0.5200 15.977 1.358 11.011
481 129 4 -1.0400 2.765 36.692 0.635
482 129 5 0.5200 3.695 36.469 0.549
483 129 5 0.5200 2.253 36.18 0.005
484 130 4 -1.0400 16.442 24.994 13.607
485 130 5 0.5200 16.266 25.708 12.99
486 130 5 0.5200 16.397 24.154 13.145
487 131 4 -1.0400 22.309 35.896 13.101
488 131 5 0.5200 22.922 35.187 12.892
489 131 5 0.5200 21.749 35.629 13.834
490 132 4 -1.0400 7.375 32.296 0.578
491 132 5 0.5200 7.395 32.03 1.5
492 132 5 0.5200 7.877 33.106 0.467
493 133 4 -1.0400 16.703 11.633 5.001
494 133 5 0.5200 16.097 12.231 5.444
495 133 5 0.5200 16.217 11.088 4.378
496 134 4 -1.0400 7.103 11.768 6.096
497 134 5 0.5200 7.846 11.18 6.25
498 134 5 0.5200 7.424 12.666 5.982
499 135 4 -1.0400 4.255 30.77 0.699
500 135 5 0.5200 3.532 31.114 1.229
501 135 5 0.5200 4.943 30.432 1.276
502 136 4 -1.0400 13.866 4.874 17.277
503 136 5 0.5200 14.299 5.119 16.456
504 136 5 0.5200 13.102 5.438 17.416
505 137 4 -1.0400 4.47 18.508 20.939
506 137 5 0.5200 3.624 18.424 20.493
507 137 5 0.5200 4.323 18.679 21.872
508 138 4 -1.0400 23.768 6.562 21.454
509 138 5 0.5200 24.099 7.463 21.449
510 138 5 0.5200 23.025 6.498 22.058
511 139 4 -1.0400 20.227 10.379 1.096
512 139 5 0.5200 20.039 11.321 1.119
513 139 5 0.5200 19.954 9.978 1.924
514 140 4 -1.0400 20.697 7.129 23.67
515 140 5 0.5200 20.574 7.985 24.089
516 140 5 0.5200 21.561 6.781 23.901
517 141 4 -1.0400 5.754 2.44 5.327
518 141 5 0.5200 5.821 1.889 4.544
519 141 5 0.5200 6.554 2.351 5.85
520 142 4 -1.0400 8.226 39.073 8.348
521 142 5 0.5200 8.149 38.283 7.808
522 142 5 0.5200 8.672 39.76 7.848
523 143 4 -1.0400 14.692 18.753 4.176
524 143 5 0.5200 15.407 18.232 3.803
525 143 5 0.5200 13.895 18.219 4.217
526 144 4 -1.0400 12.926 22.673 21.59
527 144 5 0.5200 12.919 23.407 22.208
528 144 5 0.5200 13.414 22.923 20.802
529 145 4 -1.0400 15.531 41.144 0
530 145 5 0.5200 16.447 41.432 0.001
531 145 5 0.5200 15.167 41.233 0.883
532 146 4 -1.0400 21.341 6.073 19.224
533 146 5 0.5200 20.439 6.048 19.553
534 146 5 0.5200 21.572 6.975 18.993
535 147 4 -1.0400 19.046 26.251 12.209
536 147 5 0.5200 18.741 26.355 13.113
537 147 5 0.5200 18.638 25.474 11.821
538 148 4 -1.0400 14.991 10.917 22.391
539 148 5 0.5200 14.33 11.155 23.045
540 148 5 0.5200 14.816 11.39 21.574
541 149 4 -1.0400 16.413 27.458 8.117
542 149 5 0.5200 16.085 26.582 8.332
543 149 5 0.5200 15.674 28.035 7.908
544 150 4 -1.0400 5.14 42.074 12.773
545 150 5 0.5200 5.538 41.802 11.942
546 150 5 0.5200 5.754 42.635 13.253
547 151 4 -1.0400 21.593 17.255 4.804
548 151 5 0.5200 22.523 17.411 4.623
549 151 5 0.5200 21.365 16.355 4.561
550 152 4 -1.0400 22.951 12.099 18.82
551 152 5 0.5200 23.569 12.747 19.166
552 152 5 0.5200 22.08 12.258 19.191
553 153 4 -1.0400 8.704 14.372 2.081
554 153 5 0.5200 8.312 13.665 1.562
555 153 5 0.5200 9.591 14.55 1.761
556 154 4 -1.0400 11.172 30.281 3.399
557 154 5 0.5200 11.075 31.181 3.078
558 154 5 0.5200 10.306 29.919 3.602
559 155 4 -1.0400 10.184 13.619 5.107
560 155 5 0.5200 9.226 13.637 5.174
561 155 5 0.5200 10.494 14.446 4.732
562 156 4 -1.0400 8.935 40.341 1.58
563 156 5 0.5200 8.656 41.224 1.327
564 156 5 0.5200 8.713 39.722 0.88
565 157 4 -1.0400 7.121 1.216 9.148
566 157 5 0.5200 6.786 2.116 9.182
567 157 5 0.5200 7.971 1.174 9.593
568 158 4 -1.0400 22.598 0.366 19.346
569 158 5 0.5200 23.271 0.005 18.764
570 158 5 0.5200 22.052 0.987 18.858
571 159 4 -1.0400 13.274 26.453 9.819
572 159 5 0.5200 12.376 26.789 9.865
573 159 5 0.5200 13.478 25.972 10.625
574 160 4 -1.0400 3.633 12.789 6.119
575 160 5 0.5200 3.056 13.342 6.651
576 160 5 0.5200 3.598 13.077 5.204
577 161 4 -1.0400 19.449 23.636 2.41
578 161 5 0.5200 19.505 23.588 1.453
579 161 5 0.5200 18.866 22.944 2.732
580 162 4 -1.0400 10.74 34.22 15.376
581 162 5 0.5200 11.694 34.32 15.413
582 162 5 0.5200 10.477 33.461 15.902
583 163 4 -1.0400 8.89 30.957 16.269
584 163 5 0.5200 9.767 30.623 16.066
585 163 5 0.5200 8.867 31.906 16.125
586 164 4 -1.0400 24.947 20.021 4.485
587 164 5 0.5200 24.688 19.437 3.768
588 164 5 0.5200 24.323 19.936 5.209
589 165 4 -1.0400 1.148 22.014 16.982
590 165 5 0.5200 0.777 21.207 16.618
591 165 5 0.5200 0.512 22.727 16.894
592 166 4 -1.0400 16.031 11.329 24.526
593 166 5 0.5200 16.575 11.567 23.772
594 166 5 0.5200 15.77 12.124 24.996
595 167 4 -1.0400 11.859 20.241 13.384
596 167 5 0.5200 12.234 19.482 13.837
597 167 5 0.5200 11.042 19.984 12.952
598 168 4 -1.0400 5.384 19.78 0.263
599 168 5 0.5200 5.723 18.92 0
600 168 5 0.5200 6.116 20.351 0.507
601 169 4 -1.0400 17.484 44.77 12.818
602 169 5 0.5200 17.356 44.248 13.613
603 169 5 0.5200 16.631 45 12.444
604 170 4 -1.0400 18.942 25.232 22.859
605 170 5 0.5200 19.101 25.84 22.133
606 170 5 0.5200 19.524 25.447 23.591
607 171 4 -1.0400 2.633 25.856 15.933
608 171 5 0.5200 2.264 24.97 15.952
609 171 5 0.5200 2.192 26.4 16.59
610 172 4 -1.0400 18.971 12.14 24.956
611 172 5 0.5200 18.219 12.736 25
612 172 5 0.5200 18.663 11.232 24.999
613 173 4 -1.0400 19.143 16.89 6.677
614 173 5 0.5200 18.305 16.486 6.914
615 173 5 0.5200 19.731 16.221 6.32
616 174 4 -1.0400 19.839 3.825 22.691
617 174 5 0.5200 19.497 4.721 22.704
618 174 5 0.5200 20.746 3.833 22.378
619 175 4 -1.0400 13.228 21.087 15.985
620 175 5 0.5200 12.47 20.502 15.91
621 175 5 0.5200 14.036 20.568 15.959
622 176 4 -1.0400 14.081 7.761 20.964
623 176 5 0.5200 13.71 6.971 20.565
624 176 5 0.5200 15.039 7.731 20.903
625 177 4 -1.0400 11.11 32.042 8.075
626 177 5 0.5200 12.051 31.875 7.99
627 177 5 0.5200 10.639 31.206 8.12
628 178 4 -1.0400 18.423 34.588 12.382
629 178 5 0.5200 18.034 35.219 11.773
630 178 5 0.5200 17.732 34.193 12.919
631 179 4 -1.0400 23.296 17.005 18.54
632 179 5 0.5200 23.685 17.732 18.047
633 179 5 0.5200 22.829 16.422 17.936
634 180 4 -1.0400 21.587 28.434 5.215
635 180 5 0.5200 21.087 28.792 5.953
636 180 5 0.5200 21.226 27.579 4.969
637 181 4 -1.0400 11.605 6.943 13.594
638 181 5 0.5200 11.925 6.187 13.097
639 181 5 0.5200 12.108 7.029 14.406
640 182 4 -1.0400 22.826 20.424 14.924
641 182 5 0.5200 21.985 20.079 15.234
642 182 5 0.5200 23.045 21.221 15.412
643 183 4 -1.0400 5.044 14.759 7.942
644 183 5 0.5200 4.531 13.976 8.155
645 183 5 0.5200 4.449 15.484 7.736
646 184 4 -1.0400 9.301 19.368 16.872
647 184 5 0.5200 8.804 19.36 16.05
648 184 5 0.5200 10.219 19.151 16.694
649 185 4 -1.0400 12.606 38.831 19.799
650 185 5 0.5200 13.552 38.785 19.641
651 185 5 0.5200 12.167 38.13 19.313
652 186 4 -1.0400 18.092 23.591 8.061
653 186 5 0.5200 18.695 24.192 8.504
654 186 5 0.5200 17.337 23.418 8.628
655 187 4 -1.0400 8.543 10.404 3.938
656 187 5 0.5200 7.795 9.87 3.661
657 187 5 0.5200 9.262 9.829 4.214
658 188 4 -1.0400 17.129 5.166 19.048
659 188 5 0.5200 18.051 5.276 18.802
660 188 5 0.5200 16.749 6.023 19.254
661 189 4 -1.0400 12.872 17.867 23.956
662 189 5 0.5200 13.757 18.174 23.745
663 189 5 0.5200 12.287 18.621 24.059
664 190 4 -1.0400 1.958 34.046 3.821
665 190 5 0.5200 2.002 33.278 4.396
666 190 5 0.5200 2.385 33.846 2.985
667 191 4 -1.0400 24.985 3.637 11.896
668 191 5 0.5200 24.088 3.961 12
669 191 5 0.5200 24.965 2.745 11.543
670 192 4 -1.0400 4.326 32.025 11.14
671 192 5 0.5200 4.994 31.611 11.693
672 192 5 0.5200 4.52 31.848 10.217
673 193 4 -1.0400 19.578 8.66 18.303
674 193 5 0.5200 19.119 9.5 18.37
675 193 5 0.5200 20.525 8.806 18.369
676 194 4 -1.0400 16.471 13.603 18.385
677 194 5 0.5200 15.935 13.065 17.798
678 194 5 0.5200 16.477 13.213 19.262
679 195 4 -1.0400 23.467 26.769 6.777
680 195 5 0.5200 22.852 26.058 6.583
681 195 5 0.5200 24.1 26.474 7.436
682 196 4 -1.0400 16.586 19.86 18.849
683 196 5 0.5200 16.983 20.517 18.272
684 196 5 0.5200 15.939 20.283 19.419
685 197 4 -1.0400 21.997 24.031 3.72
686 197 5 0.5200 22.196 23.277 3.159
687 197 5 0.5200 21.474 23.742 4.471
688 198 4 -1.0400 4.466 5.58 9.275
689 198 5 0.5200 3.575 5.651 9.624
690 198 5 0.5200 4.701 4.654 9.184
691 199 4 -1.0400 3.836 38.437 1.924
692 199 5 0.5200 4.408 38.619 1.174
693 199 5 0.5200 3.834 39.193 2.515
694 200 4 -1.0400 22.703 42.764 7.447
695 200 5 0.5200 23.4 42.25 7.033
696 200 5 0.5200 21.913 42.223 7.53
697 201 4 -1.0400 11.332 2.17 24.617
698 201 5 0.5200 11.28 1.22 24.49
699 201 5 0.5200 12.185 2.396 24.995
700 202 4 -1.0400 18.814 27.931 6.165
701 202 5 0.5200 19.01 27.799 5.235
702 202 5 0.5200 18.027 28.474 6.252
703 203 4 -1.0400 7.679 26.127 3.693
704 203 5 0.5200 7.184 26.378 2.91
705 203 5 0.5200 7.427 26.693 4.427
706 204 4 -1.0400 4.067 33.245 8.531
707 204 5 0.5200 3.183 33.525 8.78
708 204 5 0.5200 4.598 34.015 8.313
709 205 4 -1.0400 19.202 28.962 21.886
710 205 5 0.5200 19.776 28.208 22.044
711 205 5 0.5200 18.368 28.658 21.52
712 206 4 -1.0400 2.868 39.793 24.25
713 206 5 0.5200 2.239 39.075 24.35
714 206 5 0.5200 2.412 40.633 24.341
715 207 4 -1.0400 23.566 43.515 24.344
716 207 5 0.5200 22.917 43.245 24.998
717 207 5 0.5200 23.851 44.413 24.527
718 208 4 -1.0400 20.665 18.69 14.044
719 208 5 0.5200 20.558 18.297 14.913
720 208 5 0.5200 19.898 18.486 13.504
721 209 4 -1.0400 14.367 16.04 3.372
722 209 5 0.5200 13.878 16.547 2.721
723 209 5 0.5200 13.756 15.658 4.007
