Hi!
I want to add two potentials for the YAG system. To do this, I’m trying to put some .cpp .h files in src and compile (tried make and cmake). Errors appear:
[ 87%] Building CXX object CMakeFiles/lammps.dir/home/artem/lammps/src/pair_mbmh.cpp.o
/home/artem/lammps/src/pair_mbmh.cpp: In member function ‘virtual void LAMMPS_NS::PairMBMH::init_style()’:
/home/artem/lammps/src/pair_mbmh.cpp:269:39: error: ‘int LAMMPS_NS::NeighRequest::half’ is protected within this context
269 | neighbor->requests[irequest]->half=0;
In file included from /home/artem/lammps/src/pair_mbmh.cpp:22:
/home/artem/lammps/src/neigh_request.h:54:7: note: declared protected here
54 | int half; // half neigh list (set by default)
/home/artem/lammps/src/pair_mbmh.cpp:270:39: error: ‘int LAMMPS_NS::NeighRequest::full’ is protected within this context
270 | neighbor->requests[irequest]->full=1;
/home/artem/lammps/src/neigh_request.h:55:7: note: declared protected here
55 | int full; // full neigh list
/home/artem/lammps/src/pair_mbmh.cpp: In member function ‘void LAMMPS_NS::PairMBMH::read_file(char*)’:
/home/artem/lammps/src/pair_mbmh.cpp:324:22: error: ‘class LAMMPS_NS::Atom’ has no member named ‘count_words’
324 | nwords=atom->count_words(line);
/home/artem/lammps/src/pair_mbmh.cpp:342:30: error: ‘class LAMMPS_NS::Atom’ has no member named ‘count_words’
342 | nwords=atom->count_words(line);
gmake[2]: *** [CMakeFiles/lammps.dir/build.make:5018: CMakeFiles/lammps.dir/home/artem/lammps/src/pair_mbmh.cpp.o] Error 1
gmake[1]: *** [CMakeFiles/Makefile2:171: CMakeFiles/lammps.dir/all] Error 2
gmake: *** [Makefile:136: all] Error 2
What could be the problem? Everything worked for my supervisor, but I have lost contact with him now. I tried compiling a clean version and recompiling a ready version with new files. The error is the same.
This code was written for an old version of LAMMPS. The compilation error is a manifestation of the risks of having custom source code outside the LAMMPS distribution: when there a modifications to the internal programming interfaces, the external code will no longer compile.
Oh, that makes sense, thanks. I guess just upgrading to an older version will be enough to solve this little task, but just which one…? I didn’t find any version hints when I opened the .cpp file, I guess it’s not so trivial to define a specific version? Is it possible to solve it without going through all the versions?
This is not recommended. You are missing out on all the bug fixes and new features in LAMMPS.
The issue you are seeing should be easily correctable with the information in the pages in the manual I was pointing out.
/home/artem/lammps23/src/pair_mbmh.cpp:323:22: error: ‘class LAMMPS_NS::Atom’ has no member named ‘count_words’
323 | nwords=atom->count_words(line);
/home/artem/lammps23/src/pair_mbmh.cpp:341:30: error: ‘class LAMMPS_NS::Atom’ has no member named ‘count_words’
341 | nwords=atom->count_words(line);
I will add a paragraph about this function to the documentation. It must have slipped through the cracks so far, since this function is not needed when updating the potential file parser to use the tokenizer and file reader classes: 4.9. Notes for developers and code maintainers — LAMMPS documentation
One general note. Is this code available for the general public somewhere?
If not, consider contributing it for either the LAMMPS plugins repository (no review, no documentation, no testing, no guarantees, assistance with further modernizing the code and keeping it usable with current LAMMPS versions) or for general distribution to the LAMMPS repository (requires documentation, will be subject to testing, and code review).
As frequent forum contributor @srtee is often telling people, using unpublished software or even unpublished non-trivial input decks for scientific research makes it impossible to reproduce results and thus taints the value of any such results. There is a website discussing the FAIR principles.
