Error running VASP in offline mode
I’m trying to run atomate in offline mode because the compute nodes at our center cannot connect to the database. I have everything set up and running. But when I try to run any VASP workflows I get the following error in the FW_job.err file:
File “/home5/shonrao/miniconda3/lib/python3.7/site-packages/fireworks/core/rocket.py”, line 246, in run
Rocket.update_checkpoint(lp, launch_dir, launch_id, checkpoint)
File “/home5/shonrao/miniconda3/lib/python3.7/site-packages/fireworks/core/rocket.py”, line 443, in update_checkpoint
f_out.write(json.dumps(d, ensure_ascii=False))
File “/home5/shonrao/miniconda3/lib/python3.7/json/init.py”, line 238, in dumps
**kw).encode(obj)
File “/home5/shonrao/miniconda3/lib/python3.7/json/encoder.py”, line 199, in encode
chunks = self.iterencode(o, _one_shot=True)
File “/home5/shonrao/miniconda3/lib/python3.7/json/encoder.py”, line 257, in iterencode
return _iterencode(o, 0)
File “/home5/shonrao/miniconda3/lib/python3.7/json/encoder.py”, line 179, in default
raise TypeError(f'Object of type {o.__class__.__name__} '
TypeError: Object of type VaspJob is not JSON serializable
File “/home5/shonrao/miniconda3/bin/rlaunch”, line 10, in
sys.exit(rlaunch())
File “/home5/shonrao/miniconda3/lib/python3.7/site-packages/fireworks/scripts/rlaunch_run.py”, line 155, in rlaunch
launch_rocket(launchpad, fworker, args.fw_id, args.loglvl, pdb_on_exception=args.pdb)
File “/home5/shonrao/miniconda3/lib/python3.7/site-packages/fireworks/core/rocket_launcher.py”, line 58, in launch_rocket
rocket_ran = rocket.run(pdb_on_exception=pdb_on_exception)
File “/home5/shonrao/miniconda3/lib/python3.7/site-packages/fireworks/core/rocket.py”, line 415, in run
d = json.loads(f_in.read())
File “/home5/shonrao/miniconda3/lib/python3.7/json/init.py”, line 348, in loads
return _default_decoder.decode(s)
File “/home5/shonrao/miniconda3/lib/python3.7/json/decoder.py”, line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File “/home5/shonrao/miniconda3/lib/python3.7/json/decoder.py”, line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
The VASP job seems to have run properly, but the FW_offline.json file is empty at the end of the run. Using lpad recover_offline gives the below error and the job fizzles out.
File “/home5/shonrao/miniconda3/lib/python3.7/site-packages/fireworks/core/launchpad.py”, line 1691, in recover_offline
offline_data = loadfn(offline_loc)
File “/home5/shonrao/miniconda3/lib/python3.7/site-packages/monty/serialization.py”, line 83, in loadfn
return json.load(fp, *args, **kwargs)
File “/home5/shonrao/miniconda3/lib/python3.7/json/init.py”, line 296, in load
parse_constant=parse_constant, object_pairs_hook=object_pairs_hook, **kw)
File “/home5/shonrao/miniconda3/lib/python3.7/json/init.py”, line 361, in loads
return cls(**kw).decode(s)
File “/home5/shonrao/miniconda3/lib/python3.7/site-packages/monty/json.py”, line 255, in decode
d = json.JSONDecoder.decode(self, s)
2019-07-22 16:01:13,056 INFO FINISHED recovering offline runs. 0 job(s) recovered: []
2019-07-22 16:01:13,056 INFO FAILED to recover offline fw_ids: [2, 1]
I was reading through some of the previous threads, but mine doesn’t seem to be a gzip-related error. I also tried changing the “db_file” parameter in my_fworker.yaml to null, and I still get the same errors. Any idea why this might be happening?
Shreyas
Hi Shreyas
We don’t really use or actively support atomate in offline mode. That said, can you print out the contents of the “checkpoint” variable prior to the Rocket.update_checkpoint command being executed (line 245 in rocket.py in the latest FWS)?
