ERROR on proc 0: 1-3 bond count is inconsistent
I want to incorporate two molecules i.e, water and carbon dioxide on substrate using fix_gcmc in lammps. I have read the restrictions section given under fix_gcmc of lammps manual and saw the earlier posts. The link for the earlier post is as follows,
http://lammps.sandia.gov/threads/msg45624.html
I gone through the patch and compiled accordingly. When run the simulations, I got the following error
ERROR on proc 0: 1-3 bond count is inconsistent, I know this is error is due to mistake in making a topology file. I redefined the numbers for bonds , but got the same error. I am attaching the input files that I have considered. Please help to understand this error.
  1. I want to run gcmc calculations for multiple molecules, Can you give some suggestions.
The input read.data file is as follows,
Created by charmm2lammps v1.8.1 on Wed Oct 8 11:25:11 IST 2014
5216 atoms
516 bonds
2 angles
0 dihedrals
0 impropers
15 atom types
4 bond types
2 angle types
0 dihedral types
0 improper types
0.006 41.304 xlo xhi
0.011 71.711 ylo yhi
0.272 27.195 zlo zhi
Masses
1 15.999
2 15.999
3 15.999
4 15.999
5 15.999
6 24.305
7 22.9
8 28.086
9 26.982
10 26.982
11 1.008
12 12.0110 # C of CO2
13 15.9994 # O of CO2
14 15.994 # O of CO2
15 1.008 # O of CO2
Pair Coeffs
1 0.1554 3.166005
2 0.1554 3.166005
3 0.1554 3.166005
4 0.1554 3.166005
5 0.1554 3.166005
6 9.0298e-07 5.264321
7 0.1301 2.350013
8 1.8405e-06 3.302027
9 1.8405e-06 3.302027
10 1.3298e-06 4.271236
11 0 0
12 0.1554 3.166005
13 0.1554 3.166005
14 0.1554 3.166005
15 0.1554 3.166005
Atoms
1 1 8 2.1 4.424 26.807 19.175
2 2 8 2.1 4.434 32.861 19.173
3 3 8 2.1 1.818 31.307 19.139
4 4 8 2.1 1.886 28.338 19.176
5 5 8 2.1 2.816 35.641 24.617
6 6 8 2.1 2.798 29.632 24.62
7 7 8 2.1 5.424 31.165 24.573
8 8 8 2.1 5.354 34.154 24.541
9 9 8 2.1 9.577 26.827 19.10
513 3 1 2
514 3 1 3
515 4 1 2
516 4 1 3
Angle Coeffs
1 0.0 180 # HGP1 O311 HGP1
2 0.0 180 # HGP1 O311 HGP1
Angles
1 1 2 1 3 # HGP1 O311 HGP1
2 2 2 1 3 # HGP1 O311 HGP1
Thanks & Regards,
K. Mohan
co2.txt (349 Bytes)
co2_1.txt (359 Bytes)
in.gcmc_test (1.23 KB)
LAMMPS Molecular Dynamics Simulator
the data file is missing.
2) I want to run gcmc calculations for multiple molecules, Can you give some
suggestions.
LAMMPS doesn't support that currently.
Hello sir,
Please find the attached data file. But in the following post, you have given a patch to run gcmc for multiple molecules.
link: http://lammps.sandia.gov/threads/msg45616.html
Thanks & Regards,
K. Mohan Maruthi
test_org.data (370 KB)
Hello sir,
link: LAMMPS Molecular Dynamics Simulator
no, i have not. you have to pay more attention to what is shown there
and follow the entire discussion. the CH4 "molecule" in that example
is using a united atom model, i.e. it is represented by a single point
with an LJ potential. so the simulation is using only one molecule
with fix gcmc.
your (modified) data file defines the same pair of bonds twice.
