Hi
I am coding a new pair style and in the course of testing the model we discovered that we can’t run ewald sums with our pair style. What do I need to do to the code to make it compatible?
thanks much
matthew
Hi
thanks much
matthew
Hi
discovered that we can't run ewald sums with our pair style. What do I need
well, first of all, you need to code the corresponding real-space part
of the coulomb interactions, see lj/cut/coul/long or lj/long/coul/long
or lj/long or lj/cut/coul/msm or lj/cut/tip4p/long and so on.
also, there are a bunch of flags defined in pair.h, that you can set
in the constructor of your pair style to signal, which kinds of
long-range interactions, your pair style is compatible with:
int ewaldflag; // 1 if compatible with Ewald solver
int pppmflag; // 1 if compatible with PPPM solver
int msmflag; // 1 if compatible with MSM solver
int dispersionflag; // 1 if compatible with LJ/dispersion solver
int tip4pflag; // 1 if compatible with TIP4P solver
int dipoleflag; // 1 if compatible with dipole solver
int reinitflag; // 1 if compatible with fix adapt and alike
again, please see the corresponding pair style implementations for examples.
