Hello LAMMPS community,
I’m running a simple test for SPC/E water, a fairly trivial model, with geometry generated from MolTemplate, using equidistant spacing 3.45A between molecules. After setting up the geometry, I then run the nve + Langevin with 1K, and ‘kspace_style pppm 0.0001’ to perturb the geometry, before equilibrating the simulation cell.
Attached is the screenshot from VMD visualization, with periodic boundary condition. However, it returns with error:
Step Temp E_pair E_mol TotEng Press
0 0 3.1403491e+17 0 3.1403491e+17 -nan
and
ERROR on proc 2: Non-numeric atom coords - simulation unstable (…/domain.cpp:521)
I’ve also checked the units, and they seem correct. Units ‘real’ was used. I couldn’t see anything wrong with the setup. Would you please tell me what could have gone wrong for this simple simulation?
Many thanks,
Anh Tran
