hello users,
I am trying to simulate the CNT with hybrid pair_style. I am using only one type of atom.
When i run the simulation i am getting the following error
ERROR: Pair hybrid sub-style is not used (…/pair_hybrid.cpp:417)
here is the part of my input file.
pair_style hybrid tersoff lj/cut 3.4
pair_coeff * * tersoff SiC.tersoff C
pair_coeff * * lj/cut 0.002843732471143 3.4
If you use hybrid instead of hybrid/overlay, then
you can only assign one sub-style per type pair,
Thus your 2nd pair coeff command overrides the
first one and you are not using the tersoff sub style.
Thanks for your reply steve.
Then how i should define the pair_style to use both tersoff and lj/cut.
pair_style hybrid/overlay - see the doc page
As you said if i use hydid/overlay the first pair_style
will be over ride second pari_style.
But in my case i want to use both the pair_style together.
No, it will not. Please re-read the documentation.
There is a big difference between
hybrid and hybrid/overlay (see the doc page).
I think you want the latter.
