Error module 'numpy.linalg._umath_linalg' has no attribute '_ilp64'
AttributeError Traceback (most recent call last)
in <cell line: 4>() 2 from pymatgen.ext.matproj import MPRestError 3 ----> 4 m = MPRester(“mZAFPBh1vstjOmsFo28”)
13 frames
/usr/local/lib/python3.10/dist-packages/pymatgen/ext/matproj.py in new(cls, *args, **kwargs) 389 390 if len(api_key) != 32: → 391 from pymatgen.ext.matproj_legacy import _MPResterLegacy 392 393 return _MPResterLegacy(*args, **kwargs)
/usr/local/lib/python3.10/dist-packages/pymatgen/ext/matproj_legacy.py in 30 from pymatgen.core.structure import Structure 31 from pymatgen.core.surface import get_symmetrically_equivalent_miller_indices —> 32 from pymatgen.entries.computed_entries import ComputedEntry, ComputedStructureEntry 33 from pymatgen.entries.exp_entries import ExpEntry 34 from pymatgen.symmetry.analyzer import SpacegroupAnalyzer
/usr/local/lib/python3.10/dist-packages/pymatgen/entries/computed_entries.py in 18 import numpy as np 19 from monty.json import MontyDecoder, MontyEncoder, MSONable —> 20 from scipy.interpolate import interp1d 21 from uncertainties import ufloat 22
/usr/local/lib/python3.10/dist-packages/scipy/interpolate/init.py in 165 (should not be used in new code). 166 “”" → 167 from ._interpolate import * 168 from ._fitpack_py import * 169
/usr/local/lib/python3.10/dist-packages/scipy/interpolate/_interpolate.py in 10 from scipy.special import comb 11 —> 12 from . import _fitpack_py 13 from . import dfitpack 14 from ._polyint import _Interpolator1D
/usr/local/lib/python3.10/dist-packages/scipy/interpolate/_fitpack_py.py in 8 from ._fitpack_impl import bisplrep, bisplev, dblint # noqa: F401 9 from . import _fitpack_impl as _impl —> 10 from ._bsplines import BSpline 11 12
/usr/local/lib/python3.10/dist-packages/scipy/interpolate/_bsplines.py in 7 cholesky_banded, cho_solve_banded, 8 solve, solve_banded) ----> 9 from scipy.optimize import minimize_scalar 10 from . import _bspl 11 from . import _fitpack_impl
/usr/local/lib/python3.10/dist-packages/scipy/optimize/init.py in 408 409 from ._optimize import * → 410 from ._minimize import * 411 from ._root import * 412 from ._root_scalar import *
/usr/local/lib/python3.10/dist-packages/scipy/optimize/_minimize.py in 25 from ._trustregion_krylov import _minimize_trust_krylov 26 from ._trustregion_exact import _minimize_trustregion_exact —> 27 from ._trustregion_constr import _minimize_trustregion_constr 28 29 # constrained minimization
/usr/local/lib/python3.10/dist-packages/scipy/optimize/_trustregion_constr/init.py in 2 3 ----> 4 from .minimize_trustregion_constr import _minimize_trustregion_constr 5 6 all = [‘_minimize_trustregion_constr’]
/usr/local/lib/python3.10/dist-packages/scipy/optimize/_trustregion_constr/minimize_trustregion_constr.py in 3 from scipy.sparse.linalg import LinearOperator 4 from .._differentiable_functions import VectorFunction ----> 5 from .._constraints import ( 6 NonlinearConstraint, LinearConstraint, PreparedConstraint, Bounds, strict_bounds) 7 from .._hessian_update_strategy import BFGS
/usr/local/lib/python3.10/dist-packages/scipy/optimize/_constraints.py in 6 from ._optimize import OptimizeWarning 7 from warnings import warn, catch_warnings, simplefilter ----> 8 from numpy.testing import suppress_warnings 9 from scipy.sparse import issparse 10
/usr/local/lib/python3.10/dist-packages/numpy/testing/init.py in 9 10 from . import _private —> 11 from ._private.utils import * 12 from ._private.utils import (_assert_valid_refcount, _gen_alignment_data) 13 from ._private import extbuild
/usr/local/lib/python3.10/dist-packages/numpy/testing/_private/utils.py in 55 IS_PYSTON = hasattr(sys, “pyston_version_info”) 56 HAS_REFCOUNT = getattr(sys, ‘getrefcount’, None) is not None and not IS_PYSTON —> 57 HAS_LAPACK64 = numpy.linalg._umath_linalg._ilp64 58 59 _OLD_PROMOTION = lambda: np._get_promotion_state() == ‘legacy’
AttributeError: module ‘numpy.linalg._umath_linalg’ has no attribute ‘_ilp64’
This error happen on MPRester(“API”)