For the offline mode to work out, the contents of the checkpoint need to be JSON-able. But it seems that the checkpoint is including a VaspJob object which is not JSONable. I just want to see what the checkpoint is supposed to look like and see if we can fix.
Anubhav
**kw).encode(obj)
sys.exit(rlaunch())
Shreyas
Same problem here. Please fix offline mode. I will gladly provide my configuration if it helps
FW_job.error:
  File "/home/sugon/venvs/atomate/lib/python3.7/site-packages/fireworks/core/rocket.py", line 246, in run
  File "/home/sugon/venvs/atomate/lib/python3.7/site-packages/fireworks/core/rocket.py", line 443, in update_checkpoint
  File "/home/sugon/anaconda3/lib/python3.7/json/__init__.py", line 238, in dumps
    **kw).encode(obj)
  File "/home/sugon/anaconda3/lib/python3.7/json/encoder.py", line 199, in encode
  File "/home/sugon/anaconda3/lib/python3.7/json/encoder.py", line 257, in iterencode
  File "/home/sugon/anaconda3/lib/python3.7/json/encoder.py", line 179, in default
  File "/home/sugon/venvs/atomate/bin/rlaunch", line 8, in <module>
    sys.exit(rlaunch())
  File "/home/sugon/venvs/atomate/lib/python3.7/site-packages/fireworks/scripts/rlaunch_run.py", line 154, in rlaunch
  File "/home/sugon/venvs/atomate/lib/python3.7/site-packages/fireworks/core/rocket_launcher.py", line 58, in launch_rocket
  File "/home/sugon/venvs/atomate/lib/python3.7/site-packages/fireworks/core/rocket.py", line 415, in run
  File "/home/sugon/anaconda3/lib/python3.7/json/__init__.py", line 348, in loads
  File "/home/sugon/anaconda3/lib/python3.7/json/decoder.py", line 337, in decode
  File "/home/sugon/anaconda3/lib/python3.7/json/decoder.py", line 355, in raw_decode
Dear Anubhav Jain,
I got this content you asked above.
Seems that <custodian.vasp.jobs.VaspJob at 0x2afeddaddc50> is not JSONable thing
I’ll try to fix it somehow and tell about results there.
In [1]: import pickle
In [2]: with open(‘block_2021-05-28-13-04-50-066054/launcher_2021-05-28-13-04-51-570345/error.pkl’,‘rb’) as f:
…: checkpoint = pickle.load(f)
In [3]: checkpoint
Out[3]:
{’_task_n’: 3,
‘_all_stored_data’: {‘custodian’: [{‘job’: <custodian.vasp.jobs.VaspJob at 0x2afeddaddc50>,
‘corrections’: [],
‘handler’: None,
‘validator’: None,
‘max_errors’: False,
‘max_errors_per_job’: False,
‘max_errors_per_handler’: False,
‘nonzero_return_code’: False}]},
‘_all_update_spec’: {},
‘_all_mod_spec’: []}
In [9]: checkpoint['_all_stored_data']['custodian'][0]['job']
Out[9]: <custodian.vasp.jobs.VaspJob at 0x2b3d1be74358>
In [10]: job = checkpoint['_all_stored_data']['custodian'][0]['job']
In [11]: job.as_dict()
Out[11]:
{'@module': 'custodian.vasp.jobs',
 '@class': 'VaspJob',
 '@version': '2021.2.8',
 'vasp_cmd': ['mpirun', '-np', '36', '/home/sugon/bin/vasp_std'],
 'output_file': 'vasp.out',
 'stderr_file': 'std_err.txt',
 'suffix': '',
 'final': True,
 'backup': True,
 'auto_npar': False,
 'auto_gamma': True,
 'settings_override': None,
 'gamma_vasp_cmd': None,
 'copy_magmom': False,
 'auto_continue': False}
