ERROR: Unknown fix rigid/small/omp keyword group (src/RIGID/fix_rigid_small.cpp:151)
Hello everyone,
First of all, I’d like to express my appreciation for the continuous support provided by the LAMMPS development team.
I am currently trying to simulate the behavior of granular particles using LAMMPS with hardware acceleration. My LAMMPS executable is built with the RIGID package, so the fix rigid/small/omp command should be recognized.
However, when I try to use fix rigid/small/omp, LAMMPS returns an error. In contrast, if I use fix rigid/omp, it runs without any issues.
Below is a minimum working example (MWE) that demonstrates the problem:
=== MWE ===
units            si
atom_style       sphere
boundary         f f f
comm_modify      vel yes
atom_modify      map array
package          omp 4
dimension        3
neigh_modify     delay 0 every 1 check yes
variable         crit_dt      equal 5e-7
region           domain3D block -0.05 0.05 -0.05 0.05 -0.05 0.05
create_box       2 domain3D
fix              grav_acc all gravity 9.81 vector 0.0 0.0 -1.0
fix              viscous_damping all viscous 0.0001
read_data        clumps.atom add append
group            clump1 id 1 2
group            clump2 id 3 4
fix               rigidAll all rigid/small/omp group 2 clump1 clump2
#fix               rigidAll all rigid/omp group 2 clump1 clump2
pair_style       gran/hertz/history/omp 200000.0 NULL 50.0 NULL 0.5 1
pair_coeff       * *
fix              bottomPlate all wall/gran granular hertz/material 70e9 0.01 0.25 tangential mindlin_rescale NULL 1.0 0.4 &
                 damping tsuji rolling none &
                 zplane -0.03 NULL
timestep         ${crit_dt}
compute          temp_sphere all temp/sphere
thermo_modify    temp temp_sphere
run              3000000
quit
=== End of MWE ===
=== clumps.atom ===
Python generated LAMMPS data file
4 atoms
2 atom types
#0 0.08 xlo xhi
#0 0.04 ylo yhi
#0 0.08 zlo zhi
Atoms
1 1 0.02 2700 0.0 0.0 0.0
2 1 0.01 2700 0.0 0.0 0.01
3 2 0.02 2700 0.05 0.0 0.0
4 2 0.01 2700 0.05 0.0 0.01
=== End of clumps.atom ===
=== Error Message when using (fix rigid/small/omp) ===
$ mpirun -np 10 ./lmp_IGO -in TMI_2.in
LAMMPS (29 Aug 2024 - Maintenance - stable_29Aug2024_update1-26-g89e442dac1-modified)
OMP_NUM_THREADS environment is not set. Defaulting to 1 thread. (src/comm.cpp:98)
set 4 OpenMP thread(s) per MPI task
using multi-threaded neighbor list subroutines
Created orthogonal box = (-0.05 -0.05 -0.05) to (0.05 0.05 0.05)
  1 by 2 by 5 MPI processor grid
Reading data file ...
WARNING: Non-zero image flags with growing box can produce bad coordinates (src/read_data.cpp:675)
  orthogonal box = (-0.5 -0.5 -0.5) to (0.5 0.5 0.5)
  reading atoms ...
