I use the “amset deform create” to produce the deformed structures
(base) [guodonglin@localhost Deformation]$ amset deform create
Generating deformations:
unicodeify_spacegroup is deprecated
These methods have been deprecated in favor of using the Stringify mix-in class, which providesto_latex_string, to_unicode_string, etc. They will be removed in v2022.
latexify_spacegroup is deprecated
Deformations:
- [ 1.00499 1.00000 1.00000 0.00000 0.00000 0.00000]
- [ 0.99499 1.00000 1.00000 0.00000 0.00000 0.00000]
- [ 1.00000 1.00000 0.99995 0.01000 0.00000 0.00000]
Deformed structures have been created
when the calculations are done, the commad “amset deform read undeformed def-1 def-2 def-3” is used to produce the deformations potentials, but the error is generated.
(base) [guodonglin@localhost Deformation]$ amset deform read undeformed def-1 def-2 def-3
Reading bulk (undeformed) calculation
Reading deformation calculation in def-1
Reading deformation calculation in def-2
Reading deformation calculation in def-3
Spacegroup: Fm3?m (225)
WARNING: Reciprocal lattice and k-lattice belong to different
class of lattices. Often results are still useful but
it is recommended to regenerate deformations without
symmetry using: amset deform create --symprec N
Found 3 strains:
- [ 0.005 0.000 0.000 0.000 0.000 0.000]
- [-0.005 0.000 0.000 0.000 0.000 0.000]
- [ 0.000 0.000 0.000 0.005 0.000 0.000]
After symmetrization found 12 strains:
- [ 0.000 0.005 0.000 0.000 0.000 0.000]
- [ 0.000 0.000 0.005 0.000 0.000 0.000]
- [ 0.000 -0.005 0.000 0.000 0.000 0.000]
- [ 0.000 0.000 -0.005 0.000 0.000 0.000]
- [ 0.000 0.000 0.000 0.000 -0.005 0.000]
- [ 0.000 0.000 0.000 -0.005 0.000 0.000]
- [ 0.000 0.000 0.000 0.000 0.005 0.000]
- [ 0.000 0.000 0.000 0.000 0.000 -0.005]
- [ 0.000 0.000 0.000 0.000 0.000 0.005]
ERROR: one or more k-point meshes do not cover the full BZ. If using
–symprec N please ensure that the VASP calculations were
performed using ISYM = -1. Alternatively, set --symprec to a
number, e.g. 0.1.
The INCAR is like this:
SYSTEM = GeTe
ENCUT=600
ISTART = 0
ICHARG = 2
NPAR = 1
PREC = Accurate
ISMEAR = -5
IBRION=-1
ADDGRID = True
EDIFF = 1E-8
PREC = Accurate
NSW = 1
ICORELEVEL = 1
the KPOINTS is like this:
A
0
G
23 23 23
0.0 0.0 0.0
How to solve this problem, “ERROR: one or more k-point meshes do not cover the full BZ.”
Thanks.
