I am trying to build LAMMPS using cygwin for windows OS. I have done everything succesfully i.e include necessary libraries, packages etc. Now when I run the makefile to create the executable, I am getting an error message which says
recipe for target ‘update.o’ failed
recipe for target ‘cygwin’(this is makefile.cygwin) failed
Below I have added my makefile for your reference.
cygwin serial = cygwin, g++4, no MPI, no FFTs
SHELL = /bin/sh
compiler/linker settings
specify flags and libraries needed for your compiler
CC = g++
CCFLAGS = -O
SHFLAGS = -fPIC
DEPFLAGS = -M
LINK = g++
LINKFLAGS = -O
LIB =
SIZE = size
ARCHIVE = ar
ARFLAGS = -rc
SHLIBFLAGS = -shared
LAMMPS-specific settings
specify settings for LAMMPS features you will use
if you change any -D setting, do full re-compile after “make clean”
LAMMPS ifdef settings, OPTIONAL
see possible settings in doc/Section_start.html#2_2 (step 4)
LMP_INC = -DLAMMPS_GZIP -DLAMMPS_XDR
MPI library, REQUIRED
see discussion in doc/Section_start.html#2_2 (step 5)
can point to dummy MPI library in src/STUBS as in Makefile.serial
INC = path for mpi.h, MPI compiler settings
PATH = path for MPI library
LIB = name of MPI library
MPI_INC = -I/cygdrive/f/lammps/lammps-22feb13/src/STUBS
MPI_PATH = -L/cygdrive/f/lammps/lammps-22feb13/src/STUBS
MPI_LIB = -lmpi_stubs
FFT library, OPTIONAL
see discussion in doc/Section_start.html#2_2 (step 6)
can be left blank to use provided KISS FFT library
INC = -DFFT setting, e.g. -DFFT_FFTW, FFT compiler settings
PATH = path for FFT library
LIB = name of FFT library
FFT_INC = -DFFT_FFTW -I/cygdrive/c/cygwin/usr/local/include
FFT_PATH = -L/cygdrive/c/cygwin/usr/local/lib
FFT_LIB = lfftw
JPEG library, OPTIONAL
see discussion in doc/Section_start.html#2_2 (step 7)
only needed if -DLAMMPS_JPEG listed with LMP_INC
INC = path for jpeglib.h
PATH = path for JPEG library
LIB = name of JPEG library
JPG_INC =
JPG_PATH =
JPG_LIB =
build rules and dependencies
no need to edit this section
include Makefile.package.settings
EXTRA_INC = (LMP_INC) (PKG_INC) (MPI_INC) (FFT_INC) (JPG_INC) (PKG_SYSINC)
EXTRA_PATH = (PKG_PATH) (MPI_PATH) (FFT_PATH) (JPG_PATH) (PKG_SYSPATH)
EXTRA_LIB = (PKG_LIB) (MPI_LIB) (FFT_LIB) (JPG_LIB) (PKG_SYSLIB)
Link target
(EXE): (OBJ)
(LINK) (LINKFLAGS) (EXTRA_PATH) (OBJ) (EXTRA_LIB) (LIB) -o (EXE)
(SIZE) $(EXE)
Library targets
lib: (OBJ) (ARCHIVE) (ARFLAGS) (EXE) $(OBJ)
shlib: (OBJ) (CC) (CCFLAGS) (SHFLAGS) (SHLIBFLAGS) (EXTRA_PATH) -o (EXE) \ (OBJ) (EXTRA_LIB) (LIB)
Compilation rules
.o:.cpp
(CC) (CCFLAGS) (SHFLAGS) (EXTRA_INC) -c $<
.d:.cpp
(CC) (CCFLAGS) (EXTRA_INC) (DEPFLAGS) < > @
Individual dependencies
DEPENDS = (OBJ:.o=.d) sinclude (DEPENDS)
