Error running the atomate MgO tutorial
I’ve recently tried to run the MgO tutorial for atomate. However, pymatgen cannot get the electron DOS from MongoDB.
When mgdb query is used, the following result is returned:
The task is added to the database
The OUTCAR seems to be normal
When I use the database in Mongodb and try to find the file by task_id, the following is returned
“schema” : {
“code” : “atomate”,
“version” : “0.9.5”
“state” : “successful”,
“task_id” : 6,
“task_label” : “structure optimization”,
“transformations” : {
It is found that the task_label is ‘structure optimization’ while in the python code for band structure analysis (bs-analysis.py in the tutorial) the task_label should be ‘nscf uniform’ in the database.
I’m wondering is there any change I can make to let the code work?
Also I’m not sure if the work is correctly done and all results added to the database. The outputs seem to be normal. But when I run lpad get_wflows.
It returns that the work is still running
“state”: “RUNNING”,
“name”: “MgO–8”,
“created_on”: “2020-09-23T12:02:44.240000”,
“states_list”: “W-W-REA-C”
However, when I use top to see the processes, there is no vasp process.
Here is the my_ fworker.yaml
category: ‘’
query: “{}”
env:
db_file: /home/admin123/atomate/config/db.json
vasp_cmd: mpirun --allow-run-as-root -np 48 /opt/vasp.5.4.1/build/std/vasp
scratch_dir: null
my_launchpad.yaml
authsource: atomate_db
host: master
logdir: null
mongoclient_kwargs: {}
password: null
port: 27017
ssl: false
ssl_ca_certs: null
ssl_certfile: null
ssl_keyfile: null
ssl_pem_passphrase: null
strm_lvl: INFO
uri_mode: false
user_indices: []
username: null
wf_user_indices: []
db.json
“admin_password”: “”,
“admin_user”: “”,
“aliases”: {},
“collection”: “tasks”,
“database”: “atomate_db”,
“host”: “master”,
“port”: 27017,
“readonly_password”: “”,
“readonly_user”: “”
my_qadapter.yaml
_fw_name: CommonAdapter
_fw_q_type: SLURM
rocket_launch: rlaunch -c /home/admin123/atomate/config singleshot
nodes: 1
walltime: 24:00:00
queue: simw
account: null
job_name: null
pre_rocket: null
post_rocket: null
logdir: /home/admin123/atomate/logs
Many thanks!
Bosang
Everything works fine now. I used qlaunch singleshot which indeed only submitted one FireWork. I’ve changed the rocker launcher in my_qadapter file from singleshot mode to rapidfire mode. {rlaunch -c /home/admin123/atomate/config rapidfire} .Then qlaunch rapidfire --nlaunches 0 completed the workflow!
