Our lab is planning to buy a new computer with 2 processors and 12 cores in each. So we send a request to the computer manufacture to have a benchmark computing. I specify the Processor in the input file by using
Processors 2 3 2
And using the command line “mpiexec -np 12” to run the program. But it returned
[email protected]:/benchmark$ mpiexec -np 12 ./lmp_mpi <in.C.10w >out.C.10w
[email protected]:/benchmark$ cat out.C.10w
LAMMPS (10 Aug 2015)
ERROR: Specified processors != physical processors (../comm.cpp:287)
Processors 2 3 2
returned
We have used our 4-core computer doing the same thing without problems
before. So can anyone tell me where this error comes from?
you should have only one line of "
LAMMPS (10 Aug 2015)" in your output.
the fact that you are getting more is an indication that you are running
either a serial binary or that your mpiexec command is from a different MPI
library than what the binary was compiled with. thus mpiexec will not
launch one parallel job with 12 ranks, but 12 serial jobs with 1 rank each.
the error message then comes from processors command, as only 1 processor
on the same communicator is available for each instance, yet your command
requires 12.
