Error on LAMMPS tutorial 7 - Free energy calculation
https://lammpstutorials.github.io/sphinx/build/html/tutorial7/free-energy-calculation.html
“Run and data acquisition”
“The step count is reset to 0 using reset_timestep to synchronize it with the output times of fix density/number . Run the simulation using LAMMPS.”
Got error messages as follows:
“ERROR: Cannot reset timestep with active dump - must undump first (src/output.cpp:641)
Last command: reset_timestep 0”
Thanks for reporting. Just to be sure, what version of LAMMPS are you using?
Simon
@simongravelle FYI, this is the behavior of LAMMPS since version 15Sep2022.
29Aug2024
Another issue need to be corrected on this page.
" Method 2: Umbrella sampling"
" LAMMPS input script
If you are using LAMMPS–GUI, open the file named free-energy.lmp. Alternatively, if you are not using LAMMPS–GUI, create a new input file and paste in the following content."
Based on the context below, I think the “free-energy.lmp” here should be " umbrella-sampling.lmp"
Fixed: Fix error in tutorial7 by simongravelle · Pull Request #106 · lammpstutorials/lammpstutorials.github.io · GitHub
Thank you very much for reporting these issues to us.
Simon
