ERROR: Invalid fix ave/time argument
Dear answerer, hello. I am running a water - sphere system with 1000 water molecules on LAMMPS【LAMMPS (2 Aug 2023 - Update 3)】
, and I want to calculate its surface tension using the Irving - Kirkwood pressure - tensor method, according to the template on the official website:
So I ran the following input file:
{412B6712-3E3C-4574-B5FB-F677DFF74D57}
However, the following errors occurred.
May I ask how to solve it?
Do not just blindly copy from the documentation, but read and understand it, since there can be typos.
The error message is self-explanatory. Do you have a compute with the compute-id “p”? Apparently not and hence the error.
Thank you very much for your reply. It was my carelessness. The problem has been solved. Wish you a happy life~
