I am trying to simulate a hierarchical carbon structure containing DMSO (C2H6OS) organic solvent using ReaxFF. My reactive forcefield file contains the parametric values for all the atoms types present in the structure (i.e., C, H, O, and S). However, my simulation gives following error;
“ERROR: Incorrect args for pair coefficients (src/USER-REAXC/pair_reaxc.cpp:309)”
Here is given below the input script. Kindly let me know how to fix it. Thanks
REAXff - MFI type ZTC
-------------------- Init Section ----------------------
units real
atom_style charge
#bond_style harmonic
#angle_style harmonic
#dihedral_style harmonic
pair_style reax/c NULL
-------------------- Atom Definition Section ------------
read_data MFI_dmso.out
#change_box all x final 0 20 y final 0 20 z final 0 20
group C type 1 # C
group dmso type 2 3 4 5
group S type 2
group O_solvent type 3
group C_solvent type 4
group H_solvent type 5
#--------------------- Pair Coefficients ------------------------
pair_coeff * * ffield.reax.LIS C H O S
-------------------- Settings Section -------------------
neighbor 2 bin
neigh_modify every 10 delay 0 check no
timestep 0.1
fix 2 all qeq/reax 1 0.0 10.0 1e-4 reax/c
-------------------- Minimization -------------------
#fix 1 all nvt temp 300.0 300.0 500.0
fix 1 all npt temp 300.0 300.0 100.0 iso 10.0 10.0 2500.0
thermo 10
dump 1 all atom 1000 FAU-npt*.lammpstrj
run 100
thermo 100
thermo_style custom step time temp press pe ke etotal epair enthalpy vol density
min_style cg
minimize 1.0e-10 1e-10 10000 10000
write_data MFImin.data