724 210 4 -1.0400 3.684 6.07 19.55
725 210 5 0.5200 3.679 6.842 18.979
726 210 5 0.5200 2.802 5.924 19.899
727 211 4 -1.0400 2.139 29.566 8.126
728 211 5 0.5200 2.923 30.087 8.317
729 211 5 0.5200 2.313 28.643 8.322
730 212 4 -1.0400 6.497 40.861 15.026
731 212 5 0.5200 6.774 39.943 14.985
732 212 5 0.5200 6.141 41.05 15.897
733 213 4 -1.0400 2.045 2.035 16.894
734 213 5 0.5200 2.925 1.664 16.988
735 213 5 0.5200 2.062 2.964 17.134
736 214 4 -1.0400 22.431 14.487 5.413
737 214 5 0.5200 22.025 14.969 6.137
738 214 5 0.5200 23.082 15.045 4.982
739 215 4 -1.0400 20.137 31.397 5.381
740 215 5 0.5200 19.257 31.446 5.001
741 215 5 0.5200 20.639 32.175 5.126
742 216 4 -1.0400 11.218 37.657 24.87
743 216 5 0.5200 11.242 37.003 24.167
744 216 5 0.5200 11.672 38.453 24.582
745 217 4 -1.0400 24.998 31.057 6.546
746 217 5 0.5200 24.366 31.766 6.401
747 217 5 0.5200 24.531 30.221 6.611
748 218 4 -1.0400 19.714 10.358 4.127
749 218 5 0.5200 20.507 10.166 4.632
750 218 5 0.5200 19.258 11.107 4.519
751 219 4 -1.0400 5.114 42.23 24.262
752 219 5 0.5200 4.364 41.74 24.608
753 219 5 0.5200 4.852 43.139 24.094
754 220 4 -1.0400 5.091 34.685 12.056
755 220 5 0.5200 4.352 34.105 11.862
756 220 5 0.5200 5.891 34.163 12.154
757 221 4 -1.0400 17.032 1.378 8.93
758 221 5 0.5200 16.312 1.658 8.36
759 221 5 0.5200 16.905 0.46 9.18
760 222 4 -1.0400 9.059 9.66 13.976
761 222 5 0.5200 9.542 8.838 14.092
762 222 5 0.5200 8.165 9.556 14.309
763 223 4 -1.0400 18.054 10.768 8.604
764 223 5 0.5200 18.235 10.04 8.004
765 223 5 0.5200 18.875 11.065 9.004
766 224 4 -1.0400 4.136 29.528 15.819
767 224 5 0.5200 4.216 30.453 15.574
768 224 5 0.5200 3.22 29.331 16.03
769 225 4 -1.0400 5.944 22.433 22.503
770 225 5 0.5200 6.125 22.008 21.661
771 225 5 0.5200 5.292 21.921 22.987
772 226 4 -1.0400 20.168 43.318 11.54
773 226 5 0.5200 20.861 43.954 11.348
774 226 5 0.5200 19.501 43.729 12.095
775 227 4 -1.0400 16.784 9.027 17.913
776 227 5 0.5200 15.994 8.873 17.39
777 227 5 0.5200 16.616 8.783 18.826
778 228 4 -1.0400 24.775 4.986 18.709
779 228 5 0.5200 24.756 5.88 18.361
780 228 5 0.5200 23.936 4.555 18.53
781 229 4 -1.0400 19.998 23.624 6.22
782 229 5 0.5200 19.736 22.885 6.774
783 229 5 0.5200 20.63 24.17 6.693
784 230 4 -1.0400 17.699 10.682 19.735
785 230 5 0.5200 16.892 11.151 19.959
786 230 5 0.5200 18.359 11.308 19.429
787 231 4 -1.0400 12.114 15.955 0.956
788 231 5 0.5200 11.623 16.05 1.776
789 231 5 0.5200 11.785 15.194 0.472
790 232 4 -1.0400 12.198 19.455 19.194
791 232 5 0.5200 12.08 19.514 18.243
792 232 5 0.5200 12.05 18.551 19.48
793 233 4 -1.0400 14.698 41.289 21.824
794 233 5 0.5200 13.93 41.731 22.195
795 233 5 0.5200 14.502 40.358 21.699
796 234 4 -1.0400 18.763 19.875 7.414
797 234 5 0.5200 19.278 20.303 6.726
798 234 5 0.5200 17.983 19.471 7.026
799 235 4 -1.0400 0.787 28.701 23.383
800 235 5 0.5200 0.686 28.654 24.337
801 235 5 0.5200 0 28.349 22.96
802 236 4 -1.0400 16.103 30.832 1.027
803 236 5 0.5200 16.739 30.269 0.578
804 236 5 0.5200 16.542 31.63 1.331
805 237 4 -1.0400 3.602 42.825 11.181
806 237 5 0.5200 3.156 42.53 10.384
807 237 5 0.5200 3.152 43.596 11.534
808 238 4 -1.0400 0.939 24.993 11.16
809 238 5 0.5200 0.217 25.53 11.494
810 238 5 0.5200 0.771 24.765 10.243
811 239 4 -1.0400 21.071 33.353 13.606
812 239 5 0.5200 20.522 32.666 13.222
813 239 5 0.5200 21.862 32.959 13.981
814 240 4 -1.0400 4.102 34.272 14.095
815 240 5 0.5200 3.791 35.149 13.86
816 240 5 0.5200 3.353 33.719 14.33
817 241 4 -1.0400 13.644 12.741 8.272
818 241 5 0.5200 13.611 11.906 7.799
819 241 5 0.5200 14.336 13.293 7.901
820 242 4 -1.0400 4.879 43.585 15.883
821 242 5 0.5200 5.291 43.114 16.612
822 242 5 0.5200 5.306 44.437 15.771
823 243 4 -1.0400 9.133 24.455 21.002
824 243 5 0.5200 8.355 24.436 21.564
825 243 5 0.5200 8.988 25.064 20.275
826 244 4 -1.0400 22.359 41.606 18.387
827 244 5 0.5200 22.348 42.445 17.92
828 244 5 0.5200 23.2 41.502 18.838
829 245 4 -1.0400 5.52 28.711 3.959
830 245 5 0.5200 5.94 29.088 3.182
831 245 5 0.5200 5.558 27.753 3.911
832 246 4 -1.0400 3.307 19.927 17.177
833 246 5 0.5200 4.082 20.099 16.637
834 246 5 0.5200 3.141 20.679 17.749
835 247 4 -1.0400 13.249 20.804 2.71
836 247 5 0.5200 13.312 19.858 2.862
837 247 5 0.5200 14.131 21.176 2.635
838 248 4 -1.0400 7.853 15.023 10.625
839 248 5 0.5200 7.855 15.881 11.054
840 248 5 0.5200 7.088 14.955 10.049
841 249 4 -1.0400 13.189 18.527 9.516
842 249 5 0.5200 13.925 17.974 9.242
843 249 5 0.5200 13.512 19.404 9.733
844 250 4 -1.0400 8.932 11.294 24.63
845 250 5 0.5200 7.975 11.221 24.607
846 250 5 0.5200 9.179 12.196 24.845
847 251 4 -1.0400 16.925 15.042 22.558
848 251 5 0.5200 16.114 14.544 22.432
849 251 5 0.5200 17.624 14.45 22.845
850 252 4 -1.0400 18.788 19.436 16.73
851 252 5 0.5200 18.848 20.391 16.643
852 252 5 0.5200 18.571 19.051 15.878
853 253 4 -1.0400 23.256 10.116 15.901
854 253 5 0.5200 23.944 10.642 15.487
855 253 5 0.5200 22.428 10.602 15.885
856 254 4 -1.0400 10.841 23.881 24.064
857 254 5 0.5200 10.936 24.818 24.25
858 254 5 0.5200 9.929 23.618 24.203
859 255 4 -1.0400 11.278 28.573 10.692
860 255 5 0.5200 10.445 28.205 10.995
861 255 5 0.5200 11.237 28.721 9.744
862 256 4 -1.0400 3.023 2.583 14.225
863 256 5 0.5200 2.199 3.076 14.237
864 256 5 0.5200 3.721 3.116 14.613
865 257 4 -1.0400 10.956 39.34 16.574
866 257 5 0.5200 10.03 39.576 16.663
867 257 5 0.5200 11.028 38.48 16.153
868 258 4 -1.0400 21.972 27.817 14.175
869 258 5 0.5200 21.333 27.625 14.866
870 258 5 0.5200 21.731 28.635 13.734
871 259 4 -1.0400 4.348 31.04 23.648
872 259 5 0.5200 5.103 31.467 24.06
873 259 5 0.5200 4.094 30.272 24.164
874 260 4 -1.0400 16.243 30.961 14.799
875 260 5 0.5200 15.803 30.332 15.377
876 260 5 0.5200 15.875 31.836 14.938
877 261 4 -1.0400 10.071 37.002 10.151
878 261 5 0.5200 10.003 37.216 9.217
879 261 5 0.5200 9.652 36.155 10.316
880 262 4 -1.0400 4.591 26.072 2.873
881 262 5 0.5200 4.398 25.392 2.224
882 262 5 0.5200 4.911 25.663 3.681
883 263 4 -1.0400 22.521 37.844 14.31
884 263 5 0.5200 21.952 38.574 14.564
885 263 5 0.5200 22.742 37.325 15.087
886 264 4 -1.0400 5.679 4.615 18.449
887 264 5 0.5200 4.84 4.369 18.052
888 264 5 0.5200 6.3 3.889 18.362
889 265 4 -1.0400 18.915 9.224 21.038
890 265 5 0.5200 18.327 9.564 21.716
891 265 5 0.5200 19.546 9.904 20.791
892 266 4 -1.0400 12.63 27.096 22.976
893 266 5 0.5200 11.989 27 22.269
894 266 5 0.5200 12.572 26.341 23.566
895 267 4 -1.0400 12.589 21.033 10.941
896 267 5 0.5200 12.695 21.746 11.576
897 267 5 0.5200 11.687 20.705 10.976
898 268 4 -1.0400 20.267 1.728 17.806
899 268 5 0.5200 20.125 0.779 17.77
900 268 5 0.5200 20.662 2.024 16.983
901 269 4 -1.0400 16.662 2.427 3.435
902 269 5 0.5200 16.727 3.228 3.961
903 269 5 0.5200 17.483 1.934 3.5
904 270 4 -1.0400 6.804 18.902 17.612
905 270 5 0.5200 6.348 19.388 16.92
906 270 5 0.5200 6.248 18.863 18.394
907 271 4 -1.0400 21.425 15.731 1.749
908 271 5 0.5200 21.909 15.044 2.213
909 271 5 0.5200 21.162 16.414 2.371
910 272 4 -1.0400 4.434 18.971 4.45
911 272 5 0.5200 4.143 19.414 5.25
912 272 5 0.5200 3.668 18.708 3.934
913 273 4 -1.0400 14.519 25.128 2.793
914 273 5 0.5200 13.662 25.248 2.376
915 273 5 0.5200 14.699 24.19 2.891
916 274 4 -1.0400 10.007 2.968 20.049
917 274 5 0.5200 9.908 2.243 19.427
918 274 5 0.5200 10.803 3.463 19.84
919 275 4 -1.0400 13.017 11.896 4.846
920 275 5 0.5200 12.668 11.099 4.44
921 275 5 0.5200 13.975 11.838 4.892
922 276 4 -1.0400 15.974 40.387 15.879
923 276 5 0.5200 15.772 41.32 15.783
924 276 5 0.5200 16.644 40.272 16.558
925 277 4 -1.0400 16.292 6.142 22.826
926 277 5 0.5200 15.67 6.874 22.829
927 277 5 0.5200 16.37 5.786 23.714
928 278 4 -1.0400 15.657 40.843 6.613
929 278 5 0.5200 15.108 40.186 7.047
930 278 5 0.5200 15.428 40.888 5.681
931 279 4 -1.0400 14.665 37.194 17.915
932 279 5 0.5200 15.421 36.773 18.333
933 279 5 0.5200 14.562 36.854 17.024
934 280 4 -1.0400 23.872 44.588 22.033
935 280 5 0.5200 23.898 43.628 22.05
936 280 5 0.5200 23.065 44.878 21.603
937 281 4 -1.0400 6.166 38.778 11.966
938 281 5 0.5200 6.499 37.965 11.578
939 281 5 0.5200 6.787 39.49 11.799
940 282 4 -1.0400 17.647 12.309 1.436
941 282 5 0.5200 18.154 12.674 2.166
942 282 5 0.5200 17.815 11.366 1.37
943 283 4 -1.0400 16.73 3.17 7.119
944 283 5 0.5200 16.859 4.088 7.37
945 283 5 0.5200 17.579 2.721 7.102
946 284 4 -1.0400 23.971 3.277 22.777
947 284 5 0.5200 23.936 2.94 23.675
948 284 5 0.5200 24.881 3.47 22.542
949 285 4 -1.0400 10.429 21.939 2.738
950 285 5 0.5200 9.76 21.491 3.261
951 285 5 0.5200 11.109 21.311 2.482
952 286 4 -1.0400 24.999 38.666 23.713
953 286 5 0.5200 24.928 39.497 24.188
954 286 5 0.5200 24.426 38.013 24.122
955 287 4 -1.0400 24.315 37.468 13.093
956 287 5 0.5200 24.992 37.626 13.757
957 287 5 0.5200 24.732 37.256 12.255
958 288 4 -1.0400 4.601 7.772 10.427
959 288 5 0.5200 3.797 7.797 10.95
960 288 5 0.5200 4.47 8.263 9.613
961 289 4 -1.0400 5.189 17.069 6.383
962 289 5 0.5200 4.345 17.423 6.676
963 289 5 0.5200 5.755 17.788 6.094
964 290 4 -1.0400 13.514 23.556 5.765
965 290 5 0.5200 14.036 23.648 4.965
966 290 5 0.5200 12.679 23.131 5.556
