Hi
I’m trying to use (pair_style hybrid lj/charmm/coul/charmm 9.0 10.0 eam)
which I get the following error,
Can anyone please help me understand where is my problem?
Thank you in advance
WARNING: Using a manybody potential with bonds/angles/dihedrals and special_bond exclusions (…/pair.cpp:196)
[Ale:00559] *** Process received signal ***
[Ale:00559] Signal: Segmentation fault (11)
[Ale:00559] Signal code: Address not mapped (1)
[Ale:00559] Failing at address: 0x30
[Ale:00559] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x10340) [0x7f4135cf8340]
[Ale:00559] [ 1] lammps-daily() [0x9b3119]
[Ale:00559] [ 2] lammps-daily() [0x9b3774]
[Ale:00559] [ 3] lammps-daily() [0x9b37f5]
[Ale:00559] [ 4] lammps-daily() [0xa19879]
[Ale:00559] [ 5] lammps-daily() [0x816c2c]
[Ale:00559] [ 6] lammps-daily() [0x7060bf]
[Ale:00559] [ 7] lammps-daily() [0x77d2fb]
[Ale:00559] [ 8] lammps-daily() [0xef78ce]
[Ale:00559] [ 9] lammps-daily() [0x776726]
[Ale:00559] [10] lammps-daily() [0x775039]
[Ale:00559] [11] lammps-daily() [0x77594d]
[Ale:00559] [12] lammps-daily() [0x4126b6]
[Ale:00559] [13] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7f4135944ec5]
[Ale:00559] [14] lammps-daily() [0x416b6f]
[Ale:00559] *** End of error message ***
Segmentation fault (core dumped)
