Hi all
I encountered a problem when I tried to use the command fix addtorque to rotate two bodies (I have already installed the USER-MISC package). I received the error information “ERROR: Expected floating point parameter in input script or data file”.
I have referred to http://lammps.sandia.gov/threads/msg10089.html, but still have no clue.
Attached is my input file and data file, can any one give me some suggestions or feedback? I would really appreciate your kindly help.
Best regards
Yihua Zhou
data.nanoworm (1.34 MB)
in.nanoworm (5.93 KB)
Hi all
received the error information "ERROR: Expected floating point parameter in
input script or data file".
have no clue.
sorry, but those inputs are useless since they are using non-standard styles.
Hi all
have no clue.
the answer is the same, you use NULL and that is not a floating point
number (0.0 is).