967 291 4 -1.0400 2.554 22.067 10.697
968 291 5 0.5200 2.033 22.764 10.29
969 291 5 0.5200 3.274 22.456 11.198
970 292 4 -1.0400 20.282 36.747 6.095
971 292 5 0.5200 20.664 36.069 6.657
972 292 5 0.5200 19.327 36.74 6.19
973 293 4 -1.0400 6.977 6.288 19.708
974 293 5 0.5200 6.966 6.514 18.775
975 293 5 0.5200 6.414 6.898 20.191
976 294 4 -1.0400 24.705 15.374 19.818
977 294 5 0.5200 24.972 15.635 18.934
978 294 5 0.5200 23.786 15.096 19.806
979 295 4 -1.0400 24.308 39.583 12.221
980 295 5 0.5200 23.448 39.95 12.005
981 295 5 0.5200 24.988 40.051 11.73
982 296 4 -1.0400 19.766 14.502 3.698
983 296 5 0.5200 20.144 14.443 4.579
984 296 5 0.5200 20.004 13.721 3.194
985 297 4 -1.0400 15.686 7.928 1.491
986 297 5 0.5200 16.065 8.3 2.291
987 297 5 0.5200 14.73 7.997 1.527
988 298 4 -1.0400 2.171 39.085 6.911
989 298 5 0.5200 1.386 39.54 7.226
990 298 5 0.5200 2.404 38.385 7.525
991 299 4 -1.0400 21.431 21.847 5.588
992 299 5 0.5200 21.509 21.365 4.761
993 299 5 0.5200 21.377 21.224 6.317
994 300 4 -1.0400 6.045 11.942 3.889
995 300 5 0.5200 5.151 12.219 3.673
996 300 5 0.5200 6.02 11.079 4.309
997 301 4 -1.0400 7.997 35.668 8.857
998 301 5 0.5200 7.589 36.523 9.011
999 301 5 0.5200 7.771 35.071 9.574
1000 302 4 -1.0400 19.673 35.702 20.467
1001 302 5 0.5200 18.784 35.951 20.201
1002 302 5 0.5200 19.638 34.887 20.973
1003 303 4 -1.0400 22.705 11.146 0.682
1004 303 5 0.5200 22.622 10.32 1.166
1005 303 5 0.5200 21.976 11.228 0.062
1006 304 4 -1.0400 8.9 9.754 10.292
1007 304 5 0.5200 9.379 10.099 9.535
1008 304 5 0.5200 7.971 9.987 10.217
1009 305 4 -1.0400 21.635 12.84 10.9
1010 305 5 0.5200 22.417 12.807 10.343
1011 305 5 0.5200 21.143 12.021 10.809
1012 306 4 -1.0400 16.754 17.823 5.552
1013 306 5 0.5200 16.887 17.069 4.972
1014 306 5 0.5200 17.166 18.6 5.167
1015 307 4 -1.0400 15.417 20.897 6.125
1016 307 5 0.5200 14.977 20.183 6.593
1017 307 5 0.5200 14.765 21.536 5.829
1018 308 4 -1.0400 17.659 5.319 0.831
1019 308 5 0.5200 18.004 5.981 0.226
1020 308 5 0.5200 17.896 4.444 0.516
1021 309 4 -1.0400 8.987 27.161 9.091
1022 309 5 0.5200 9.117 28.1 8.941
1023 309 5 0.5200 9.839 26.723 9.139
1024 310 4 -1.0400 24.26 22.489 22.144
1025 310 5 0.5200 24.826 23.257 22.03
1026 310 5 0.5200 23.79 22.558 22.978
1027 311 4 -1.0400 14.064 10.852 2.634
1028 311 5 0.5200 14.238 10.052 3.136
1029 311 5 0.5200 13.189 10.8 2.242
1030 312 4 -1.0400 5.098 34.733 3.778
1031 312 5 0.5200 5.572 34.724 4.613
1032 312 5 0.5200 5.489 34.09 3.181
1033 313 4 -1.0400 5.575 20.786 8.338
1034 313 5 0.5200 6.168 20.904 9.083
1035 313 5 0.5200 5.099 19.958 8.435
1036 314 4 -1.0400 5.714 6.804 23.988
1037 314 5 0.5200 5.138 6.179 24.433
1038 314 5 0.5200 5.255 7.183 23.235
1039 315 4 -1.0400 12.563 13.085 2.465
1040 315 5 0.5200 13.06 13.877 2.687
1041 315 5 0.5200 12.274 13.135 1.551
1042 316 4 -1.0400 8.337 4.799 18.123
1043 316 5 0.5200 8.569 4.091 18.728
1044 316 5 0.5200 9.106 5.042 17.603
1045 317 4 -1.0400 14.932 10.602 18.826
1046 317 5 0.5200 14.479 10.007 19.428
1047 317 5 0.5200 14.302 11.227 18.459
1048 318 4 -1.0400 9.554 24.823 17.616
1049 318 5 0.5200 9.488 25.757 17.829
1050 318 5 0.5200 10.472 24.597 17.446
1051 319 4 -1.0400 6.966 24.876 11.932
1052 319 5 0.5200 7.869 25.024 12.224
1053 319 5 0.5200 6.78 25.432 11.172
1054 320 4 -1.0400 13.416 1.557 21.574
1055 320 5 0.5200 12.734 1.591 22.249
1056 320 5 0.5200 13.013 1.636 20.707
1057 321 4 -1.0400 17.39 43.593 21.614
1058 321 5 0.5200 18.012 43.677 20.888
1059 321 5 0.5200 16.981 44.445 21.785
1060 322 4 -1.0400 9.33 1.647 22.378
1061 322 5 0.5200 10.278 1.603 22.523
1062 322 5 0.5200 9.068 2.561 22.249
1063 323 4 -1.0400 18.366 40.623 8.391
1064 323 5 0.5200 19.268 40.298 8.442
1065 323 5 0.5200 17.755 39.891 8.499
1066 324 4 -1.0400 8.103 2.254 2.699
1067 324 5 0.5200 8.399 3.133 2.945
1068 324 5 0.5200 8.863 1.708 2.486
1069 325 4 -1.0400 16.69 2.088 24.024
1070 325 5 0.5200 16.429 1.783 24.896
1071 325 5 0.5200 15.924 2.091 23.445
1072 326 4 -1.0400 16.935 43.147 7.319
1073 326 5 0.5200 17.767 43.616 7.414
1074 326 5 0.5200 17.044 42.24 7.615
1075 327 4 -1.0400 4.152 5.284 22.108
1076 327 5 0.5200 3.638 6.086 21.995
1077 327 5 0.5200 3.601 4.603 22.502
1078 328 4 -1.0400 16.485 30.981 20.01
1079 328 5 0.5200 15.936 30.809 20.779
1080 328 5 0.5200 17.318 30.512 20.099
1081 329 4 -1.0400 23.734 40.829 14.004
1082 329 5 0.5200 24.301 40.226 14.491
1083 329 5 0.5200 22.933 40.991 14.507
1084 330 4 -1.0400 9.045 21.571 12.379
1085 330 5 0.5200 9.101 20.677 12.035
1086 330 5 0.5200 9.911 21.853 12.682
1087 331 4 -1.0400 18.915 42.044 3.539
1088 331 5 0.5200 18.066 41.918 3.97
1089 331 5 0.5200 19.022 42.969 3.307
1090 332 4 -1.0400 8.4 41.154 12.993
1091 332 5 0.5200 7.442 41.227 12.987
1092 332 5 0.5200 8.697 40.921 13.876
1093 333 4 -1.0400 1.065 6.572 23.502
1094 333 5 0.5200 1.07 6.718 22.553
1095 333 5 0.5200 1.538 5.761 23.703
1096 334 4 -1.0400 13.941 34.538 10.614
1097 334 5 0.5200 14.446 34.98 9.928
1098 334 5 0.5200 13.106 34.233 10.251
1099 335 4 -1.0400 20.665 23.209 14.445
1100 335 5 0.5200 20.612 24.166 14.395
1101 335 5 0.5200 20.361 22.915 15.306
1102 336 4 -1.0400 16.622 40.48 23.302
1103 336 5 0.5200 16.175 40.578 24.146
1104 336 5 0.5200 16.578 39.563 23.021
1105 337 4 -1.0400 13.448 7.791 17.391
1106 337 5 0.5200 13.699 8.433 18.06
1107 337 5 0.5200 14.238 7.43 16.982
1108 338 4 -1.0400 23.077 34.835 19.271
1109 338 5 0.5200 23.244 34.397 20.108
1110 338 5 0.5200 23.904 35.168 18.913
1111 339 4 -1.0400 0.433 33.363 23.865
1112 339 5 0.5200 0.267 32.729 23.163
1113 339 5 0.5200 0.849 32.918 24.607
1114 340 4 -1.0400 6.157 0.604 23.374
1115 340 5 0.5200 6.45 1.465 23.68
1116 340 5 0.5200 6.92 0.049 23.199
1117 341 4 -1.0400 15.836 8.335 6.53
1118 341 5 0.5200 16.477 7.929 5.941
1119 341 5 0.5200 16.084 9.247 6.694
1120 342 4 -1.0400 23.002 22.542 12.382
1121 342 5 0.5200 22.799 23.388 12.787
1122 342 5 0.5200 23.915 22.31 12.567
1123 343 4 -1.0400 24.045 33.52 5.112
1124 343 5 0.5200 24.042 33.276 4.183
1125 343 5 0.5200 23.141 33.627 5.418
1126 344 4 -1.0400 10.706 42.278 11.686
1127 344 5 0.5200 9.806 42.543 11.484
1128 344 5 0.5200 10.733 41.332 11.847
1129 345 4 -1.0400 9.416 15.977 6.226
1130 345 5 0.5200 9.248 16.252 5.321
1131 345 5 0.5200 8.961 16.569 6.83
1132 346 4 -1.0400 19.928 35.928 24.294
1133 346 5 0.5200 19.201 36.213 24.853
1134 346 5 0.5200 20.449 36.69 24.032
1135 347 4 -1.0400 24.446 21.706 19.036
1136 347 5 0.5200 24.158 20.803 19.191
1137 347 5 0.5200 23.726 22.31 19.231
1138 348 4 -1.0400 4.437 8.991 14.579
1139 348 5 0.5200 4.695 9.884 14.819
1140 348 5 0.5200 5.223 8.453 14.455
1141 349 4 -1.0400 17.637 27.445 15.277
1142 349 5 0.5200 17.385 28.366 15.172
1143 349 5 0.5200 16.857 26.919 15.469
1144 350 4 -1.0400 18.425 21.124 4.649
1145 350 5 0.5200 19.21 21.02 4.106
1146 350 5 0.5200 18.455 21.973 5.096
1147 351 4 -1.0400 19.407 2.24 3.954
1148 351 5 0.5200 20.045 2.457 4.638
1149 351 5 0.5200 19.856 2.164 3.109
1150 352 4 -1.0400 5.418 18.313 2.444
1151 352 5 0.5200 5.15 19.233 2.381
1152 352 5 0.5200 6.366 18.245 2.311
1153 353 4 -1.0400 15.122 5.198 0.855
1154 353 5 0.5200 14.746 5.797 1.504
1155 353 5 0.5200 15.515 4.445 1.304
1156 354 4 -1.0400 15.61 37.372 1.657
1157 354 5 0.5200 15.529 36.814 0.88
1158 354 5 0.5200 15.644 38.293 1.389
1159 355 4 -1.0400 24.57 13.451 8.891
1160 355 5 0.5200 23.669 13.334 8.579
1161 355 5 0.5200 24.817 12.705 9.442
1162 356 4 -1.0400 15.997 14.526 5.132
1163 356 5 0.5200 16.151 15.153 5.843
1164 356 5 0.5200 16.292 14.907 4.301
1165 357 4 -1.0400 6.124 26.56 18.996
1166 357 5 0.5200 5.853 26.155 18.169
1167 357 5 0.5200 5.767 27.45 19.048
1168 358 4 -1.0400 7.645 14.662 25
1169 358 5 0.5200 6.811 15.079 24.77
1170 358 5 0.5200 7.779 13.889 24.447
1171 359 4 -1.0400 15.211 32.418 11.361
1172 359 5 0.5200 14.318 32.068 11.39
1173 359 5 0.5200 15.741 31.896 10.754
1174 360 4 -1.0400 12.934 30.123 9.789
1175 360 5 0.5200 12.831 30.664 10.576
1176 360 5 0.5200 13.868 29.978 9.62
1177 361 4 -1.0400 18.924 33.673 5.034
1178 361 5 0.5200 19.739 34.181 5.026
1179 361 5 0.5200 18.363 33.958 4.308
1180 362 4 -1.0400 12.498 8.663 3.65
1181 362 5 0.5200 12.757 7.784 3.938
1182 362 5 0.5200 11.541 8.739 3.674
1183 363 4 -1.0400 20.502 25.864 9.413
1184 363 5 0.5200 20.652 24.947 9.171
1185 363 5 0.5200 21.119 26.119 10.102
1186 364 4 -1.0400 21.173 17.039 19.73
1187 364 5 0.5200 20.669 16.223 19.734
1188 364 5 0.5200 21.901 16.969 20.352
1189 365 4 -1.0400 24.269 24.551 5.211
1190 365 5 0.5200 24.973 24.859 4.635
1191 365 5 0.5200 24.626 23.928 5.847
1192 366 4 -1.0400 10.15 22.527 16.077
1193 366 5 0.5200 9.456 21.869 16.164
1194 366 5 0.5200 10.861 22.324 16.689
1195 367 4 -1.0400 6.991 32.329 9.478
1196 367 5 0.5200 7.825 32.108 9.899
1197 367 5 0.5200 6.499 31.524 9.298
1198 368 4 -1.0400 23.507 10.46 22.238
1199 368 5 0.5200 24.287 10.885 22.602
1200 368 5 0.5200 23.735 9.578 21.933
1201 369 4 -1.0400 9.825 6.639 0.075
1202 369 5 0.5200 9.663 7.1 0.901
1203 369 5 0.5200 9.328 5.818 0.063
1204 370 4 -1.0400 20.145 36.608 9.276
1205 370 5 0.5200 20.213 35.681 9.516
