Respected Lammps users, I am using lammps 15 July 2023 and march 2023 widowns version mpi, After installation of march 2023 version doesnt contain lm_mpi.exe file in bin after which I downloaded july 2023. I need to use mpi run as it works for few hours then suddenly shutdown showing an error. Kindly assist to resolve it. In addition is it better to use OMP multithreded run rather than to use mpi as I used both of these together worked but the speed was not so fast as mpi alone? Below are the specs of computer. Thanks
Device Name DESKTOP
Processor Intel(R) Core™ i3-8100 CPU @ 3.60GHz 3.60 GHz
Installed RAM 12.0 GB (11.8 GB usable)
Storage 112 GB SSD KINGSTON SA400S37120G, 932 GB HDD ST1000DM010-2EP102
Graphics Card Intel(R) UHD Graphics 630 (128 MB)
Device ID 44DD6510-9996-4166-B7FE-BF390590DD48
Product ID 00331-10000-00001-AA428
System Type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
using command like this…
E:\New folder\New folder2>mpiexec -n 4 lmp_mpi.exe -in in.mfacetwet
this error comes out
Error while connecting to host, No connection could be made because the target machine actively refused it. (10061)
Connect on sock (host=DESKTOP, port=8676) failed, exhaused all end points
Unable to connect to 'DESKTOP-PHPOCSJ:8676',
sock error: Error = -1```
