ERROR: Out of range basis setting in create_atoms command
Hello everyone,
I’m trying to build a sphere using alumina in a custom lattice. The input seems to work well when I create a sphere with a specific radius. However, it doesn’t work with other radii, and also when I attempt to fill a box with Al2O3 using the this lattice, I encounter the same error: ‘ERROR: Out of range basis setting in create_atoms command.’
Sincerely, Abderrazak
That error message is a clear indication that the error has nothing to do with the radius of a sphere, but due to a typo or other omission in your custom latter or create_atoms command.
I greatly appreciate your response,
but If the error is related to the lattice or create_atoms commands, I think it will not work for any radius, but it works for one."
That statement makes no sense. I do know a little bit about how those commands are implemented and thus am quite confident in my statements. You may see a correlation, but that is no proof for causation.
If you want to get help in having this resolved, you have to provide tangible proof to confirm your statements.
Thank you very much. Upon verification, you are correct. The issue I’m facing is within the “create_atoms” command, specifically with the particle type. I have set a particle type in “create_atoms” that I did not declare in “read_data,” which I used to define my simulation box.
