There is an error report when I try to install the openkim-models package via Homebrew
Last login: Thu Mar 17 17:11:18 on ttys005
(base) yswang@yswangdeMacBook-Pro ~ % brew install openkim-models
fatal: Could not resolve HEAD to a revision
Warning: No available formula with the name "openkim-models".
==> Searching for similarly named formulae...
Error: No similarly named formulae found.
==> Searching for a previously deleted formula (in the last month)...
Error: No previously deleted formula found.
==> Searching taps on GitHub...
Error: No formulae found in taps.
Can’t figure out what’s wrong here.
I would appreciate somebody can help me. Thanks.
This appears to be a problem with your Homebrew installation. It’s not obvious to me what the problem is, so you’ll probably need to ask for help from the Homebrew community.
Thank you, Ryan! Now I have installed the openkim-models and run
source /usr/local/bin/kim-api-activate
But when I try to run
pip install --user kimpy
then another error comes:
(base) yswang@yswangdeMacBook-Pro ~ % pip3 install --user kimpy
Collecting kimpy
Using cached kimpy-2.0.0.tar.gz (51 kB)
Preparing metadata (setup.py) ... error
error: subprocess-exited-with-error
× python setup.py egg_info did not run successfully.
│ exit code: 1
╰─> [27 lines of output]
File "/private/var/folders/8f/s4bcrbxj7v5dnjmql59hxggc0000gn/T/pip-install-tz4qv477/kimpy_458e9b045bac45579b089308a310364e/setup.py", line 32, in inquire_kim_api
["pkg-config", kim_api_key, "libkim-api"], universal_newlines=True
File "/Users/yswang/anaconda3/lib/python3.7/subprocess.py", line 395, in check_output
**kwargs).stdout
File "/Users/yswang/anaconda3/lib/python3.7/subprocess.py", line 472, in run
with Popen(*popenargs, **kwargs) as process:
File "/Users/yswang/anaconda3/lib/python3.7/subprocess.py", line 775, in __init__
restore_signals, start_new_session)
File "/Users/yswang/anaconda3/lib/python3.7/subprocess.py", line 1522, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: 'pkg-config': 'pkg-config'
During handling of the above exception, another exception occurred:
File "<string>", line 36, in <module>
File "<pip-setuptools-caller>", line 34, in <module>
File "/private/var/folders/8f/s4bcrbxj7v5dnjmql59hxggc0000gn/T/pip-install-tz4qv477/kimpy_458e9b045bac45579b089308a310364e/setup.py", line 310, in <module>
chech_kim_api_compatibility()
File "/private/var/folders/8f/s4bcrbxj7v5dnjmql59hxggc0000gn/T/pip-install-tz4qv477/kimpy_458e9b045bac45579b089308a310364e/setup.py", line 293, in chech_kim_api_compatibility
modversion = inquire_kim_api("--modversion")[0]
File "/private/var/folders/8f/s4bcrbxj7v5dnjmql59hxggc0000gn/T/pip-install-tz4qv477/kimpy_458e9b045bac45579b089308a310364e/setup.py", line 40, in inquire_kim_api
raise Exception(msg)
Exception: Package "libkim-api" was not found in the search path.
Make sure "kim-api" is installed and do not forget to "source path/to/kim-api-activate".
See "Installing the KIM API" at https://openkim.org/kim-api for more detailed information.
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
