When I use the OPLS force field to generate a data file, I got errors.
CH3
C(=N-O)-CH2-CH3
|-(NH2)
(SMILES : CC(CC)C(=NO)N )
ITEM OPTIONS
replace true
mass true
ntotal 20
field opls
build_dir .
ITEM END
ITEM SHORTHAND
AO CC(CC)C(=NO)N,1
ITEM END
ITEM GROUPS
AO CC(CC)C(=NO)N
ITEM END
ITEM CLUSTERS
AO AO,1
ITEM END
There are commands that i used :
perl emc_setup.pl 1.esh
emc_win32 build.emc
then errors ccoming:
Info: variables = {seed → -1, ntotal → 20, fshape → 1, output → “1”, field
→ “opls/2012/opls-aa”, location1 → “C:/emc944/field/”, nav →
0.6022141179, temperature → 300, radius → 5, nrelax → 100,
weight_nonbond → 0.0001, weight_bond → 0.0001, weight_focus → 1,
cutoff → 9.5, charge_cutoff → 9.5, kappa → 4, density1 → 1,
lprevious → 0, lphase → 0, f_AO → 1, chem_AO → “CC(CC)C(=NO)N”}
Info: output =
{detail → 3, wide → false, expand → false, math → true, reduced →
false, info → true, strict → true, warning → true, message → true,
debug → false, exit → true, ignore → false}
Info: field = {id → opls, mode → opls, style → none, name →
{“C:/emc944/field/opls/2012/opls-aa.prm”,
“C:/emc944/field/opls/2012/opls-aa.top”}, compress → false, error
→ true, debug → false, check → {atomistic → true, charge → true}}
Info: importing ‘C:/emc944/field/opls/2012/opls-aa.prm’
Warning: undefined periodic element ‘LP’.
Warning: undefined periodic element ‘OW3P’.
Warning: undefined periodic element ‘OW3F’.
Info: groups = {ngroups → 1, group →
{id → AO, chemistry → “CC(CC)C(=NO)N”, depth → 8, charges →
forcefield, charge → 0, terminator → false, bias → none},
ndeletes → 0, npolymers → 0}
Info: field = {mode → apply, style → none, error → true, debug → false,
Info: applying ‘C:/emc944/field/opls/2012/opls-aa.prm’
Warning: missing rules for field ‘C:/emc944/field/opls/2012/opls-aa.prm’.
Warning: missing rule for {group, site} = {AO, 13}.
Warning: missing rule for {group, site} = {AO, 14}.
Warning: missing rule for {group, site} = {AO, 15}.
Warning: missing rule for {group, site} = {AO, 16}.
Warning: missing rule for {group, site} = {AO, 17}.
Warning: missing rule for {group, site} = {AO, 18}.
Warning: missing rule for {group, site} = {AO, 19}.
Error: core/fields.c:432 FieldsApply:
Missing rules.
Program aborted.
AND
If i want to use C(C)C(=NO)N (called A) and C(C)C(=O)N (called B) groups for building a polymer like methyl - [ (A)5 - (B)5 - (A)5 ] 10 - methyl with opls-aa , would you please show me some detail steps and codes?
OR
I have build some polymers pdb file , how to import those pdb files to build data files using EMC
