Hello list,
I am trying to use kim for lammps simulation. I can see that my model and model driver are installed under “kim-api-collections-management list”:
User Collection
lammps_input (571 Bytes)
amp.params (9.42 KB)
Hello list,
User Collection
Can you please provide versions for the kim-api and lammps?
Ryan
I installed both kim-api and lammps fresh.
kim-api following the instructions here: https://github.com/openkim/kim-api/blob/master/INSTALL, so must be kim-api-2.0.2, and lammps version LAMMPS (29 Mar 2019).
Regards,
Alireza
OK,
Is there a kim.log file generated when you execute lammps? What is in it?
How did you build lamms?
Can you provide the full output of
$ kim-api-collections-management list
and
$ ldd ../../../lammps/build/lmp
Ryan
Sure! See attached please. Also I build lammps by:
$ cd lammps && mkdir build && cd build
$ cmake -D CMAKE_C_COMPILER=gcc -D CMAKE_CXX_COMPILER=g++ -D CMAKE_Fortran_COMPILER=gfortran -D PKG_KIM=on -D KIM_LIBRARY=$"/usr/local/lib/libkim-api.so" -D KIM_INCLUDE_DIR=$"/usr/local/include/kim-api" ../cmake
$ make
Regards,
Alireza
kim-management.txt (2.04 KB)
kim.log (480 Bytes)
ldd-lammps.txt (849 Bytes)
Hi Alireza,
OK, The problem is that the installed model has a mispelled name. It is "amp_parametrized_model" instead of "amp_parameterized_model" which is what you have in the lammps input script.
Cheers,
Ryan
Oh! My bad! Thanks Ryan! Everything works fine now. Thanks also for the quick response!
Regards,
Alireza