1206 370 5 0.5200 20.976 36.904 8.898
1207 371 4 -1.0400 11.737 21.622 8.371
1208 371 5 0.5200 12.663 21.54 8.133
1209 371 5 0.5200 11.507 22.551 8.445
1210 372 4 -1.0400 9.389 19.28 1.83
1211 372 5 0.5200 9.344 18.327 1.716
1212 372 5 0.5200 10.142 19.625 1.344
1213 373 4 -1.0400 2.536 33.625 22.758
1214 373 5 0.5200 1.808 34.021 22.272
1215 373 5 0.5200 3.003 33.009 22.189
1216 374 4 -1.0400 14.279 30.363 13.174
1217 374 5 0.5200 14.681 29.5 13.298
1218 374 5 0.5200 13.329 30.265 13.084
1219 375 4 -1.0400 22.323 30.505 15.462
1220 375 5 0.5200 22.367 30.817 16.369
1221 375 5 0.5200 21.591 30.933 15.012
1222 376 4 -1.0400 23.375 14.94 13.517
1223 376 5 0.5200 22.517 14.824 13.101
1224 376 5 0.5200 23.471 14.311 14.235
1225 377 4 -1.0400 21.254 16.824 9.899
1226 377 5 0.5200 20.852 17.081 9.065
1227 377 5 0.5200 21.36 15.87 9.923
1228 378 4 -1.0400 5.444 25.252 16.085
1229 378 5 0.5200 5.719 25.092 15.179
1230 378 5 0.5200 4.991 26.097 16.138
1231 379 4 -1.0400 14.037 27.466 15.063
1232 379 5 0.5200 14.608 26.71 15.219
1233 379 5 0.5200 13.84 27.531 14.126
1234 380 4 -1.0400 2.399 2.067 10.709
1235 380 5 0.5200 2.593 1.459 9.992
1236 380 5 0.5200 3.22 2.4 11.078
1237 381 4 -1.0400 8.242 8.591 7.607
1238 381 5 0.5200 7.83 8.644 8.472
1239 381 5 0.5200 8.853 9.323 7.498
1240 382 4 -1.0400 23.335 25.267 10.253
1241 382 5 0.5200 23.188 24.56 9.621
1242 382 5 0.5200 24.242 25.233 10.567
1243 383 4 -1.0400 20.144 26.417 18.17
1244 383 5 0.5200 19.88 27.115 17.566
1245 383 5 0.5200 20.732 25.808 17.717
1246 384 4 -1.0400 14.086 9.298 6.63
1247 384 5 0.5200 13.568 10.051 6.336
1248 384 5 0.5200 13.656 8.486 6.353
1249 385 4 -1.0400 6.947 25.859 0.461
1250 385 5 0.5200 7.324 25.203 1.052
1251 385 5 0.5200 6.007 25.694 0.357
1252 386 4 -1.0400 15.298 17.682 16.678
1253 386 5 0.5200 15.988 18.313 16.897
1254 386 5 0.5200 15.696 16.841 16.444
1255 387 4 -1.0400 23.042 18.165 13.572
1256 387 5 0.5200 22.736 18.452 12.708
1257 387 5 0.5200 23.979 17.96 13.528
1258 388 4 -1.0400 8.041 3.55 24.467
1259 388 5 0.5200 8.051 2.618 24.698
1260 388 5 0.5200 8.822 3.978 24.825
1261 389 4 -1.0400 2.159 35.971 16.041
1262 389 5 0.5200 2.971 36.362 16.372
1263 389 5 0.5200 2.137 36.041 15.084
1264 390 4 -1.0400 14.622 38.378 11.519
1265 390 5 0.5200 15.434 37.935 11.261
1266 390 5 0.5200 14.179 38.715 10.737
1267 391 4 -1.0400 3.609 25.249 9.742
1268 391 5 0.5200 3.619 25.986 10.356
1269 391 5 0.5200 4.484 24.857 9.698
1270 392 4 -1.0400 17.977 36.587 3.078
1271 392 5 0.5200 18.77 36.06 3.2
1272 392 5 0.5200 17.211 36.085 3.364
1273 393 4 -1.0400 11.692 26.78 17.781
1274 393 5 0.5200 12.051 26.832 16.892
1275 393 5 0.5200 11.295 27.622 18.015
1276 394 4 -1.0400 12.892 36.694 14.241
1277 394 5 0.5200 12.959 35.736 14.21
1278 394 5 0.5200 11.99 36.945 14.451
1279 395 4 -1.0400 5.683 33.934 16.088
1280 395 5 0.5200 6.584 34.094 16.38
1281 395 5 0.5200 5.231 34.772 15.969
1282 396 4 -1.0400 10.26 3.567 6.327
1283 396 5 0.5200 11.19 3.438 6.123
1284 396 5 0.5200 10.165 4.302 6.937
1285 397 4 -1.0400 22.661 22.922 17.395
1286 397 5 0.5200 23.503 22.603 17.062
1287 397 5 0.5200 21.948 22.42 16.995
1288 398 4 -1.0400 4.926 27.614 1.121
1289 398 5 0.5200 4.347 28.264 1.525
1290 398 5 0.5200 5.819 27.728 1.456
1291 399 4 -1.0400 3.212 2.768 24.396
1292 399 5 0.5200 3.376 2.206 23.634
1293 399 5 0.5200 4.046 2.985 24.818
1294 400 4 -1.0400 5.759 4.866 15.872
1295 400 5 0.5200 5.299 5.34 15.176
1296 400 5 0.5200 6.707 4.952 15.746
1297 401 4 -1.0400 0.64 21.55 23.849
1298 401 5 0.5200 0.137 21.077 24.516
1299 401 5 0.5200 0.368 22.47 23.834
1300 402 4 -1.0400 16.897 23.325 4.214
1301 402 5 0.5200 16.699 23.359 3.275
1302 402 5 0.5200 16.249 23.843 4.697
1303 403 4 -1.0400 6.041 15.418 13.714
1304 403 5 0.5200 6.754 14.83 13.972
1305 403 5 0.5200 6.328 15.968 12.981
1306 404 4 -1.0400 17.656 30.942 6.922
1307 404 5 0.5200 16.993 30.302 7.191
1308 404 5 0.5200 18.532 30.576 7.066
1309 405 4 -1.0400 9.045 44.418 4.815
1310 405 5 0.5200 9.104 44.618 5.752
1311 405 5 0.5200 8.403 45 4.403
1312 406 4 -1.0400 3.113 41.956 7.599
1313 406 5 0.5200 2.185 42.099 7.799
1314 406 5 0.5200 3.533 42.797 7.407
1315 407 4 -1.0400 21.023 28.618 2.463
1316 407 5 0.5200 21.825 29.04 2.148
1317 407 5 0.5200 20.383 29.291 2.71
1318 408 4 -1.0400 1.867 19.917 23.285
1319 408 5 0.5200 0.968 19.781 22.975
1320 408 5 0.5200 2.415 20.218 22.557
1321 409 4 -1.0400 12.644 7.47 7.972
1322 409 5 0.5200 12.665 8.422 8.09
1323 409 5 0.5200 13.542 7.133 7.93
1324 410 4 -1.0400 19.743 44.07 16.435
1325 410 5 0.5200 18.96 44.435 16.854
1326 410 5 0.5200 20.523 44.519 16.768
1327 411 4 -1.0400 24.497 33.238 15.333
1328 411 5 0.5200 23.59 33.491 15.523
1329 411 5 0.5200 24.995 34.012 15.061
1330 412 4 -1.0400 18.37 11.92 21.781
1331 412 5 0.5200 19.32 11.978 21.902
1332 412 5 0.5200 18.034 12.765 21.474
1333 413 4 -1.0400 17.902 40.161 19.34
1334 413 5 0.5200 17.275 39.461 19.538
1335 413 5 0.5200 17.627 40.622 18.545
1336 414 4 -1.0400 23.047 15.555 22.369
1337 414 5 0.5200 22.646 14.809 22.821
1338 414 5 0.5200 22.782 16.371 22.801
1339 415 4 -1.0400 16.381 33.457 22.908
1340 415 5 0.5200 16.776 32.812 22.316
1341 415 5 0.5200 16.889 33.498 23.721
1342 416 4 -1.0400 19.172 41.984 22.512
1343 416 5 0.5200 19.668 41.248 22.146
1344 416 5 0.5200 18.236 41.77 22.513
1345 417 4 -1.0400 4.636 29.441 11.765
1346 417 5 0.5200 3.829 29.29 12.262
1347 417 5 0.5200 4.749 28.741 11.118
1348 418 4 -1.0400 6.433 20.875 15.342
1349 418 5 0.5200 7.113 21.207 15.933
1350 418 5 0.5200 6.391 21.429 14.559
1351 419 4 -1.0400 10.636 32.57 11.056
1352 419 5 0.5200 10.352 31.759 10.626
1353 419 5 0.5200 11.578 32.525 11.233
1354 420 4 -1.0400 6.947 20.654 12.576
1355 420 5 0.5200 6.085 20.661 12.153
1356 420 5 0.5200 7.054 19.839 13.073
1357 421 4 -1.0400 21.436 36.937 2.191
1358 421 5 0.5200 21.008 36.085 2.304
1359 421 5 0.5200 20.798 37.638 2.338
1360 422 4 -1.0400 2.709 0.986 20.169
1361 422 5 0.5200 3.094 0.909 19.292
1362 422 5 0.5200 2.948 0.217 20.692
1363 423 4 -1.0400 21.261 31.544 24.102
1364 423 5 0.5200 20.684 32.108 24.622
1365 423 5 0.5200 22.088 32.002 23.933
1366 424 4 -1.0400 3.022 40.877 19.446
1367 424 5 0.5200 3.32 41.79 19.448
1368 424 5 0.5200 3.78 40.293 19.367
1369 425 4 -1.0400 20.898 13.56 23.297
1370 425 5 0.5200 20.828 13.577 22.339
1371 425 5 0.5200 20.629 12.698 23.622
1372 426 4 -1.0400 6.19 40.419 2.162
1373 426 5 0.5200 6.484 39.545 1.896
1374 426 5 0.5200 6.8 40.777 2.811
1375 427 4 -1.0400 8.184 21.194 18.859
1376 427 5 0.5200 7.853 20.763 18.068
1377 427 5 0.5200 9.059 20.857 19.065
1378 428 4 -1.0400 10.443 5.956 8.984
1379 428 5 0.5200 11.27 6.127 8.529
1380 428 5 0.5200 10.399 6.491 9.78
1381 429 4 -1.0400 16.967 21.276 11.713
1382 429 5 0.5200 17.688 20.727 11.397
1383 429 5 0.5200 17.316 22.114 12.025
1384 430 4 -1.0400 13.846 15.837 13.367
1385 430 5 0.5200 13.163 16.512 13.36
1386 430 5 0.5200 14.692 16.239 13.575
1387 431 4 -1.0400 7.493 16.596 18.976
1388 431 5 0.5200 7.754 17.35 18.441
1389 431 5 0.5200 6.647 16.262 18.668
1390 432 4 -1.0400 14.344 3.557 3.878
1391 432 5 0.5200 14.718 3.287 3.036
1392 432 5 0.5200 14.76 4.372 4.167
1393 433 4 -1.0400 24.553 13.119 0.34
1394 433 5 0.5200 24.709 12.204 0.585
1395 433 5 0.5200 23.608 13.281 0.291
1396 434 4 -1.0400 23.45 35.78 7.939
1397 434 5 0.5200 24.183 36.103 7.411
1398 434 5 0.5200 23.695 34.951 8.355
1399 435 4 -1.0400 2.458 20.967 20.704
1400 435 5 0.5200 1.604 21.278 21.014
1401 435 5 0.5200 2.405 20.768 19.766
1402 436 4 -1.0400 15.355 43.009 18.185
1403 436 5 0.5200 15 42.35 17.583
1404 436 5 0.5200 15.339 43.87 17.762
1405 437 4 -1.0400 7.481 23.733 14.447
1406 437 5 0.5200 7.978 23.251 15.113
1407 437 5 0.5200 7.61 23.319 13.59
1408 438 4 -1.0400 13.426 17.295 18.309
1409 438 5 0.5200 13.929 18.112 18.348
1410 438 5 0.5200 12.818 17.329 17.567
1411 439 4 -1.0400 20.964 19.683 9.166
1412 439 5 0.5200 21.048 20.582 9.492
1413 439 5 0.5200 21.833 19.276 9.123
1414 440 4 -1.0400 16.851 20.444 1.287
1415 440 5 0.5200 17.439 19.69 1.2
1416 440 5 0.5200 17.37 21.25 1.339
1417 441 4 -1.0400 0.786 2.196 5.882
1418 441 5 0.5200 1.278 1.404 6.109
1419 441 5 0.5200 1.177 2.953 6.323
1420 442 4 -1.0400 9.855 11.425 1.858
1421 442 5 0.5200 9.328 11.94 2.474
1422 442 5 0.5200 9.707 10.49 2.014
1423 443 4 -1.0400 2.559 25.219 4.3
1424 443 5 0.5200 2.039 26.019 4.186
1425 443 5 0.5200 2.065 24.466 3.969
1426 444 4 -1.0400 15.034 18.34 1.148
1427 444 5 0.5200 15.269 17.412 1.072
1428 444 5 0.5200 14.112 18.416 1.403
1429 445 4 -1.0400 3.055 21.127 3.01
1430 445 5 0.5200 3.798 21.705 3.195
1431 445 5 0.5200 3.181 20.705 2.157
1432 446 4 -1.0400 13.507 14.618 10.775
1433 446 5 0.5200 13.346 15.171 10.007
1434 446 5 0.5200 14.376 14.216 10.705
1435 447 4 -1.0400 23.896 36.693 0.586
1436 447 5 0.5200 23.883 36.4 1.5
1437 447 5 0.5200 24.282 37.57 0.535
1438 448 4 -1.0400 6.642 31.01 4.13
1439 448 5 0.5200 7.007 31.768 4.593
1440 448 5 0.5200 5.737 31.196 3.873
1441 449 4 -1.0400 17.744 25.716 6.312
1442 449 5 0.5200 18.557 25.734 6.822
