I am trying to build a model consisting in a fluid between 2 layers of copper but lammps gives me an error I don’t know how to solve. Apparently the pair style to set the potentials is incorrect, but I don’t know how to tell lammps I want to use an eam potential for copper and a lj potential for the fluid (and the interaction between the fluid an the copper). I copy part of the script:
echo both
boundary p s p
atom_style atomic
neighbor 2.0 bin
neigh_modify delay 1
create geometry
region total block 0 108.45 0 216.9 0 108.45 units box
create_box 2 total
region fluid block 0 108.45 72.3 144.6 0 108.45 units box
lattice fcc 3.61500000000000021316 orient x 1 0 0 orient y 0 1 0 orient z 0 0 1
region copper-down block 0 108.45 0 72.3 0 108.45 units box
region copper-up block 0 108.45 144.6 216.9 0 108.45 units box
create atoms and set potentials
create_atoms 1 region copper-down
mass 1 1.0
create_atoms 2 random 10000 482748 fluid
mass 2 1.0
create_atoms 1 region copper-up
mass 1 1.0
pair_style hybrid eam/alloy lj/cut/6.17
pair_coeff 1 1 Cu_mishin1.eam.alloy Cu
pair_coeff 1* 2 1.0 1.0
Thank you in advance for your help.
