Error in trying out MCSQS
Hello. I am trying to get a hang of the mcsqs programme. To do so, I have copied the rndstr.in file from Table 2 of the paper "EfM-oM-,M-^Acient stochastic generation of special quasirandom structures" , and run the command : corrdump -l = rndstr.in -ro -noe -nop -clus -2 = 6 -3= 5.2 -4 = 5.2
This generated the cluster.out file. But on running the command: mcsqs -n= 60
, as given in the paper I am getting the following error : "Please drop irrelevant species when site is fully occupied with one specie"
Am i doing anything wrong?
I just tried that and I cannot reproduce your error. Could you double check if you have the correct input file rndstr.in as Table 2 in the paper?
For me, I put Nb=0.5 instead of Nb = 0.5 in rndstr.in it worked.
Thanks!
