Dear LAMMPS community,
I got an error when I run this code, it is a compression and shear test. When I use p s s as the boundary condition, I don’t receive any errors but the box in the compression direction was forced to separate with part of the atoms like in the attached figure. When I use p f s, I got error :lost atoms. And I am also wondering on what condition I can use ‘lost ignore’? How do I fix this? Many thanks.
3d metal simulation
boundary p f s
atom_style atomic
read_data Au_xyz.data
pair_style eam/fs
pair_coeff * * Mendelev_Cu2_2012.eam.fs Cu Cu Cu Cu
region lower block INF INF INF 10 INF INF
region upper block INF INF 446 INF INF INF
group lower region lower
group upper region upper
group boundary union lower upper
group mobile subtract all boundary
equilibrate
min_style cg
minimize 0.0 1.0e-8 5000 100000
reset_timestep 0
timestep 0.001
velocity all create 300 12345 mom yes rot no
fix 1 all npt temp 300 300 0.1 x 0 0 1 drag 1
fix 2 boundary setforce NULL 0.0 0.0
velocity boundary set NULL 0.0 0.0 units box
thermo 1000
thermo_style custom step lx ly lz press pxx pyy pzz pe temp
run 50000
unfix 1
unfix 2
shear and compressive
reset_timestep 0
timestep 0.001
fix 1 all nvt temp 300 300 0.1 drag 1
variable srate equal 2.0e8
variable srate1 equal “-v_srate / 1.0e12”
fix 3 all deform 1 y erate ${srate1} units box remap x
dump 1 all custom 20000 dump.shear.*.txt id type x y z
dump_modify 1 sort id
thermo 1000
thermo_style custom step temp v_p2 v_p3 v_p4 ke pe press
#shear
label loopa
variable a loop 50
run 0
displace_atoms upper ramp z 0 0.20 y 0 456 units box
run 1000
next a
jump shear3 loopa