1443 449 5 0.5200 17.385 24.825 6.313
1444 450 4 -1.0400 9.374 27.485 16.141
1445 450 5 0.5200 9.326 27.426 15.184
1446 450 5 0.5200 9.937 28.222 16.389
1447 451 4 -1.0400 13.883 28.091 19.134
1448 451 5 0.5200 14.107 27.251 18.727
1449 451 5 0.5200 14.551 28.32 19.784
1450 452 4 -1.0400 19.823 23.116 12.381
1451 452 5 0.5200 19.497 22.216 12.311
1452 452 5 0.5200 19.985 23.467 11.502
1453 453 4 -1.0400 13.623 0.575 2.957
1454 453 5 0.5200 13.565 0.904 2.057
1455 453 5 0.5200 14.383 0.965 3.394
1456 454 4 -1.0400 3.173 34.797 6.456
1457 454 5 0.5200 2.244 35.015 6.351
1458 454 5 0.5200 3.653 35.575 6.75
1459 455 4 -1.0400 9.04 41.918 6.021
1460 455 5 0.5200 9.893 41.653 6.372
1461 455 5 0.5200 8.717 41.243 5.419
1462 456 4 -1.0400 18.631 38.61 22.892
1463 456 5 0.5200 19.219 38.326 22.188
1464 456 5 0.5200 18.601 37.936 23.575
1465 457 4 -1.0400 15.102 24.964 17.516
1466 457 5 0.5200 15.846 25.554 17.66
1467 457 5 0.5200 14.394 25.444 17.079
1468 458 4 -1.0400 11.278 34.779 7.335
1469 458 5 0.5200 10.453 34.37 7.606
1470 458 5 0.5200 11.951 34.613 7.999
1471 459 4 -1.0400 17.995 38.759 5.714
1472 459 5 0.5200 17.818 39.531 6.258
1473 459 5 0.5200 17.21 38.538 5.208
1474 460 4 -1.0400 23.574 20.494 10.131
1475 460 5 0.5200 24.281 21.013 10.521
1476 460 5 0.5200 23.92 19.647 9.843
1477 461 4 -1.0400 11.32 36.242 11.802
1478 461 5 0.5200 11.597 35.617 12.477
1479 461 5 0.5200 11.973 36.941 11.725
1480 462 4 -1.0400 0.004 5.145 16.789
1481 462 5 0.5200 0.376 5.851 16.255
1482 462 5 0.5200 0.344 4.3 16.484
1483 463 4 -1.0400 10.92 6.312 4.816
1484 463 5 0.5200 10.908 5.938 3.932
1485 463 5 0.5200 10.45 7.149 4.817
1486 464 4 -1.0400 8.508 26.931 23.372
1487 464 5 0.5200 9.451 26.997 23.537
1488 464 5 0.5200 8.269 26.01 23.244
1489 465 4 -1.0400 24.077 4.585 15.822
1490 465 5 0.5200 24.875 4.526 16.352
1491 465 5 0.5200 23.32 4.721 16.396
1492 466 4 -1.0400 5.282 8.3 17.628
1493 466 5 0.5200 5.16 7.407 17.297
1494 466 5 0.5200 6.208 8.441 17.836
1495 467 4 -1.0400 16.742 15.596 14.501
1496 467 5 0.5200 17.332 15.423 13.765
1497 467 5 0.5200 17.257 15.725 15.301
1498 468 4 -1.0400 21.039 10.505 23.501
1499 468 5 0.5200 21.387 9.746 23.026
1500 468 5 0.5200 21.207 10.4 24.44
1501 469 4 -1.0400 20.394 28.676 19.842
1502 469 5 0.5200 21.186 28.294 20.227
1503 469 5 0.5200 20.513 29.623 19.739
1504 470 4 -1.0400 4.598 37.031 10.825
1505 470 5 0.5200 3.725 36.635 10.767
1506 470 5 0.5200 5.24 36.451 10.409
1507 471 4 -1.0400 7.285 30.265 6.177
1508 471 5 0.5200 8.175 29.919 6.076
1509 471 5 0.5200 7.316 31.092 6.664
1510 472 4 -1.0400 2.561 15.319 9.85
1511 472 5 0.5200 1.955 14.575 9.86
1512 472 5 0.5200 3.453 15.008 10.019
1513 473 4 -1.0400 2.583 6.007 16.67
1514 473 5 0.5200 2.166 6.431 17.424
1515 473 5 0.5200 2.949 5.162 16.941
1516 474 4 -1.0400 20.261 32.11 16.779
1517 474 5 0.5200 20.428 31.717 17.639
1518 474 5 0.5200 19.931 33.004 16.895
1519 475 4 -1.0400 7.628 16.81 1.047
1520 475 5 0.5200 8.466 16.355 1.159
1521 475 5 0.5200 7.558 17.135 0.147
1522 476 4 -1.0400 0.75 42.959 10.028
1523 476 5 0.5200 0.106 42.27 10.209
1524 476 5 0.5200 0.364 43.613 9.441
1525 477 4 -1.0400 20.327 3.14 0.422
1526 477 5 0.5200 19.688 3.308 1.118
1527 477 5 0.5200 20.567 3.969 0.002
1528 478 4 -1.0400 9.657 36.502 17.966
1529 478 5 0.5200 8.821 36.122 18.246
1530 478 5 0.5200 9.516 37.402 17.665
1531 479 4 -1.0400 1.098 18.631 12.802
1532 479 5 0.5200 0.461 17.954 12.559
1533 479 5 0.5200 1.97 18.237 12.876
1534 480 4 -1.0400 1.923 29.145 21.552
1535 480 5 0.5200 2.091 29.595 20.72
1536 480 5 0.5200 2.626 29.347 22.173
1537 481 4 -1.0400 17.532 28.306 11.112
1538 481 5 0.5200 17.516 27.453 10.672
1539 481 5 0.5200 17.538 28.176 12.063
Bonds
1 1 4 1
2 1 4 2
3 1 4 3
4 2 4 5
5 2 5 6
6 1 6 7
7 3 6 8
8 1 8 9
9 1 8 10
10 1 8 11
11 3 6 12
12 1 12 13
13 2 12 15
14 1 12 14
15 2 15 16
16 1 16 17
17 3 16 18
18 1 18 19
19 1 18 20
20 1 18 21
21 3 16 22
22 1 22 23
23 2 22 25
24 1 22 24
25 2 25 26
26 1 26 27
27 3 26 28
28 1 28 29
29 1 28 30
30 1 28 31
31 3 26 32
32 1 32 33
33 2 32 35
34 1 32 34
35 2 35 36
36 1 36 37
37 3 36 38
38 1 38 39
39 1 38 40
40 1 38 41
41 3 36 42
42 1 42 43
43 2 42 45
44 1 42 44
45 2 45 46
46 1 46 47
47 3 46 48
48 1 48 49
49 1 48 50
50 1 48 51
51 3 46 52
52 1 52 53
53 2 52 55
54 1 52 54
55 2 55 56
56 1 56 57
57 3 56 58
58 1 58 59
59 1 58 60
60 1 58 61
61 3 56 62
62 1 62 63
63 2 62 65
64 1 62 64
65 2 65 66
66 1 66 67
67 3 66 68
68 1 68 69
69 1 68 70
70 1 68 71
71 3 66 72
72 1 72 73
73 2 72 75
74 1 72 74
75 2 75 76
76 1 76 77
77 3 76 78
78 1 78 79
79 1 78 80
80 1 78 81
81 3 76 82
82 1 82 83
83 2 82 85
84 1 82 84
85 2 85 86
86 1 86 87
87 3 86 88
88 1 88 89
89 1 88 90
90 1 88 91
91 3 86 92
92 1 92 93
93 2 92 95
94 1 92 94
95 2 95 96
96 1 96 97
97 2 96 98
98 1 96 99
99 4 100 101
100 4 100 102
101 4 103 104
102 4 103 105
103 4 106 107
104 4 106 108
105 4 109 110
106 4 109 111
107 4 112 113
108 4 112 114
109 4 115 116
110 4 115 117
111 4 118 119
112 4 118 120
113 4 121 122
114 4 121 123
115 4 124 125
116 4 124 126
117 4 127 128
118 4 127 129
119 4 130 131
120 4 130 132
121 4 133 134
122 4 133 135
123 4 136 137
124 4 136 138
125 4 139 140
126 4 139 141
127 4 142 143
128 4 142 144
129 4 145 146
130 4 145 147
131 4 148 149
132 4 148 150
133 4 151 152
134 4 151 153
135 4 154 155
136 4 154 156
137 4 157 158
138 4 157 159
139 4 160 161
140 4 160 162
141 4 163 164
142 4 163 165
143 4 166 167
144 4 166 168
145 4 169 170
146 4 169 171
147 4 172 173
148 4 172 174
149 4 175 176
150 4 175 177
151 4 178 179
152 4 178 180
153 4 181 182
154 4 181 183
155 4 184 185
156 4 184 186
157 4 187 188
158 4 187 189
159 4 190 191
160 4 190 192
161 4 193 194
162 4 193 195
163 4 196 197
164 4 196 198
165 4 199 200
166 4 199 201
167 4 202 203
168 4 202 204
169 4 205 206
170 4 205 207
171 4 208 209
172 4 208 210
173 4 211 212
174 4 211 213
175 4 214 215
176 4 214 216
177 4 217 218
178 4 217 219
179 4 220 221
180 4 220 222
181 4 223 224
182 4 223 225
183 4 226 227
184 4 226 228
185 4 229 230
186 4 229 231
187 4 232 233
188 4 232 234
189 4 235 236
190 4 235 237
191 4 238 239
192 4 238 240
193 4 241 242
194 4 241 243
195 4 244 245
196 4 244 246
197 4 247 248
198 4 247 249
199 4 250 251
200 4 250 252
201 4 253 254
202 4 253 255
203 4 256 257
204 4 256 258
205 4 259 260
206 4 259 261
207 4 262 263
208 4 262 264
209 4 265 266
210 4 265 267
211 4 268 269
212 4 268 270
213 4 271 272
214 4 271 273
215 4 274 275
216 4 274 276
217 4 277 278
218 4 277 279
219 4 280 281
220 4 280 282
221 4 283 284
222 4 283 285
223 4 286 287
224 4 286 288
225 4 289 290
226 4 289 291
227 4 292 293
228 4 292 294
229 4 295 296
230 4 295 297
231 4 298 299
232 4 298 300
233 4 301 302
234 4 301 303
235 4 304 305
236 4 304 306
237 4 307 308
238 4 307 309
239 4 310 311
240 4 310 312
241 4 313 314
242 4 313 315
243 4 316 317
244 4 316 318
245 4 319 320
246 4 319 321
247 4 322 323
248 4 322 324
249 4 325 326
250 4 325 327
251 4 328 329
252 4 328 330
253 4 331 332
254 4 331 333
255 4 334 335
256 4 334 336
257 4 337 338
258 4 337 339
259 4 340 341
260 4 340 342
261 4 343 344
262 4 343 345
263 4 346 347
264 4 346 348
265 4 349 350
266 4 349 351
267 4 352 353
268 4 352 354
269 4 355 356
270 4 355 357
271 4 358 359
272 4 358 360
273 4 361 362
274 4 361 363
275 4 364 365
276 4 364 366
277 4 367 368
278 4 367 369
279 4 370 371
280 4 370 372
281 4 373 374
282 4 373 375
283 4 376 377
284 4 376 378
285 4 379 380
286 4 379 381
287 4 382 383
288 4 382 384
289 4 385 386
290 4 385 387
291 4 388 389
292 4 388 390
293 4 391 392
294 4 391 393
295 4 394 395
296 4 394 396
297 4 397 398
298 4 397 399
299 4 400 401
300 4 400 402
301 4 403 404
302 4 403 405
303 4 406 407
304 4 406 408
305 4 409 410
306 4 409 411
307 4 412 413
308 4 412 414
309 4 415 416
310 4 415 417
311 4 418 419
312 4 418 420
313 4 421 422
314 4 421 423
315 4 424 425
316 4 424 426
317 4 427 428
318 4 427 429
319 4 430 431
320 4 430 432
321 4 433 434
322 4 433 435
323 4 436 437
324 4 436 438
325 4 439 440
326 4 439 441
327 4 442 443
328 4 442 444
329 4 445 446
330 4 445 447
331 4 448 449
332 4 448 450
333 4 451 452
334 4 451 453
335 4 454 455
336 4 454 456
337 4 457 458
338 4 457 459
339 4 460 461
340 4 460 462
341 4 463 464
342 4 463 465
343 4 466 467
344 4 466 468
345 4 469 470
346 4 469 471
347 4 472 473
348 4 472 474
349 4 475 476
350 4 475 477
351 4 478 479
352 4 478 480
353 4 481 482
354 4 481 483
355 4 484 485
356 4 484 486
357 4 487 488
358 4 487 489
359 4 490 491
360 4 490 492
361 4 493 494
362 4 493 495
363 4 496 497
364 4 496 498
365 4 499 500
366 4 499 501
367 4 502 503
368 4 502 504
369 4 505 506
370 4 505 507
371 4 508 509
372 4 508 510
373 4 511 512
374 4 511 513
375 4 514 515
376 4 514 516
377 4 517 518
378 4 517 519
379 4 520 521
380 4 520 522
381 4 523 524
382 4 523 525
383 4 526 527
384 4 526 528
385 4 529 530
386 4 529 531
387 4 532 533
388 4 532 534
389 4 535 536
390 4 535 537
391 4 538 539
392 4 538 540
393 4 541 542
394 4 541 543
395 4 544 545
396 4 544 546
397 4 547 548
398 4 547 549
399 4 550 551
400 4 550 552
401 4 553 554
402 4 553 555
403 4 556 557
