I am running a couple of LAMMPS scripts where the first one saves a dump file which is used in the other one. Both the scripts are running well on a windows machine but when I port it to a linux server, the first script saves the dump file properly. However, the second script fails to read this dump file with the following error :
Created orthogonal box = (0 0 0) to (10 10 10)
Scanning dump file …
Reading snapshot from dump file …
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= EXIT CODE: 11
= CLEANING UP REMAINING PROCESSES
= YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault (signal 11)
Any help will be appreciated.
Dr. M. Bhattacharya
