I get the following error:
ERROR: Incorrect args for pair coefficients (src/KSPACE/pair_lj_long_coul_long.cpp:196)
Last command: read_data step3_input.data
I have the following input file:
echo screen
variable dcdfreq index 5000
variable outputname index step5_production
variable inputname index step4.1_equilibration
units real
newton off
pair_style lj/long/coul/long long off 10
pair_modify mix arithmetic
kspace_style pppm 1e-6
kspace_modify force/disp/real 0.0001
kspace_modify force/disp/kspace 0.002
atom_style full
bond_style harmonic
angle_style charmm
dihedral_style charmm
special_bonds lj/coul 0.0 0.0 1.0
improper_style harmonic
timestep 2
variable laststep file {inputname}.dump** **next laststep** **read_dump {inputname}.dump ${laststep} x y z vx vy vz ix iy iz box yes replace yes format native
neighbor 2 bin
neigh_modify delay 5 every 1
fix 2 all npt temp 310.15 310.15 100.0 iso 0.9869233 0.9869233 1000 couple xyz mtk no pchain 0
thermo {dcdfreq}** **thermo_style custom step time xlo xhi ylo yhi zlo zhi etotal pe ke temp press ebond eangle edihed eimp evdwl ecoul elong temp vol ** **dump 1 all dcd {dcdfreq} {outputname}.dcd** **dump_modify 1 unwrap yes** **dump 2 all custom {dcdfreq} {outputname}.dump id type x y z vx vy vz ix iy iz** **dump_modify 2 append no** **write_data {outputname}.data
reset_timestep 0
run 50000
And a part of my data file:
** 1819 atoms**
** 1221 bonds**
** 642 angles**
** 95 dihedrals**
** 1 impropers**
** 11 atom types**
** 12 bond types**
** 22 angle types**
** 41 dihedral types**
** 1 improper types**
** -13.5000 13.5000 xlo xhi**
** -13.5000 13.5000 ylo yhi**
** -13.5000 13.5000 zlo zhi**
Masses
** 1 1.008 # HGA1**
** 2 1.008 # HGA2**
** 3 1.008 # HGP1**
** 4 1.008 # HT**
** 5 12.011 # CG2O2**
** 6 12.011 # CG301**
** 7 12.011 # CG311**
** 8 12.011 # CG321**
** 9 15.999 # OG2D1**
** 10 15.999 # OG311**
** 11 15.999 # OT**
Pair Coeffs
** 1 0.04500000000000 2.38760856461611 0.04500000000000 2.38760856461611 # HGA1**
** 2 0.03500000000000 2.38760856461611 0.03500000000000 2.38760856461611 # HGA2**
** 3 0.04600000000000 0.40001352444501 0.04600000000000 0.40001352444501 # HGP1**
** 4 0.04600000000000 0.40001352444501 0.04600000000000 0.40001352444501 # HT**
** 5 0.09800000000000 3.02905564167715 0.09800000000000 3.02905564167715 # CG2O2**
** 6 0.03200000000000 3.56359487256136 0.01000000000000 3.38541512893329 # CG301**
** 7 0.03200000000000 3.56359487256136 0.01000000000000 3.38541512893329 # CG311**
** 8 0.05600000000000 3.58141284692416 0.01000000000000 3.38541512893329 # CG321**
** 9 0.12000000000000 3.02905564167715 0.12000000000000 2.49451641079295 # OG2D1**
** 10 0.19210000000000 3.14487247503540 0.19210000000000 3.14487247503540 # OG311**
** 11 0.15210000000000 3.15057422683150 0.15210000000000 3.15057422683150 # OT**
I would be grateful if you could tell me what the error is in one of the two files.