  4 atoms
  read_data CPU = 0.001 seconds
2 atoms in group clump1
2 atoms in group clump2
Last command: fix               rigidAll all rigid/small/omp group 2 clump1 clump2
=== End of Error message ===
=== Information of LAMMPS ===
$ ./lmp_IGO -help
Large-scale Atomic/Molecular Massively Parallel Simulator - 29 Aug 2024 - Maintenance
Git info (maintenance / stable_29Aug2024_update1-26-g89e442dac1-modified)
OS: Linux "Ubuntu 24.04.1 LTS" 6.8.0-51-generic x86_64
Compiler: Intel LLVM C++ 202500.0 / Intel(R) oneAPI DPC++/C++ Compiler 2025.0.4 (2025.0.4.20241205) with OpenMP 5.1
C++ standard: C++11
MPI v3.1: Open MPI v5.0.6, package: Open MPI hp-z8@HP-Z8 Distribution, ident: 5.0.6, repo rev: v5.0.6, Nov 15, 2024
Accelerator configuration:
OPENMP package API: OpenMP
OPENMP package precision: double
OpenMP standard: OpenMP 5.1
INTEL package API: OpenMP
INTEL package precision: single mixed double
INTEL package SIMD: enabled
FFT information:
FFT precision  = double
FFT engine  = mpiFFT
FFT library = KISS
Active compile time flags:
-DLAMMPS_GZIP
-DLAMMPS_FFMPEG
-DLAMMPS_SMALLBIG
sizeof(smallint): 32-bit
sizeof(imageint): 32-bit
sizeof(tagint):   32-bit
sizeof(bigint):   64-bit
Available compression formats:
Extension: .gz     Command: gzip
Extension: .bz2    Command: bzip2
Extension: .zst    Command: zstd
Extension: .xz     Command: xz
Extension: .lzma   Command: xz
Installed packages:
GRANULAR INTEL OPENMP RIGID VTK
List of individual style options included in this LAMMPS executable
* Atom styles:
atomic          body            charge          ellipsoid       hybrid
line            sphere          tri
* Integrate styles:
respa           respa/omp       verlet
* Minimize styles:
cg              fire/old        fire            hftn            quickmin
sd
* Pair styles:
born            born/omp        buck            buck/coul/cut
buck/coul/cut/intel             buck/coul/cut/omp               buck/intel
buck/omp        coul/cut        coul/cut/omp    coul/debye      coul/debye/omp
coul/dsf        coul/dsf/omp    coul/wolf       coul/wolf/omp   meam/c
reax            reax/c          mesont/tpm      gran/hertz/history
gran/hertz/history/omp          gran/hooke      gran/hooke/history
gran/hooke/history/omp          gran/hooke/omp  granular        hybrid
hybrid/omp      hybrid/molecular                hybrid/molecular/omp
hybrid/overlay  hybrid/overlay/omp              hybrid/scaled
hybrid/scaled/omp               lj/cut          lj/cut/coul/cut
lj/cut/coul/cut/omp             lj/cut/intel    lj/cut/omp      lj/expand
lj/expand/omp   morse           morse/omp       soft            soft/omp
table           table/omp       yukawa          yukawa/omp      zbl
zbl/omp         zero
* Fix styles
adapt           add/heat        addforce        ave/atom        ave/chunk
ave/correlate   ave/grid        ave/histo       ave/histo/weight
ave/time        aveforce        balance         box/relax       damping/cundall
deform          deposit         ave/spatial     ave/spatial/sphere
lb/pc           lb/rigid/pc/sphere              reax/c/bonds    reax/c/species
dt/reset        efield          ehex            enforce2d       evaporate
external        freeze          gravity         gravity/omp     halt
heat            heat/flow       indent          langevin        lineforce
momentum        move            nph             nph/omp         nph/sphere
nph/sphere/omp  npt             npt/intel       npt/omp         npt/sphere
npt/sphere/omp  nve             nve/intel       nve/limit       nve/noforce
nve/omp         nve/sphere      nve/sphere/omp  nvt             nvt/intel
nvt/omp         nvt/sllod       nvt/sllod/intel nvt/sllod/omp   nvt/sphere
nvt/sphere/omp  pair            planeforce      pour            press/berendsen
press/langevin  print           property/atom   rattle          recenter
restrain        rigid           rigid/nph       rigid/nph/omp   rigid/nph/small
rigid/npt       rigid/npt/omp   rigid/npt/small rigid/nve       rigid/nve/omp
rigid/nve/small rigid/nvt       rigid/nvt/omp   rigid/nvt/small rigid/omp
rigid/small     rigid/small/omp setforce        shake           spring
spring/chunk    spring/self     store/force     store/state     temp/berendsen
temp/rescale    thermal/conductivity            vector          viscous
wall/gran       wall/gran/region                wall/harmonic   wall/lj1043
wall/lj126      wall/lj93       wall/morse      wall/reflect    wall/region
wall/table
=== End of Information ===
I would greatly appreciate any advice or insights on how to resolve this issue.
Thank you!
That is not correct, for fix rigid/small/omp you also need to have the OPENMP package installed.
The command is recognized, otherwise, it would not print an error message. The error message says that the “group” keyword is not recognized and that is documented behavior. All rigid/small variants can only be used with the “molecule” keyword. LAMMPS is behaving exactly as it should according to the documentation.
Thank you.