404 4 556 558
405 4 559 560
406 4 559 561
407 4 562 563
408 4 562 564
409 4 565 566
410 4 565 567
411 4 568 569
412 4 568 570
413 4 571 572
414 4 571 573
415 4 574 575
416 4 574 576
417 4 577 578
418 4 577 579
419 4 580 581
420 4 580 582
421 4 583 584
422 4 583 585
423 4 586 587
424 4 586 588
425 4 589 590
426 4 589 591
427 4 592 593
428 4 592 594
429 4 595 596
430 4 595 597
431 4 598 599
432 4 598 600
433 4 601 602
434 4 601 603
435 4 604 605
436 4 604 606
437 4 607 608
438 4 607 609
439 4 610 611
440 4 610 612
441 4 613 614
442 4 613 615
443 4 616 617
444 4 616 618
445 4 619 620
446 4 619 621
447 4 622 623
448 4 622 624
449 4 625 626
450 4 625 627
451 4 628 629
452 4 628 630
453 4 631 632
454 4 631 633
455 4 634 635
456 4 634 636
457 4 637 638
458 4 637 639
459 4 640 641
460 4 640 642
461 4 643 644
462 4 643 645
463 4 646 647
464 4 646 648
465 4 649 650
466 4 649 651
467 4 652 653
468 4 652 654
469 4 655 656
470 4 655 657
471 4 658 659
472 4 658 660
473 4 661 662
474 4 661 663
475 4 664 665
476 4 664 666
477 4 667 668
478 4 667 669
479 4 670 671
480 4 670 672
481 4 673 674
482 4 673 675
483 4 676 677
484 4 676 678
485 4 679 680
486 4 679 681
487 4 682 683
488 4 682 684
489 4 685 686
490 4 685 687
491 4 688 689
492 4 688 690
493 4 691 692
494 4 691 693
495 4 694 695
496 4 694 696
497 4 697 698
498 4 697 699
499 4 700 701
500 4 700 702
501 4 703 704
502 4 703 705
503 4 706 707
504 4 706 708
505 4 709 710
506 4 709 711
507 4 712 713
508 4 712 714
509 4 715 716
510 4 715 717
511 4 718 719
512 4 718 720
513 4 721 722
514 4 721 723
515 4 724 725
516 4 724 726
517 4 727 728
518 4 727 729
519 4 730 731
520 4 730 732
521 4 733 734
522 4 733 735
523 4 736 737
524 4 736 738
525 4 739 740
526 4 739 741
527 4 742 743
528 4 742 744
529 4 745 746
530 4 745 747
531 4 748 749
532 4 748 750
533 4 751 752
534 4 751 753
535 4 754 755
536 4 754 756
537 4 757 758
538 4 757 759
539 4 760 761
540 4 760 762
541 4 763 764
542 4 763 765
543 4 766 767
544 4 766 768
545 4 769 770
546 4 769 771
547 4 772 773
548 4 772 774
549 4 775 776
550 4 775 777
551 4 778 779
552 4 778 780
553 4 781 782
554 4 781 783
555 4 784 785
556 4 784 786
557 4 787 788
558 4 787 789
559 4 790 791
560 4 790 792
561 4 793 794
562 4 793 795
563 4 796 797
564 4 796 798
565 4 799 800
566 4 799 801
567 4 802 803
568 4 802 804
569 4 805 806
570 4 805 807
571 4 808 809
572 4 808 810
573 4 811 812
574 4 811 813
575 4 814 815
576 4 814 816
577 4 817 818
578 4 817 819
579 4 820 821
580 4 820 822
581 4 823 824
582 4 823 825
583 4 826 827
584 4 826 828
585 4 829 830
586 4 829 831
587 4 832 833
588 4 832 834
589 4 835 836
590 4 835 837
591 4 838 839
592 4 838 840
593 4 841 842
594 4 841 843
595 4 844 845
596 4 844 846
597 4 847 848
598 4 847 849
599 4 850 851
600 4 850 852
601 4 853 854
602 4 853 855
603 4 856 857
604 4 856 858
605 4 859 860
606 4 859 861
607 4 862 863
608 4 862 864
609 4 865 866
610 4 865 867
611 4 868 869
612 4 868 870
613 4 871 872
614 4 871 873
615 4 874 875
616 4 874 876
617 4 877 878
618 4 877 879
619 4 880 881
620 4 880 882
621 4 883 884
622 4 883 885
623 4 886 887
624 4 886 888
625 4 889 890
626 4 889 891
627 4 892 893
628 4 892 894
629 4 895 896
630 4 895 897
631 4 898 899
632 4 898 900
633 4 901 902
634 4 901 903
635 4 904 905
636 4 904 906
637 4 907 908
638 4 907 909
639 4 910 911
640 4 910 912
641 4 913 914
642 4 913 915
643 4 916 917
644 4 916 918
645 4 919 920
646 4 919 921
647 4 922 923
648 4 922 924
649 4 925 926
650 4 925 927
651 4 928 929
652 4 928 930
653 4 931 932
654 4 931 933
655 4 934 935
656 4 934 936
657 4 937 938
658 4 937 939
659 4 940 941
660 4 940 942
661 4 943 944
662 4 943 945
663 4 946 947
664 4 946 948
665 4 949 950
666 4 949 951
667 4 952 953
668 4 952 954
669 4 955 956
670 4 955 957
671 4 958 959
672 4 958 960
673 4 961 962
674 4 961 963
675 4 964 965
676 4 964 966
677 4 967 968
678 4 967 969
679 4 970 971
680 4 970 972
681 4 973 974
682 4 973 975
683 4 976 977
684 4 976 978
685 4 979 980
686 4 979 981
687 4 982 983
688 4 982 984
689 4 985 986
690 4 985 987
691 4 988 989
692 4 988 990
693 4 991 992
694 4 991 993
695 4 994 995
696 4 994 996
697 4 997 998
698 4 997 999
699 4 1000 1001
700 4 1000 1002
701 4 1003 1004
702 4 1003 1005
703 4 1006 1007
704 4 1006 1008
705 4 1009 1010
706 4 1009 1011
707 4 1012 1013
708 4 1012 1014
709 4 1015 1016
710 4 1015 1017
711 4 1018 1019
712 4 1018 1020
713 4 1021 1022
714 4 1021 1023
715 4 1024 1025
716 4 1024 1026
717 4 1027 1028
718 4 1027 1029
719 4 1030 1031
720 4 1030 1032
721 4 1033 1034
722 4 1033 1035
723 4 1036 1037
724 4 1036 1038
725 4 1039 1040
726 4 1039 1041
727 4 1042 1043
728 4 1042 1044
729 4 1045 1046
730 4 1045 1047
731 4 1048 1049
732 4 1048 1050
733 4 1051 1052
734 4 1051 1053
735 4 1054 1055
736 4 1054 1056
737 4 1057 1058
738 4 1057 1059
739 4 1060 1061
740 4 1060 1062
741 4 1063 1064
742 4 1063 1065
743 4 1066 1067
744 4 1066 1068
745 4 1069 1070
746 4 1069 1071
747 4 1072 1073
748 4 1072 1074
749 4 1075 1076
750 4 1075 1077
751 4 1078 1079
752 4 1078 1080
753 4 1081 1082
754 4 1081 1083
755 4 1084 1085
756 4 1084 1086
757 4 1087 1088
758 4 1087 1089
759 4 1090 1091
760 4 1090 1092
761 4 1093 1094
762 4 1093 1095
763 4 1096 1097
764 4 1096 1098
765 4 1099 1100
766 4 1099 1101
767 4 1102 1103
768 4 1102 1104
769 4 1105 1106
770 4 1105 1107
771 4 1108 1109
772 4 1108 1110
773 4 1111 1112
774 4 1111 1113
775 4 1114 1115
776 4 1114 1116
777 4 1117 1118
778 4 1117 1119
779 4 1120 1121
780 4 1120 1122
781 4 1123 1124
782 4 1123 1125
783 4 1126 1127
784 4 1126 1128
785 4 1129 1130
786 4 1129 1131
787 4 1132 1133
788 4 1132 1134
789 4 1135 1136
790 4 1135 1137
791 4 1138 1139
792 4 1138 1140
793 4 1141 1142
794 4 1141 1143
795 4 1144 1145
796 4 1144 1146
797 4 1147 1148
798 4 1147 1149
799 4 1150 1151
800 4 1150 1152
801 4 1153 1154
802 4 1153 1155
803 4 1156 1157
804 4 1156 1158
805 4 1159 1160
806 4 1159 1161
807 4 1162 1163
808 4 1162 1164
809 4 1165 1166
810 4 1165 1167
811 4 1168 1169
812 4 1168 1170
813 4 1171 1172
814 4 1171 1173
815 4 1174 1175
816 4 1174 1176
817 4 1177 1178
818 4 1177 1179
819 4 1180 1181
820 4 1180 1182
821 4 1183 1184
822 4 1183 1185
823 4 1186 1187
824 4 1186 1188
825 4 1189 1190
826 4 1189 1191
827 4 1192 1193
828 4 1192 1194
829 4 1195 1196
830 4 1195 1197
831 4 1198 1199
832 4 1198 1200
833 4 1201 1202
834 4 1201 1203
835 4 1204 1205
836 4 1204 1206
837 4 1207 1208
838 4 1207 1209
839 4 1210 1211
840 4 1210 1212
841 4 1213 1214
842 4 1213 1215
843 4 1216 1217
844 4 1216 1218
845 4 1219 1220
846 4 1219 1221
847 4 1222 1223
848 4 1222 1224
849 4 1225 1226
850 4 1225 1227
851 4 1228 1229
852 4 1228 1230
853 4 1231 1232
854 4 1231 1233
855 4 1234 1235
856 4 1234 1236
857 4 1237 1238
858 4 1237 1239
859 4 1240 1241
860 4 1240 1242
861 4 1243 1244
862 4 1243 1245
863 4 1246 1247
864 4 1246 1248
865 4 1249 1250
866 4 1249 1251
867 4 1252 1253
868 4 1252 1254
869 4 1255 1256
870 4 1255 1257
871 4 1258 1259
872 4 1258 1260
873 4 1261 1262
874 4 1261 1263
875 4 1264 1265
876 4 1264 1266
877 4 1267 1268
878 4 1267 1269
879 4 1270 1271
880 4 1270 1272
881 4 1273 1274
882 4 1273 1275
883 4 1276 1277
884 4 1276 1278
885 4 1279 1280
886 4 1279 1281
887 4 1282 1283
888 4 1282 1284
889 4 1285 1286
890 4 1285 1287
891 4 1288 1289
892 4 1288 1290
893 4 1291 1292
894 4 1291 1293
895 4 1294 1295
896 4 1294 1296
897 4 1297 1298
898 4 1297 1299
899 4 1300 1301
900 4 1300 1302
901 4 1303 1304
902 4 1303 1305
903 4 1306 1307
904 4 1306 1308
905 4 1309 1310
906 4 1309 1311
907 4 1312 1313
908 4 1312 1314
909 4 1315 1316
910 4 1315 1317
911 4 1318 1319
912 4 1318 1320
913 4 1321 1322
914 4 1321 1323
915 4 1324 1325
916 4 1324 1326
917 4 1327 1328
918 4 1327 1329
919 4 1330 1331
920 4 1330 1332
921 4 1333 1334
922 4 1333 1335
923 4 1336 1337
924 4 1336 1338
925 4 1339 1340
926 4 1339 1341
927 4 1342 1343
928 4 1342 1344
929 4 1345 1346
930 4 1345 1347
931 4 1348 1349
932 4 1348 1350
933 4 1351 1352
934 4 1351 1353
935 4 1354 1355
936 4 1354 1356
937 4 1357 1358
938 4 1357 1359
939 4 1360 1361
940 4 1360 1362
941 4 1363 1364
942 4 1363 1365
943 4 1366 1367
944 4 1366 1368
945 4 1369 1370
946 4 1369 1371
947 4 1372 1373
948 4 1372 1374
949 4 1375 1376
950 4 1375 1377
951 4 1378 1379
952 4 1378 1380
953 4 1381 1382
954 4 1381 1383
955 4 1384 1385
956 4 1384 1386
957 4 1387 1388
958 4 1387 1389
959 4 1390 1391
960 4 1390 1392
961 4 1393 1394
962 4 1393 1395
963 4 1396 1397
964 4 1396 1398
965 4 1399 1400
966 4 1399 1401
967 4 1402 1403
968 4 1402 1404
969 4 1405 1406
970 4 1405 1407
971 4 1408 1409
972 4 1408 1410
973 4 1411 1412
974 4 1411 1413
975 4 1414 1415
976 4 1414 1416
977 4 1417 1418
978 4 1417 1419
979 4 1420 1421
980 4 1420 1422
981 4 1423 1424
982 4 1423 1425
983 4 1426 1427
984 4 1426 1428
985 4 1429 1430
986 4 1429 1431
987 4 1432 1433
988 4 1432 1434
989 4 1435 1436
990 4 1435 1437
991 4 1438 1439
992 4 1438 1440
993 4 1441 1442
994 4 1441 1443
995 4 1444 1445
996 4 1444 1446
997 4 1447 1448
998 4 1447 1449
999 4 1450 1451
1000 4 1450 1452
1001 4 1453 1454
1002 4 1453 1455
1003 4 1456 1457
1004 4 1456 1458
1005 4 1459 1460
1006 4 1459 1461
1007 4 1462 1463
1008 4 1462 1464
1009 4 1465 1466
1010 4 1465 1467
1011 4 1468 1469
1012 4 1468 1470
1013 4 1471 1472
1014 4 1471 1473
1015 4 1474 1475
1016 4 1474 1476
1017 4 1477 1478
1018 4 1477 1479
1019 4 1480 1481
1020 4 1480 1482
1021 4 1483 1484
1022 4 1483 1485
1023 4 1486 1487
1024 4 1486 1488
1025 4 1489 1490
1026 4 1489 1491
1027 4 1492 1493
1028 4 1492 1494
1029 4 1495 1496
1030 4 1495 1497
1031 4 1498 1499
1032 4 1498 1500
1033 4 1501 1502
1034 4 1501 1503
1035 4 1504 1505
1036 4 1504 1506
1037 4 1507 1508
1038 4 1507 1509
1039 4 1510 1511
1040 4 1510 1512
1041 4 1513 1514
1042 4 1513 1515
1043 4 1516 1517
1044 4 1516 1518
1045 4 1519 1520
1046 4 1519 1521
1047 4 1522 1523
1048 4 1522 1524
1049 4 1525 1526
1050 4 1525 1527
1051 4 1528 1529
1052 4 1528 1530
1053 4 1531 1532
1054 4 1531 1533
1055 4 1534 1535
1056 4 1534 1536
1057 4 1537 1538
1058 4 1537 1539
Angles
1 1 1 4 2
2 1 2 4 3
3 1 1 4 3
4 2 1 4 5
5 2 3 4 5
6 3 4 5 6
7 2 5 6 7
8 4 5 6 8
9 5 5 6 12
10 6 6 8 9
11 6 6 8 10
12 6 6 8 11
13 1 9 8 11
14 1 9 8 10
15 1 10 8 11
16 7 7 6 12
17 6 6 12 13
18 8 6 12 15
19 2 14 12 15
20 1 13 12 14
21 2 13 12 15
22 6 6 12 14
23 3 12 15 16
24 2 15 16 17
25 4 15 16 18
26 5 15 16 22
27 6 16 18 19
28 6 16 18 20
29 6 16 18 21
30 1 19 18 21
31 1 19 18 20
32 1 20 18 21
33 7 17 16 22
34 6 16 22 23
35 8 16 22 25
36 2 24 22 25
37 1 23 22 24
38 2 23 22 25
39 6 16 22 24
40 3 22 25 26
41 2 25 26 27
42 4 25 26 28
43 5 25 26 32
44 6 26 28 29
45 6 26 28 30
46 6 26 28 31
47 1 29 28 31
48 1 29 28 30
49 1 30 28 31
50 7 27 26 32
51 6 26 32 33
52 8 26 32 35
53 2 34 32 35
54 1 33 32 34
55 2 33 32 35
56 6 26 32 34
57 3 32 35 36
58 2 35 36 37
59 4 35 36 38
60 5 35 36 42
61 6 36 38 39
62 6 36 38 40
63 6 36 38 41
64 1 39 38 41
65 1 39 38 40
66 1 40 38 41
67 7 37 36 42
68 6 36 42 43
69 8 36 42 45
70 2 44 42 45
71 1 43 42 44
72 2 43 42 45
73 6 36 42 44
74 3 42 45 46
75 2 45 46 47
76 4 45 46 48
77 5 45 46 52
78 6 46 48 49
79 6 46 48 50
80 6 46 48 51
81 1 49 48 51
82 1 49 48 50
83 1 50 48 51
84 7 47 46 52
85 6 46 52 53
86 8 46 52 55
87 2 54 52 55
88 1 53 52 54
89 2 53 52 55
90 6 46 52 54
91 3 52 55 56
92 2 55 56 57
93 4 55 56 58
94 5 55 56 62
95 6 56 58 59
96 6 56 58 60
97 6 56 58 61
98 1 59 58 61
99 1 59 58 60
100 1 60 58 61
101 7 57 56 62
102 6 56 62 63
103 8 56 62 65
104 2 64 62 65
105 1 63 62 64
106 2 63 62 65
107 6 56 62 64
108 3 62 65 66
109 2 65 66 67
110 4 65 66 68
111 5 65 66 72
112 6 66 68 69
113 6 66 68 70
114 6 66 68 71
115 1 69 68 71
116 1 69 68 70
117 1 70 68 71
118 7 67 66 72
119 6 66 72 73
120 8 66 72 75
121 2 74 72 75
122 1 73 72 74
123 2 73 72 75
124 6 66 72 74
125 3 72 75 76
126 2 75 76 77
127 4 75 76 78
128 5 75 76 82
129 6 76 78 79
130 6 76 78 80
131 6 76 78 81
132 1 79 78 81
133 1 79 78 80
134 1 80 78 81
135 7 77 76 82
136 6 76 82 83
137 8 76 82 85
138 2 84 82 85
139 1 83 82 84
140 2 83 82 85
141 6 76 82 84
142 3 82 85 86
143 2 85 86 87
144 4 85 86 88
145 5 85 86 92
146 6 86 88 89
147 6 86 88 90
148 6 86 88 91
149 1 89 88 91
150 1 89 88 90
151 1 90 88 91
152 7 87 86 92
153 6 86 92 93
154 8 86 92 95
155 2 94 92 95
156 1 93 92 94
157 2 93 92 95
158 6 86 92 94
159 9 92 95 96
160 2 95 96 97
161 2 95 96 98
162 2 95 96 99
163 1 97 96 98
164 1 97 96 99
165 1 98 96 99
166 10 101 100 102
167 10 104 103 105
168 10 107 106 108
169 10 110 109 111
170 10 113 112 114
171 10 116 115 117
172 10 119 118 120
173 10 122 121 123
174 10 125 124 126
175 10 128 127 129
176 10 131 130 132
177 10 134 133 135
178 10 137 136 138
179 10 140 139 141
180 10 143 142 144
181 10 146 145 147
182 10 149 148 150
183 10 152 151 153
184 10 155 154 156
185 10 158 157 159
186 10 161 160 162
187 10 164 163 165
188 10 167 166 168
189 10 170 169 171
190 10 173 172 174
191 10 176 175 177
192 10 179 178 180
193 10 182 181 183
194 10 185 184 186
195 10 188 187 189
196 10 191 190 192
197 10 194 193 195
198 10 197 196 198
199 10 200 199 201
200 10 203 202 204
201 10 206 205 207
202 10 209 208 210
203 10 212 211 213
204 10 215 214 216
205 10 218 217 219
206 10 221 220 222
207 10 224 223 225
208 10 227 226 228
209 10 230 229 231
210 10 233 232 234
211 10 236 235 237
212 10 239 238 240
213 10 242 241 243
214 10 245 244 246
215 10 248 247 249
216 10 251 250 252
217 10 254 253 255
218 10 257 256 258
219 10 260 259 261
220 10 263 262 264
221 10 266 265 267
222 10 269 268 270
223 10 272 271 273
224 10 275 274 276
225 10 278 277 279
226 10 281 280 282
227 10 284 283 285
228 10 287 286 288
229 10 290 289 291
230 10 293 292 294
231 10 296 295 297
232 10 299 298 300
233 10 302 301 303
234 10 305 304 306
235 10 308 307 309
236 10 311 310 312
237 10 314 313 315
238 10 317 316 318
239 10 320 319 321
240 10 323 322 324
241 10 326 325 327
242 10 329 328 330
243 10 332 331 333
244 10 335 334 336
245 10 338 337 339
246 10 341 340 342
247 10 344 343 345
248 10 347 346 348
249 10 350 349 351
250 10 353 352 354
251 10 356 355 357
252 10 359 358 360
253 10 362 361 363
254 10 365 364 366
255 10 368 367 369
256 10 371 370 372
257 10 374 373 375
258 10 377 376 378
259 10 380 379 381
260 10 383 382 384
261 10 386 385 387
262 10 389 388 390
263 10 392 391 393
264 10 395 394 396
265 10 398 397 399
266 10 401 400 402
267 10 404 403 405
268 10 407 406 408
269 10 410 409 411
270 10 413 412 414
271 10 416 415 417
272 10 419 418 420
273 10 422 421 423
274 10 425 424 426
275 10 428 427 429
276 10 431 430 432
277 10 434 433 435
278 10 437 436 438
279 10 440 439 441
280 10 443 442 444
281 10 446 445 447
282 10 449 448 450
283 10 452 451 453
284 10 455 454 456
285 10 458 457 459
286 10 461 460 462
287 10 464 463 465
288 10 467 466 468
289 10 470 469 471
290 10 473 472 474
291 10 476 475 477
292 10 479 478 480
293 10 482 481 483
294 10 485 484 486
295 10 488 487 489
296 10 491 490 492
297 10 494 493 495
298 10 497 496 498
299 10 500 499 501
300 10 503 502 504
301 10 506 505 507
302 10 509 508 510
303 10 512 511 513
304 10 515 514 516
305 10 518 517 519
306 10 521 520 522
307 10 524 523 525
308 10 527 526 528
309 10 530 529 531
310 10 533 532 534
311 10 536 535 537
312 10 539 538 540
313 10 542 541 543
314 10 545 544 546
315 10 548 547 549
316 10 551 550 552
317 10 554 553 555
318 10 557 556 558
319 10 560 559 561
320 10 563 562 564
321 10 566 565 567
322 10 569 568 570
323 10 572 571 573
324 10 575 574 576
325 10 578 577 579
326 10 581 580 582
327 10 584 583 585
328 10 587 586 588
329 10 590 589 591
330 10 593 592 594
331 10 596 595 597
332 10 599 598 600
333 10 602 601 603
334 10 605 604 606
335 10 608 607 609
336 10 611 610 612
337 10 614 613 615
338 10 617 616 618
339 10 620 619 621
340 10 623 622 624
341 10 626 625 627
342 10 629 628 630
343 10 632 631 633
344 10 635 634 636
345 10 638 637 639
346 10 641 640 642
347 10 644 643 645
348 10 647 646 648
349 10 650 649 651
350 10 653 652 654
351 10 656 655 657
352 10 659 658 660
353 10 662 661 663
354 10 665 664 666
355 10 668 667 669
356 10 671 670 672
357 10 674 673 675
358 10 677 676 678
359 10 680 679 681
360 10 683 682 684
361 10 686 685 687
362 10 689 688 690
363 10 692 691 693
364 10 695 694 696
365 10 698 697 699
366 10 701 700 702
367 10 704 703 705
368 10 707 706 708
369 10 710 709 711
370 10 713 712 714
371 10 716 715 717
372 10 719 718 720
373 10 722 721 723
374 10 725 724 726
375 10 728 727 729
376 10 731 730 732
377 10 734 733 735
378 10 737 736 738
379 10 740 739 741
380 10 743 742 744
381 10 746 745 747
382 10 749 748 750
383 10 752 751 753
384 10 755 754 756
385 10 758 757 759
386 10 761 760 762
387 10 764 763 765
388 10 767 766 768
389 10 770 769 771
390 10 773 772 774
391 10 776 775 777
392 10 779 778 780
393 10 782 781 783
394 10 785 784 786
395 10 788 787 789
396 10 791 790 792
397 10 794 793 795
398 10 797 796 798
399 10 800 799 801
400 10 803 802 804
401 10 806 805 807
402 10 809 808 810
403 10 812 811 813
404 10 815 814 816
405 10 818 817 819
406 10 821 820 822
407 10 824 823 825
408 10 827 826 828
409 10 830 829 831
410 10 833 832 834
411 10 836 835 837
412 10 839 838 840
413 10 842 841 843
414 10 845 844 846
415 10 848 847 849
416 10 851 850 852
417 10 854 853 855
418 10 857 856 858
419 10 860 859 861
420 10 863 862 864
421 10 866 865 867
422 10 869 868 870
423 10 872 871 873
424 10 875 874 876
425 10 878 877 879
426 10 881 880 882
427 10 884 883 885
428 10 887 886 888
429 10 890 889 891
430 10 893 892 894
431 10 896 895 897
432 10 899 898 900
433 10 902 901 903
434 10 905 904 906
435 10 908 907 909
436 10 911 910 912
437 10 914 913 915
438 10 917 916 918
439 10 920 919 921
440 10 923 922 924
441 10 926 925 927
442 10 929 928 930
443 10 932 931 933
444 10 935 934 936
445 10 938 937 939
446 10 941 940 942
447 10 944 943 945
448 10 947 946 948
449 10 950 949 951
450 10 953 952 954
451 10 956 955 957
452 10 959 958 960
453 10 962 961 963
454 10 965 964 966
455 10 968 967 969
456 10 971 970 972
457 10 974 973 975
458 10 977 976 978
459 10 980 979 981
460 10 983 982 984
461 10 986 985 987
462 10 989 988 990
463 10 992 991 993
464 10 995 994 996
465 10 998 997 999
466 10 1001 1000 1002
467 10 1004 1003 1005
468 10 1007 1006 1008
469 10 1010 1009 1011
470 10 1013 1012 1014
471 10 1016 1015 1017
472 10 1019 1018 1020
473 10 1022 1021 1023
474 10 1025 1024 1026
475 10 1028 1027 1029
476 10 1031 1030 1032
477 10 1034 1033 1035
478 10 1037 1036 1038
479 10 1040 1039 1041
480 10 1043 1042 1044
481 10 1046 1045 1047
482 10 1049 1048 1050
483 10 1052 1051 1053
484 10 1055 1054 1056
485 10 1058 1057 1059
486 10 1061 1060 1062
487 10 1064 1063 1065
488 10 1067 1066 1068
489 10 1070 1069 1071
490 10 1073 1072 1074
491 10 1076 1075 1077
492 10 1079 1078 1080
493 10 1082 1081 1083
494 10 1085 1084 1086
495 10 1088 1087 1089
496 10 1091 1090 1092
497 10 1094 1093 1095
498 10 1097 1096 1098
499 10 1100 1099 1101
500 10 1103 1102 1104
501 10 1106 1105 1107
502 10 1109 1108 1110
503 10 1112 1111 1113
504 10 1115 1114 1116
505 10 1118 1117 1119
506 10 1121 1120 1122
507 10 1124 1123 1125
508 10 1127 1126 1128
509 10 1130 1129 1131
510 10 1133 1132 1134
511 10 1136 1135 1137
512 10 1139 1138 1140
513 10 1142 1141 1143
514 10 1145 1144 1146
515 10 1148 1147 1149
516 10 1151 1150 1152
517 10 1154 1153 1155
518 10 1157 1156 1158
519 10 1160 1159 1161
520 10 1163 1162 1164
521 10 1166 1165 1167
522 10 1169 1168 1170
523 10 1172 1171 1173
524 10 1175 1174 1176
525 10 1178 1177 1179
526 10 1181 1180 1182
527 10 1184 1183 1185
528 10 1187 1186 1188
529 10 1190 1189 1191
530 10 1193 1192 1194
531 10 1196 1195 1197
532 10 1199 1198 1200
533 10 1202 1201 1203
534 10 1205 1204 1206
535 10 1208 1207 1209
536 10 1211 1210 1212
537 10 1214 1213 1215
538 10 1217 1216 1218
539 10 1220 1219 1221
540 10 1223 1222 1224
541 10 1226 1225 1227
542 10 1229 1228 1230
543 10 1232 1231 1233
544 10 1235 1234 1236
545 10 1238 1237 1239
546 10 1241 1240 1242
547 10 1244 1243 1245
548 10 1247 1246 1248
549 10 1250 1249 1251
550 10 1253 1252 1254
551 10 1256 1255 1257
552 10 1259 1258 1260
553 10 1262 1261 1263
554 10 1265 1264 1266
555 10 1268 1267 1269
556 10 1271 1270 1272
557 10 1274 1273 1275
558 10 1277 1276 1278
559 10 1280 1279 1281
560 10 1283 1282 1284
561 10 1286 1285 1287
562 10 1289 1288 1290
563 10 1292 1291 1293
564 10 1295 1294 1296
565 10 1298 1297 1299
566 10 1301 1300 1302
567 10 1304 1303 1305
568 10 1307 1306 1308
569 10 1310 1309 1311
570 10 1313 1312 1314
571 10 1316 1315 1317
572 10 1319 1318 1320
573 10 1322 1321 1323
574 10 1325 1324 1326
575 10 1328 1327 1329
576 10 1331 1330 1332
577 10 1334 1333 1335
578 10 1337 1336 1338
579 10 1340 1339 1341
580 10 1343 1342 1344
581 10 1346 1345 1347
582 10 1349 1348 1350
583 10 1352 1351 1353
584 10 1355 1354 1356
585 10 1358 1357 1359
586 10 1361 1360 1362
587 10 1364 1363 1365
588 10 1367 1366 1368
589 10 1370 1369 1371
590 10 1373 1372 1374
591 10 1376 1375 1377
592 10 1379 1378 1380
593 10 1382 1381 1383
594 10 1385 1384 1386
595 10 1388 1387 1389
596 10 1391 1390 1392
597 10 1394 1393 1395
598 10 1397 1396 1398
599 10 1400 1399 1401
600 10 1403 1402 1404
601 10 1406 1405 1407
602 10 1409 1408 1410
603 10 1412 1411 1413
604 10 1415 1414 1416
605 10 1418 1417 1419
606 10 1421 1420 1422
607 10 1424 1423 1425
608 10 1427 1426 1428
609 10 1430 1429 1431
610 10 1433 1432 1434
611 10 1436 1435 1437
612 10 1439 1438 1440
613 10 1442 1441 1443
614 10 1445 1444 1446
615 10 1448 1447 1449
616 10 1451 1450 1452
617 10 1454 1453 1455
618 10 1457 1456 1458
619 10 1460 1459 1461
620 10 1463 1462 1464
621 10 1466 1465 1467
622 10 1469 1468 1470
623 10 1472 1471 1473
624 10 1475 1474 1476
625 10 1478 1477 1479
626 10 1481 1480 1482
627 10 1484 1483 1485
628 10 1487 1486 1488
629 10 1490 1489 1491
630 10 1493 1492 1494
631 10 1496 1495 1497
632 10 1499 1498 1500
633 10 1502 1501 1503
634 10 1505 1504 1506
635 10 1508 1507 1509
636 10 1511 1510 1512
637 10 1514 1513 1515
638 10 1517 1516 1518
639 10 1520 1519 1521
640 10 1523 1522 1524
641 10 1526 1525 1527
642 10 1529 1528 1530
643 10 1532 1531 1533
644 10 1535 1534 1536
645 10 1538 1537 1539
Dihedrals
1 1 4 5 6 12
2 2 4 5 6 8
3 3 5 6 12 15
4 4 8 16 12 15
5 1 12 15 16 22
6 2 12 15 16 18
7 3 15 16 22 25
8 4 18 26 22 25
9 1 22 25 26 32
10 2 22 25 26 28
11 3 25 26 32 35
12 4 28 36 32 35
13 1 32 35 36 42
14 2 32 35 36 38
15 3 35 36 42 45
16 4 38 46 42 45
17 1 42 45 46 52
18 2 42 45 46 48
19 3 45 46 52 55
20 4 48 56 52 55
21 1 52 55 56 62
22 2 52 55 56 58
23 3 55 56 62 65
24 4 58 66 62 65
25 1 62 65 66 72
26 2 62 65 66 68
27 3 65 66 72 75
28 4 68 76 72 75
29 1 72 75 76 82
30 2 72 75 76 78
31 3 75 76 82 85
32 4 78 86 82 85
33 1 82 85 86 92
34 2 82 85 86 88
35 3 85 86 92 95
36 4 88 96 92 95
37 5 86 92 95 96
#Initialization
#PPO in water
units real
newton on
atom_style full
kspace_style pppm/tip4p 1.0e-4
#Force-Field
pair_style lj/cut/tip4p/long 11 12 4 10 0.15 10.0 lj/cut/coul/long 10.0 10.0 buck/coul/long 10.0 10.0
bond_style harmonic
angle_style harmonic
dihedral_style opls
special_bonds lj/coul 0 0 0 #I tried with and without this
#Forcefield params
pair_coeff 1 1 buck/coul/long 2649 0.267379679 27.4 #H-H
pair_coeff 2 2 buck/coul/long 14976 0.323624595 640.8 #C-C
pair_coeff 3 3 buck/coul/long 75844 0.246123554 398.9 #OP-OP
pair_coeff 4 4 lj/cut/tip4p/long 0.1852 3.1589 #OW-OW
pair_coeff 5 5 lj/cut/tip4p/long 0 0 #HW-HW
pair_coeff 1 2 buck/coul/long 4320 0.292825769 138.2 #H-C
pair_coeff 1 3 buck/coul/long 14176 0.256278831 104.5 #H-O
pair_coeff 1 4 lj/cut/coul/long 0.048068143 2.824373191 #H-OW
pair_coeff 1 5 lj/cut/coul/long 0 0 #H-HW
pair_coeff 2 3 buck/coul/long 33702 0.27956388 505.6 #C-O
pair_coeff 2 4 lj/cut/coul/long 0.18147044 2.943377863 #C-OW
pair_coeff 2 5 lj/cut/coul/long 0 0 #c-HW
pair_coeff 3 4 lj/cut/coul/long 0.201078728 3.191529042 #O-OW
pair_coeff 3 5 buck/coul/long -60.24 0.5 0 #O-HW
pair_coeff 4 5 lj/cut/tip4p/long 0 0 #OW-HW
group ppo type 1:3
group water type 4 5
group oxygen type 4
dielectric 1.0
fix fShakeTIP4P water shake 0.0001 10 100 b 1 a 1
#bond
bond_coeff 1 327.5 1.09
bond_coeff 2 369.5 1.40
bond_coeff 3 309.0 1.513
bond_coeff 4 300.0 0.9572
#angle
angle_coeff 1 38.5 108.3004824
angle_coeff 2 56 110.070922
angle_coeff 3 74.5 109.2344036
angle_coeff 4 59.5 111.1652714
angle_coeff 5 59.5 107.6644993
angle_coeff 6 42.9 109.4865051
angle_coeff 7 42.9 109.4865051
angle_coeff 8 59.5 105.9570851
angle_coeff 9 74.5 108.3348599
angle_coeff 10 75 104.52
#dihedrals
dihedral_coeff 1 -0.5 -0.24 -1.13 0
dihedral_coeff 2 -0.14 0.12 0 0
dihedral_coeff 3 -0.29 -2.44 -0.74 0
dihedral_coeff 4 1.97 0.03 0 0
dihedral_coeff 5 0.485 -0.34 -0.34 0
– minimization protocol –
include “system.in.init”
read_data “system.data”
include “system.in.settings”
#minimization
unfix fShakeTIP4P #if there is already fixed shake then we have to unfix it
thermo 10 #thermodynamic output at N timesteps
variable Nrun equal 10000
variable Nf equal {Nrun}/1000 variable Ne equal 10 variable Nr equal {Nf}/{Ne} variable Ndump equal {Nrun}/1000
variable Nr_rdf equal 0.5*{Nrun}/{Ne}
variable watMoleMass equal 18.0153 # /(g/mol)
variable ppoMoleMass equal 568 # /(g/mol)
variable nAvog equal 6.0221415e23 # Avogadro’s number
variable watMoleculeMass equal ({watMoleMass}/{nAvog}) # /(g/molecule)
variable ppoMoleculeMass equal ({ppoMoleMass}/{nAvog}) # /(g/molecule)
variable A3_in_cm3 equal 1e-24 # Angstrom^3 in cm^3
variable nAtoms equal 1515
variable nMolecules equal 480
variable Text equal 298.0
variable Pext equal 1.0
min_style sd #default is cg
dump 1 all custom 50 traj_min.lammpstrj id mol type x y z ix iy iz
minimize 1.0e-03 1.0e-5 100000 400000
#write coordinates after minization
write_data system_after_min.data
write_restart system_after_min.rst
Now read “system.in.settings” in order to enable Shake again:
#include “system.in.init”
include system.in.settings
Optional: write the coordinates after minimization
– simulation protocol –
undump 1
velocity all create {Text} 1234 timestep 1 dump 2 all custom 500 traj_npt.lammpstrj id mol type x y z ix iy iz fix fxnpt ppo npt temp {Text} {Text} 100.0 iso {Pext} {Pext} 1000.0 drag 1.0 fix fxnpt1 water npt temp {Text} {Text} 100.0 iso {Pext} {Pext} 1000.0 drag 1.0 compute T all temp fix TempAve all ave/time {Ne} {Nr} {Nf} c_T
variable P equal press
fix PressAve all ave/time {Ne} {Nr} {Nf} v_P compute PE all pe pair kspace variable PE_Mol equal c_PE/v_nMolecules fix PEAve_Mol all ave/time {Ne} {Nr} {Nf} v_PE_Mol
variable Dens equal (v_nMolecules*({watMoleculeMass})+{ppoMoleculeMass})/(vol*{A3_in_cm3}) fix DensAve all ave/time {Ne} {Nr} {Nf} v_Dens file system.dens
compute msd water msd com yes
fix msd water ave/time 1 1 500 c_msd[4] file wat.msdsh
compute rdf oxygen rdf 1000 5 5 # oxygen-oxygen
fix rdf oxygen ave/time {Ne} {Nr_rdf} ${Nrun} c_rdf file wat.rdf mode vector
compute cal_rg ppo gyration
fix rg ppo ave/time 1000 1 1000 c_cal_rg file ppo.rg
thermo_style custom step temp f_TempAve press f_PressAve f_DensAve
thermo_modify flush yes
thermo {Nf} dump trj all atom {Ndump} ppowater.lammpstrj
run ${Nrun}
write_restart restart.sys
write_data system_after_npt.data
Your zero-th step energy is very positive meaning you have a bad structure (e.g. overlap) or a bad potential.
Ray
